[PATCH 14/23] mprotect.c: Remove warning for no prototype
Thu Sep 4 17:10:03 UTC 2014
On 9/4/2014 11:19 AM, Gedare Bloom wrote:
> On Wed, Sep 3, 2014 at 11:26 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>>   cpukit/posix/src/mprotect.c | 23 ++++++++++++++---------
>>   1 file changed, 14 insertions(+), 9 deletions(-)
>> diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
>> index f2f8af6..51b565e 100644
>> --- a/cpukit/posix/src/mprotect.c
>> +++ b/cpukit/posix/src/mprotect.c
>> @@ -3,10 +3,19 @@
>>    * @brief Change Memory Protection
>>    * @ingroup POSIXAPI
>> + * 12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
>> + * This is not a functional version of mprotect() but the SPARC backend
>> + * for at least gcc 2.8.1 plus gnat 3.13p and gcc 3.0.1 require it to
>> + * be there and return 0.
>> + * As of gcc 4.2.2, the gcc SPARC backend doesn't appear to have a
>> + * way to call this for RTEMS anymore but it doesn't hurt to leave it.
>> - *  COPYRIGHT (c) 1989-2007.
>> + *  COPYRIGHT (c) 1989-2014.
>>    *  On-Line Applications Research Corporation (OAR).
>>    *  The license and distribution terms for this file may be
>> @@ -21,16 +30,12 @@
>>   #include <unistd.h>
>> - *  12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
>> - *  This is not a functional version but the SPARC backend for at least
>> - *  gcc 2.8.1 plus gnat 3.13p and gcc 3.0.1 require it to be there and
>> - *  return 0.
>> - *  As of gcc 4.2.2, the gcc SPARC backend doesn't appear to have a
>> - *  way to call this for RTEMS anymore but it doesn't hurt to leave it.
>> + * RTEMS does not have <sys/mman.h> so we need a prototype here to
>> + * avoid warnings.
>> +int mprotect( const void *, size_t, int );
> I don't like (despise) adding prototypes to C files just to get rid of
> this warning. The prototype should be coming from whatever header
> provides the function, or the function should be declared static.
We can't make it static as it doesn't solve the problem of providing a
public
symbol to satisfy linking. As the comments indicate, this was added to let
gcc produced SPARC executables actually link.
Also I didn't see adding <sys/mman.h> when we don't support any of it.
http://pubs.opengroup.org/onlinepubs/009695399/basedefs/sys/mman.h.html
However, that doesn't mean that adding <sys/mman.h> and a bunch of
stubs that return ENOSYS isn't an acceptable option. I just don't want to
invest the effort now.
>>   int mprotect(
>>     const void *addr __attribute__((unused)),
>>     size_t len __attribute__((unused)),
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
