[PATCH 19/23] rtems-rfs-buffer.c: Correct printf() format specifiers to eliminate warnings
Wed Sep 3 15:26:13 UTC 2014
 cpukit/libfs/src/rfs/rtems-rfs-buffer.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
index 3d89f5f..4192b21 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
@@ -52,13 +52,12 @@ rtems_rfs_scan_chain (rtems_chain_control*   chain,
     buffer = (rtems_rfs_buffer*) node;
     if (rtems_rfs_trace (RTEMS_RFS_TRACE_BUFFER_CHAINS))
-      printf ("%" PRIuPTR " ", ((intptr_t) buffer->user));
+      printf ("%p ", buffer->user);
     if (((rtems_rfs_buffer_block) ((intptr_t)(buffer->user))) == block)
-        printf (": found block=%" PRIuPTR "\n",
-                ((intptr_t)(buffer->user)));
+        printf (": found block=%p\n", buffer->user);
       (*count)--;
       rtems_chain_extract_unprotected (node);
1.9.3
