or1ksim: Updated results from RTEMS Tester
Sat Sep 20 04:44:46 UTC 2014
On 20/09/2014 12:56 am, Hesham Moustafa wrote:
> However, when I tested failures and timeouts separately, most of them
> work on QEMU, the others miss the trailing end-of-test line, which
> exists when I run them on or1ksim simulator.
How many cores do you have and what host OS ? I assume this is not on a VM.
The tester attempts to have a single test running on each core but the
effect this can have may vary from host to host. The --jobs option is
there to help.
