[PATCH 14/23] mprotect.c: Remove warning for no prototype
Thu Sep 4 19:38:22 UTC 2014
On 9/4/2014 2:06 PM, Gedare Bloom wrote:
> On Thu, Sep 4, 2014 at 1:10 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> On 9/4/2014 11:19 AM, Gedare Bloom wrote:
>>> On Wed, Sep 3, 2014 at 11:26 AM, Joel Sherrill
>>>>   cpukit/posix/src/mprotect.c | 23 ++++++++++++++---------
>>>>   1 file changed, 14 insertions(+), 9 deletions(-)
>>>> diff --git a/cpukit/posix/src/mprotect.c b/cpukit/posix/src/mprotect.c
>>>> index f2f8af6..51b565e 100644
>>>> --- a/cpukit/posix/src/mprotect.c
>>>> +++ b/cpukit/posix/src/mprotect.c
>>>> @@ -3,10 +3,19 @@
>>>>    * @brief Change Memory Protection
>>>>    * @ingroup POSIXAPI
>>>> + * 12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
>>>> + * This is not a functional version of mprotect() but the SPARC backend
>>>> + * for at least gcc 2.8.1 plus gnat 3.13p and gcc 3.0.1 require it to
>>>> + * be there and return 0.
>>>> + * As of gcc 4.2.2, the gcc SPARC backend doesn't appear to have a
>>>> + * way to call this for RTEMS anymore but it doesn't hurt to leave it.
>>>> - *  COPYRIGHT (c) 1989-2007.
>>>> + *  COPYRIGHT (c) 1989-2014.
>>>>    *  On-Line Applications Research Corporation (OAR).
>>>>    *  The license and distribution terms for this file may be
>>>> @@ -21,16 +30,12 @@
>>>>   #include <unistd.h>
>>>> - *  12.2.3 Change Memory Protection, P1003.1b-1996, p. 277.
>>>> - *  This is not a functional version but the SPARC backend for at least
>>>> - *  gcc 2.8.1 plus gnat 3.13p and gcc 3.0.1 require it to be there and
>>>> - *  return 0.
>>>> - *  As of gcc 4.2.2, the gcc SPARC backend doesn't appear to have a
>>>> - *  way to call this for RTEMS anymore but it doesn't hurt to leave it.
>>>> + * RTEMS does not have <sys/mman.h> so we need a prototype here to
>>>> + * avoid warnings.
>>>> +int mprotect( const void *, size_t, int );
>>> I don't like (despise) adding prototypes to C files just to get rid of
>>> this warning. The prototype should be coming from whatever header
>>> provides the function, or the function should be declared static.
>> We can't make it static as it doesn't solve the problem of providing a
>> public
>> symbol to satisfy linking. As the comments indicate, this was added to let
>> gcc produced SPARC executables actually link.
>> Also I didn't see adding <sys/mman.h> when we don't support any of it.
>> http://pubs.opengroup.org/onlinepubs/009695399/basedefs/sys/mman.h.html
>> However, that doesn't mean that adding <sys/mman.h> and a bunch of
>> stubs that return ENOSYS isn't an acceptable option. I just don't want to
>> invest the effort now.
> Make a note to that effect.
PR? Note in code? Where?
I can assign the PR to you. :)
> -gedare
>>>>   int mprotect(
>>>>     const void *addr __attribute__((unused)),
>>>>     size_t len __attribute__((unused)),
>>>> 1.9.3
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
