[PATCH] Adding "eth" linker script section for arm bsp.
Mon Sep 8 07:02:12 UTC 2014
On 02/09/14 15:07, Federico Casares wrote:
> Are you suggesting to remove the
> "lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg" and
> "lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth.cfg" files?
> The tcfg includes in its list two tests that should not be compiled for this
> BSP configuration, due to BBS size required by those tests. This differs from
> the other configurations available for the LPC176x.
Ok, I am fine with adding this BSP.  I think we have to address the explosion
of test demands separately.  Maybe select only one variant for each BSP family.
  There are not only BSP variants, but we also have BSP options.  It is not
possible to test everything.
Regarding the latest patch.  Please reduce the copy and paste in the *.cfg
files.  We don't need three copies of the same file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
