[PATCH 19/23] rtems-rfs-buffer.c: Correct printf() format specifiers to eliminate warnings
Thu Sep 4 16:21:18 UTC 2014
On Wed, Sep 3, 2014 at 11:26 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
>  cpukit/libfs/src/rfs/rtems-rfs-buffer.c | 5 ++---
>  1 file changed, 2 insertions(+), 3 deletions(-)
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> index 3d89f5f..4192b21 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
> @@ -52,13 +52,12 @@ rtems_rfs_scan_chain (rtems_chain_control*   chain,
>      buffer = (rtems_rfs_buffer*) node;
>      if (rtems_rfs_trace (RTEMS_RFS_TRACE_BUFFER_CHAINS))
> -      printf ("%" PRIuPTR " ", ((intptr_t) buffer->user));
> +      printf ("%p ", buffer->user);
>      if (((rtems_rfs_buffer_block) ((intptr_t)(buffer->user))) == block)
> -        printf (": found block=%" PRIuPTR "\n",
> -                ((intptr_t)(buffer->user)));
> +        printf (": found block=%p\n", buffer->user);
What is the warning this fixed? The "PRIuPTR" should be the right way
to print an (unsigned) pointer. Perhaps changing the cast to
(uintptr_t) would fix the warning?
>        (*count)--;
>        rtems_chain_extract_unprotected (node);
> 1.9.3
> devel mailing list
> devel at rtems.org
