Automate RTEMS test results?
Gedare Bloom
gedare at rtems.org
Sat Sep 6 19:35:32 UTC 2014
See tester in rtems-tools.git it is designed for exactly what you ask. You
probably need to modify an existing script to run or1ksim.
On Sep 6, 2014 2:58 PM, "Hesham Moustafa" <heshamelmatary at gmail.com> wrote:
> Hi,
> Given that I am able to run qemu-or1k from sim-scripts (I will push
> the script soon)
> Is there a way to run all tests with one command and get results of
> how many passed/failed tests? (i.e, 5/10 passed tests)
> Thanks,
> Hesham
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140906/d05d93b7/attachment-0001.html>
