[PATCH] or1k: New cache manager.
Tue Sep 16 18:15:58 UTC 2014
On 9/16/2014 12:54 PM, Hesham Moustafa wrote:
> Hi
> On Tue, Sep 16, 2014 at 7:47 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> I don't understand this but I got it applied.
>> I manually edited the saved email to delete the preinstall.am
>> changes.  I committed the rest. Then I ran bootstrap -p myself
>> and folded that into the rest of your patch.
>> It should all be committed now.
> Thanks for doing this, me too do not know what's wrong. BTW, commits
> are not mirrored on github since 4 days ago.
>> How about some new test results. :)
> I did run one last night, no big progress since previous results :( Is
> there any tool, script, utility program or whatever that I can use to
> detect wrong memory access (i.e, stack overwrite, heap corruption,
> access to another task context)? I tried to add -fstack-protector-all
> to gcc, but QEMU did not get anything or core-dump, ticker just hangs.
I haven't checked into how gcc does its stack overwrite protection.
The tests by themselves don't have these problems. The first
possible source is incorrect layout of sections to memory by
the linker script. There is some debug code in boot
There used to be debug printk's in bspgetworkarea.c so you
could check if areas overlapped. That usually causes bad issues
though. Let's go through some basics:
+ Does hello world run and exit cleanly?
+ How far does ticker get?
+ Have you tried the trick I suggested earlier to disable the
real clock tick driver, use the simulator idle tick code, and
disable all the tests that are known to fail that way. This
will eliminate the ISR code as an issue because you won't
have any (if console output if polled).  See h8sim for
an example. Should be a Makefile.am change, adding
an include to the testsuite configuration file, building
and running.
>> --joel
>> On 9/16/2014 12:30 PM, Hesham ALMatary wrote:
>>> Implement new cache functions for or1k and create new bspstart function
>>> for or1ksim to initialize instruction and data caches. Also, sim.cfg
>>> is modified to enable/confiure cache units.
>>>  c/src/lib/libbsp/or1k/or1ksim/Makefile.am        |   9 +-
>>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am      |   4 +
>>>  c/src/lib/libbsp/or1k/or1ksim/sim.cfg            |  21 +-
>>>  c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c |  25 +++
>>>  c/src/lib/libbsp/or1k/shared/include/cache_.h    |  43 ++++
>>>  c/src/lib/libcpu/or1k/Makefile.am                |   3 +-
>>>  c/src/lib/libcpu/or1k/preinstall.am              |   4 +
>>>  c/src/lib/libcpu/or1k/shared/cache/cache.c       | 241 +++++++++++++++++++++++
>>>  c/src/lib/libcpu/or1k/shared/cache/cache_.h      |   2 +-
>>>  9 files changed, 334 insertions(+), 18 deletions(-)
>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>  create mode 100644 c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>  create mode 100644 c/src/lib/libcpu/or1k/shared/cache/cache.c
>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>> index 7af4fd0..7e1c10b 100644
>>> --- a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>> @@ -30,6 +30,7 @@ include_bsp_HEADERS += ../../shared/include/irq-info.h
>>>  include_bsp_HEADERS += ../../shared/include/stackalloc.h
>>>  include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>>>  include_bsp_HEADERS += ../../shared/tod.h
>>> +include_bsp_HEADERS += ../shared/include/cache_.h
>>>  include_bsp_HEADERS += include/irq.h
>>>  include_bsp_HEADERS += include/uart.h
>>>  include_bsp_HEADERS += include/or1ksim.h
>>> @@ -61,8 +62,8 @@ libbsp_a_CPPFLAGS =
>>>  libbsp_a_LIBADD =
>>>  # Startup
>>> -libbsp_a_SOURCES += ../../shared/bspstart.c
>>>  libbsp_a_SOURCES += ../../shared/bspreset.c
>>> +libbsp_a_SOURCES += startup/bspstart.c
>>>  # Shared
>>>  libbsp_a_SOURCES += ../../shared/bootcard.c
>>> @@ -72,8 +73,6 @@ libbsp_a_SOURCES += ../../shared/bsplibc.c
>>>  libbsp_a_SOURCES += ../../shared/bsppost.c
>>>  libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
>>>  libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>>> -libbsp_a_SOURCES += ../../shared/cpucounterread.c
>>> -libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
>>>  libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>>>  libbsp_a_SOURCES += ../../shared/sbrk.c
>>>  libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>>> @@ -100,9 +99,7 @@ libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>>  libbsp_a_SOURCES += irq/irq.c
>>>  # Cache
>>> -libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>>> -libbsp_a_SOURCES += ../../shared/include/cache_.h
>>> -libbsp_a_CPPFLAGS += -I$(srcdir)/../../shared/include
>>> +libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
>>>  #                  Special Rules                                              #
>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>> index 1561b18..c0fa6b8 100644
>>> --- a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>> @@ -86,6 +86,10 @@ $(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h $(PROJECT_INCLUDE)/bsp/$(dirsta
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
>>> +$(PROJECT_INCLUDE)/bsp/cache_.h: ../shared/include/cache_.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/cache_.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/cache_.h
>>>  $(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>> index 061f61a..ec73e3d 100644
>>> --- a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>> @@ -35,23 +35,23 @@ section mc
>>>  end
>>>  section ic
>>> -  enabled   =   0
>>> +  enabled   =   1
>>>    nsets     = 256
>>>    nways     =   1
>>> -  blocksize =  16
>>> +  blocksize =  32
>>>    hitdelay  =  20
>>> -  missdelay =  20
>>> +  missdelay =  60
>>>  end
>>>  section dc
>>> -  enabled = 0
>>> -  nsets = 256
>>> +  enabled = 1
>>> +  nsets = 256
>>>    nways = 1
>>> -  blocksize = 16
>>> -  load_hitdelay = 0
>>> -  load_missdelay = 0
>>> -  store_hitdelay = 0
>>> -  store_missdelay = 0
>>> +  blocksize = 32
>>> +  load_hitdelay = 40
>>> +  load_missdelay = 120
>>> +  store_hitdelay = 40
>>> +  store_missdelay = 120
>>>  end
>>>  section pic
>>> @@ -78,6 +78,7 @@ section cpu
>>>    ver = 0x12
>>>    cfg = 0x00
>>>    rev = 0x0001
>>> +  upr = 0x0000075f
>>>    superscalar = 0
>>>    hazards = 0
>>>    dependstats = 0
>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>> new file mode 100644
>>> index 0000000..d9fb7a7
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>> @@ -0,0 +1,25 @@
>>> + * @file
>>> + * @ingroup or1ksim
>>> + * @brief Benchmark timer support.
>>> + * Copyright (c) 2014 by Hesham ALMatary
>>> + *  The license and distribution terms for this file may be
>>> + *  found in the file LICENSE in this distribution or at
>>> + *  http://www.rtems.org/license/LICENSE
>>> +#include <bsp.h>
>>> +#include <bsp/bootcard.h>
>>> +#include <libcpu/cache.h>
>>> +void bsp_start( void )
>>> +  _CPU_cache_enable_instruction();
>>> +  _CPU_cache_enable_data();
>>> diff --git a/c/src/lib/libbsp/or1k/shared/include/cache_.h b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>>> index 0000000..ee54227
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>>> @@ -0,0 +1,43 @@
>>> + * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>>> + * http://www.rtems.org/license/LICENSE.
>>> +#ifndef LIBBSP_OR1K_SHARED_CACHE_H
>>> +#define LIBBSP_OR1K_SHARED_CACHE_H
>>> +#include <assert.h>
>>> +#include <bsp.h>
>>> +#include <rtems/rtems/intr.h>
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif /* __cplusplus */
>>> +/* These two defines also ensure that the rtems_cache_* functions have bodies */
>>> +#define CPU_DATA_CACHE_ALIGNMENT        32
>>> +#define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
>>> +#define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS 1
>>> +static inline size_t
>>> +_CPU_cache_get_data_cache_size( const uint32_t level )
>>> +  return (level == 0 || level == 1)? 8192 : 0;
>>> +_CPU_cache_get_instruction_cache_size( const uint32_t level )
>>> +#ifdef __cplusplus
>>> +#endif /* LIBBSP_OR1K_SHARED_CACHE_H */
>>> diff --git a/c/src/lib/libcpu/or1k/Makefile.am b/c/src/lib/libcpu/or1k/Makefile.am
>>> index f4a6372..0148548 100644
>>> --- a/c/src/lib/libcpu/or1k/Makefile.am
>>> +++ b/c/src/lib/libcpu/or1k/Makefile.am
>>> @@ -10,8 +10,9 @@ include_libcpudir = $(includedir)/libcpu
>>>  ## shared/cache
>>>  include_libcpu_HEADERS = ../shared/include/cache.h
>>> +include_libcpu_HEADERS += shared/cache/cache_.h
>>>  noinst_PROGRAMS += shared/cache.rel
>>> -shared_cache_rel_SOURCES = ../shared/src/no_cache.c shared/cache/cache_.h
>>> +shared_cache_rel_SOURCES = shared/cache/cache.c ../shared/src/cache_manager.c
>>>  shared_cache_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/cache
>>>  shared_cache_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>> diff --git a/c/src/lib/libcpu/or1k/preinstall.am b/c/src/lib/libcpu/or1k/preinstall.am
>>> index ee9d0da..84864cb 100644
>>> --- a/c/src/lib/libcpu/or1k/preinstall.am
>>> +++ b/c/src/lib/libcpu/or1k/preinstall.am
>>> @@ -22,3 +22,7 @@ $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
>>> +$(PROJECT_INCLUDE)/libcpu/cache_.h: shared/cache/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
>>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>>> index 0000000..fdc67ce
>>> --- /dev/null
>>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>>> @@ -0,0 +1,241 @@
>>> + * COPYRIGHT (c) 1989-2006
>>> + * On-Line Applications Research Corporation (OAR).
>>> +#include <rtems/score/cpu.h>
>>> +#include <rtems/score/interr.h>
>>> +#include <rtems/score/or1k-utility.h>
>>> +static inline void _CPU_OR1K_Cache_enable_data(void)
>>> +  uint32_t sr;
>>> +   ISR_Level level;
>>> +  _ISR_Disable (level);
>>> +  sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
>>> +  _ISR_Enable(level);
>>> +static inline void _CPU_OR1K_Cache_disable_data(void)
>>> +  uint32_t sr;
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_DCE));
>>> +static inline void _CPU_OR1K_Cache_enable_instruction(void)
>>> +  uint32_t sr;
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_ICE);
>>> +static inline void _CPU_OR1K_Cache_disable_instruction(void)
>>> +  uint32_t sr;
>>> +  ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_ICE));
>>> +static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
>>> +  ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
>>> +static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
>>> +static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
>>> +static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
>>> +static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
>>> +static inline void _CPU_OR1K_Cache_instruction_block_prefetch
>>> +(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
>>> +static inline void _CPU_OR1K_Cache_instruction_block_invalidate
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
>>> +static inline void _CPU_OR1K_Cache_instruction_block_lock
>>> +   ISR_Level level;
>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
>>> +/* Implement RTEMS cache manager functions */
>>> +void _CPU_cache_flush_1_data_line(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _CPU_OR1K_Cache_data_block_flush(d_addr);
>>> +  //asm volatile("l.csync");
>>> +void _CPU_cache_invalidate_1_data_line(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _CPU_OR1K_Cache_data_block_invalidate(d_addr);
>>> +void _CPU_cache_freeze_data(void)
>>> +  /* Do nothing */
>>> +void _CPU_cache_unfreeze_data(void)
>>> +  /* Do nothing */
>>> +void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
>>> +   ISR_Level level;
>>> +  _CPU_OR1K_Cache_instruction_block_invalidate(d_addr);
>>> +void _CPU_cache_freeze_instruction(void)
>>> +  /* Do nothing */
>>> +void _CPU_cache_unfreeze_instruction(void)
>>> +  /* Do nothing */
>>> +void _CPU_cache_flush_entire_data(void)
>>> +void _CPU_cache_invalidate_entire_data(void)
>>> +void _CPU_cache_invalidate_entire_instruction(void)
>>> +void _CPU_cache_enable_data(void)
>>> +  _CPU_OR1K_Cache_enable_data();
>>> +void _CPU_cache_disable_data(void)
>>> +  _CPU_OR1K_Cache_disable_data();
>>> +void _CPU_cache_enable_instruction(void)
>>> +  _CPU_OR1K_Cache_enable_instruction();
>>> +void _CPU_cache_disable_instruction(void)
>>> +  _CPU_OR1K_Cache_disable_instruction();
>>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>> index 08d9ecc..5f08410 100644
>>> --- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>> @@ -5,7 +5,7 @@
>>>  #ifndef __OR1K_CACHE_H
>>>  #define __OR1K_CACHE_H
>>> -#include <libcpu/cache.h>
>>> +#include <bsp/cache_.h>
>>>  #endif
>>>  /* end of include file */
>>> 1.9.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
