[PATCH 01/23] raspberrypi: Use shared bspreset.c
Fri Sep 5 13:48:39 UTC 2014
On 9/5/2014 1:40 AM, Sebastian Huber wrote:
> On 04/09/14 18:16, Gedare Bloom wrote:
>> On Wed, Sep 3, 2014 at 11:25 AM, Joel Sherrill
>> <joel.sherrill at oarcorp.com>  wrote:
>>>>  c/src/lib/libbsp/arm/csb337/startup/bspreset.c     |  1 +
>>>>  c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  2 +-
>>>>  .../lib/libbsp/arm/raspberrypi/startup/bspreset.c  | 35 ------------
>>>>  testsuites/sptests/spintr_err01/init.c             | 65 +++++++++++-----------
>>>>  4 files changed, 34 insertions(+), 69 deletions(-)
>>>>  delete mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
>>>> diff --git a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
>>>> index 1167d92..940ff7f 100644
>>>> --- a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
>>>> +++ b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
>>>> @@ -17,6 +17,7 @@ void bsp_reset(void)
>>>>    rtems_interrupt_level level;
>>>> +  (void) level;
>>>>    rtems_interrupt_disable(level);
>> Is it ok to put (void) level; and then use level?
> Logically it makes more sense to use
> (void) level;
> since rtems_interrupt_disable() sets the level, but we are only interested in
> the side-effects of rtems_interrupt_disable() and not the level itself.
Do you want me to swap the lines?
