[PATCH 01/23] raspberrypi: Use shared bspreset.c
Fri Sep 5 06:40:07 UTC 2014
On 04/09/14 18:16, Gedare Bloom wrote:
> On Wed, Sep 3, 2014 at 11:25 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com>  wrote:
>> >  c/src/lib/libbsp/arm/csb337/startup/bspreset.c     |  1 +
>> >  c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  2 +-
>> >  .../lib/libbsp/arm/raspberrypi/startup/bspreset.c  | 35 ------------
>> >  testsuites/sptests/spintr_err01/init.c             | 65 +++++++++++-----------
>> >  4 files changed, 34 insertions(+), 69 deletions(-)
>> >  delete mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
>> >diff --git a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
>> >index 1167d92..940ff7f 100644
>> >--- a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
>> >+++ b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
>> >@@ -17,6 +17,7 @@ void bsp_reset(void)
>> >    rtems_interrupt_level level;
>> >+  (void) level;
>> >    rtems_interrupt_disable(level);
> Is it ok to put (void) level; and then use level?
Logically it makes more sense to use
(void) level;
since rtems_interrupt_disable() sets the level, but we are only interested in
the side-effects of rtems_interrupt_disable() and not the level itself.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
