[PATCH 5/7] posix: Use RTEMS_DECONST()
Fri Sep 5 07:33:55 UTC 2014
 cpukit/posix/include/rtems/posix/key.h | 2 +-
 cpukit/posix/src/keysetspecific.c      | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/key.h b/cpukit/posix/include/rtems/posix/key.h
index 7cc179c..6e52544 100644
--- a/cpukit/posix/include/rtems/posix/key.h
+++ b/cpukit/posix/include/rtems/posix/key.h
@@ -68,7 +68,7 @@ typedef struct {
    * @brief The thread specific POSIX key value.
-  const void *value;
+  void *value;
 } POSIX_Keys_Key_value_pair;
diff --git a/cpukit/posix/src/keysetspecific.c b/cpukit/posix/src/keysetspecific.c
index ee85ac2..8e4b3a4 100644
--- a/cpukit/posix/src/keysetspecific.c
+++ b/cpukit/posix/src/keysetspecific.c
@@ -49,7 +49,7 @@ int pthread_setspecific(
       p = _POSIX_Keys_Find( key, executing, &search_node );
       if ( p != NULL ) {
         value_pair_ptr = POSIX_KEYS_RBTREE_NODE_TO_KEY_VALUE_PAIR( p );
-        value_pair_ptr->value = value;
+        value_pair_ptr->value = RTEMS_DECONST( void *, value );
       } else {
         value_pair_ptr = _POSIX_Keys_Key_value_pair_allocate();
@@ -61,7 +61,7 @@ int pthread_setspecific(
         value_pair_ptr->key = key;
         value_pair_ptr->thread = executing;
         /* The insert can only go wrong if the same node is already in a unique
          * tree. This has been already checked with the _RBTree_Find() */
         _RBTree_Insert(
1.8.4.5
