[PATCH 14/23] mprotect.c: Remove warning for no prototype
Thu Sep 4 19:06:18 UTC 2014
On Thu, Sep 4, 2014 at 1:10 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 9/4/2014 11:19 AM, Gedare Bloom wrote:
>> On Wed, Sep 3, 2014 at 11:26 AM, Joel Sherrill
>>>   cpukit/posix/src/mprotect.c | 23 ++++++++++++++---------
>>>   1 file changed, 14 insertions(+), 9 deletions(-)
>>> diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
>>> index f2f8af6..51b565e 100644
>>> --- a/cpukit/posix/src/mprotect.c
>>> +++ b/cpukit/posix/src/mprotect.c
>>> @@ -3,10 +3,19 @@
>>>    * @brief Change Memory Protection
>>>    * @ingroup POSIXAPI
>>> + * 12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
>>> + * This is not a functional version of mprotect() but the SPARC backend
>>> + * for at least gcc 2.8.1 plus gnat 3.13p and gcc 3.0.1 require it to
>>> + * be there and return 0.
>>> + * As of gcc 4.2.2, the gcc SPARC backend doesn't appear to have a
>>> + * way to call this for RTEMS anymore but it doesn't hurt to leave it.
>>> - *  COPYRIGHT (c) 1989-2007.
>>> + *  COPYRIGHT (c) 1989-2014.
>>>    *  On-Line Applications Research Corporation (OAR).
>>>    *  The license and distribution terms for this file may be
>>> @@ -21,16 +30,12 @@
>>>   #include <unistd.h>
>>> - *  12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
>>> - *  This is not a functional version but the SPARC backend for at least
>>> - *  gcc 2.8.1 plus gnat 3.13p and gcc 3.0.1 require it to be there and
>>> - *  return 0.
>>> - *  As of gcc 4.2.2, the gcc SPARC backend doesn't appear to have a
>>> - *  way to call this for RTEMS anymore but it doesn't hurt to leave it.
>>> + * RTEMS does not have <sys/mman.h> so we need a prototype here to
>>> + * avoid warnings.
>>> +int mprotect( const void *, size_t, int );
>> I don't like (despise) adding prototypes to C files just to get rid of
>> this warning. The prototype should be coming from whatever header
>> provides the function, or the function should be declared static.
> We can't make it static as it doesn't solve the problem of providing a
> public
> symbol to satisfy linking. As the comments indicate, this was added to let
> gcc produced SPARC executables actually link.
> Also I didn't see adding <sys/mman.h> when we don't support any of it.
> http://pubs.opengroup.org/onlinepubs/009695399/basedefs/sys/mman.h.html
> However, that doesn't mean that adding <sys/mman.h> and a bunch of
> stubs that return ENOSYS isn't an acceptable option. I just don't want to
> invest the effort now.
Make a note to that effect.
-gedare
>>>   int mprotect(
>>>     const void *addr __attribute__((unused)),
>>>     size_t len __attribute__((unused)),
>>> 1.9.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
