[PATCH] RTEMS: Update contrib/config-list.mk
Thu Sep 18 15:27:46 UTC 2014
On 9/18/2014 6:51 AM, Jan-Benedict Glaw wrote:
> On Wed, 2014-09-17 10:52:34 -0500, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> On 9/17/2014 10:41 AM, Sebastian Huber wrote:
>>> On 09/17/2014 04:45 PM, Jan-Benedict Glaw wrote:
>>>> On Wed, 2014-09-17 15:37:32 +0200, Sebastian Huber<sebastian.huber at embedded-brains.de>  wrote:
>>>>>> contrib/ChangeLog
>>>>>> 2014-09-17  Sebastian Huber<sebastian.huber at embedded-brains.de>
>>>>>> 	* config-list.mk (LIST): Add arm-rtems.
>>>>>> 	Add nios2-rtems.  Remove extra option from powerpc-rtems.
>>>> What's the rationale for removing --enable-threads=yes here, as well
>>>> as the specific version number?
>> And is this the input to your buildbot? :)
> Yes, the target list in contrib/config-list.mk is what'll be built
> using the config-list.mk-building backend. (The robot has another
> backend using a different build strategy, which has a separate target
> list, though one could argue that I'd also include all the
> config-list.mk targets in that other list as well.)
>   And to tell the whole story, Sebastian approached me with extending
> the target lists in use by those targets he sent a patch for; I just
> asked him to go this route, because I guess that'd be beneficial for
> other folks as well.
OK. Thanks for clarifying that. I suspected there was a link.
And it is committed.  And I will post a follow up patch to
add v850-elf and v850-rtems.
--joel
> MfG, JBG
