[PATCH] bsp:stm32f4XXXX system clock configuration
Sat Sep 20 18:41:25 UTC 2014
Style comments from me. I will let those who know who the HW comment on that.
On September 20, 2014 1:23:26 PM CDT, "tomasz.gregorek at gmail.com" <tomasz.gregorek at gmail.com> wrote:
>From: Tomasz Gregorek <tomasz.gregorek at gmail.com>
>Added simple math to caclulate register values for the PLL
>and for the prescalers. It will try to keep 48MHz for the USB OTG FS.
>Also it will slow down Flash memory for the high speeds.
> c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h     |  10 +
> .../libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h |  41 ++++
> .../libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h   |  94 +++++++++
>c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c    | 211
> 4 files changed, 356 insertions(+)
>create mode 100644
>c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
>diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
>b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
>index 59d13ef..d26f914 100644
>--- a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
>+++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
>@@ -55,6 +55,16 @@
>+ * @name STM32F4XXXX FLASH
>+#include <bsp/stm32f4xxxx_flash.h>
>+#define STM32F4_FLASH ((volatile stm32f4_flash *) (STM32F4_BASE +
>0x40023C00))
> #include <bsp/stm32_i2c.h>
>diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
>b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
>new file mode 100644
>index 0000000..31b3992
>--- /dev/null
>+++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
>@@ -0,0 +1,41 @@
>+ * @file
>+ * @ingroup stm32f4_flash
>+ * @brief STM32F4XXXX FLASH support.
>+ * Copyright (c) 2014 Tomasz Gregorek.  All rights reserved.
>+ *  <tomasz.gregorek at gmial.com>
>+ * The license and distribution terms for this file may be
>+ * found in the file LICENSE in this distribution or at
>+ * http://www.rtems.org/license/LICENSE.
>+#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
>+#define LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
>+#include <bsp/utility.h>
>+ * @defgroup stm32f10xxx_flash STM32F4XXXX FLASH Support
>+ * @brief STM32F4FXXX FLASH Support
>+typedef struct {
>+       uint32_t acr;
>+       uint32_t keyr;
>+       uint32_t optkeyr;
>+       uint32_t sr;
>+       uint32_t cr;
>+       uint32_t optcr;
>+       uint32_t optcr1;
>+} stm32f4_flash;
>+#endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H */
>diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
>b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
>index 8126340..ce85b8e 100644
>--- a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
>+++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
>@@ -56,4 +56,98 @@ typedef struct {
>+#define RCC_CR_HSION      BSP_BIT32(0)
>+#define RCC_CR_HSIRDY     BSP_BIT32(1)
>+#define RCC_CR_HSITRIM    3
>+#define RCC_CR_HSICAL     8
>+#define RCC_CR_HSEON      BSP_BIT32(16)
>+#define RCC_CR_HSERDY     BSP_BIT32(17)
>+#define RCC_CR_HSEBYP     BSP_BIT32(18)
>+#define RCC_CR_CSSON      BSP_BIT32(19)
>+#define RCC_CR_PLLON      BSP_BIT32(24)
>+#define RCC_CR_PLLRDY     BSP_BIT32(25)
>+#define RCC_CR_PLLI2SON   BSP_BIT32(26)
>+#define RCC_CR_PLLI2SRDY  BSP_BIT32(27)
>+#define RCC_PLLCFGR_PLLM    0
>+#define RCC_PLLCFGR_PLLN    6
>+#define RCC_PLLCFGR_PLLP    16
>+#define RCC_PLLCFGR_PLLSRC_HSE BSP_BIT32(22)
>+#define RCC_PLLCFGR_PLLSRC_HSI 0
>+#define RCC_PLLCFGR_PLLQ     24
>+#define RCC_CFGR_SW          0
>+#define RCC_CFGR_SW_MASK     3
>+#define RCC_CFGR_SW_HSI      0
>+#define RCC_CFGR_SW_HSE      1
>+#define RCC_CFGR_SW_PLL      2
>+#define RCC_CFGR_SWS         2
>+#define RCC_CFGR_SWS_MASK    (3 << RCC_CFGR_SWS)
>+#define RCC_CFGR_SWS_HSI     0
>+#define RCC_CFGR_SWS_HSE     (1 << RCC_CFGR_SWS)
>+#define RCC_CFGR_SWS_PLL     (2 << RCC_CFGR_SWS)
>+#define RCC_CFGR_HPRE        4
>+#define RCC_CFGR_HPRE_BY_1     0
>+#define RCC_CFGR_HPRE_BY_2   ( 8 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_HPRE_BY_4   ( 9 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_HPRE_BY_8   (10 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_HPRE_BY_16  (11 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_HPRE_BY_64  (12 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_HPRE_BY_128 (13 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_HPRE_BY_256 (14 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_HPRE_BY_512 (15 << RCC_CFGR_HPRE)
>+#define RCC_CFGR_PPRE1        10
>+#define RCC_CFGR_PPRE1_BY_1   0
>+#define RCC_CFGR_PPRE1_BY_2   (4 << RCC_CFGR_PPRE1)
>+#define RCC_CFGR_PPRE1_BY_4   (5 << RCC_CFGR_PPRE1)
>+#define RCC_CFGR_PPRE1_BY_8   (6 << RCC_CFGR_PPRE1)
>+#define RCC_CFGR_PPRE1_BY_16  (7 << RCC_CFGR_PPRE1)
>+#define RCC_CFGR_PPRE2        13
>+#define RCC_CFGR_PPRE2_BY_1   0
>+#define RCC_CFGR_PPRE2_BY_2   (4 << RCC_CFGR_PPRE2)
>+#define RCC_CFGR_PPRE2_BY_4   (5 << RCC_CFGR_PPRE2)
>+#define RCC_CFGR_PPRE2_BY_8   (6 << RCC_CFGR_PPRE2)
>+#define RCC_CFGR_PPRE2_BY_16  (7 << RCC_CFGR_PPRE2)
>+#define RCC_CFGR_RTCPRE       16
>+#define RCC_CFGR_RTCPRE_SET(a) (a << RCC_CFGR_RTCPRE)
>+#define RCC_CFGR_MCO1          21
>+#define RCC_CFGR_MCO1_HSI      0
>+#define RCC_CFGR_MCO1_LSE      (1 << RCC_CFGR_MCO1)
>+#define RCC_CFGR_MCO1_HSE      (2 << RCC_CFGR_MCO1)
>+#define RCC_CFGR_MCO1_PLL      (3 << RCC_CFGR_MCO1)
>+#define RCC_CFGR_I2SSRC         BSP_BIT32(23)
>+#define RCC_CFGR_MCO1PRE        24
>+#define RCC_CFGR_MCO1PRE_BY_1   0
>+#define RCC_CFGR_MCO1PRE_BY_2   (4 << RCC_CFGR_MCO1PRE)
>+#define RCC_CFGR_MCO1PRE_BY_3   (5 << RCC_CFGR_MCO1PRE)
>+#define RCC_CFGR_MCO1PRE_BY_4   (6 << RCC_CFGR_MCO1PRE)
>+#define RCC_CFGR_MCO1PRE_BY_5   (7 << RCC_CFGR_MCO1PRE)
>+#define RCC_CFGR_MCO2PRE        27
>+#define RCC_CFGR_MCO2PRE_BY_1   0
>+#define RCC_CFGR_MCO2PRE_BY_2   (4 << RCC_CFGR_MCO2PRE)
>+#define RCC_CFGR_MCO2PRE_BY_3   (5 << RCC_CFGR_MCO2PRE)
>+#define RCC_CFGR_MCO2PRE_BY_4   (6 << RCC_CFGR_MCO2PRE)
>+#define RCC_CFGR_MCO2PRE_BY_5   (7 << RCC_CFGR_MCO2PRE)
>+#define RCC_CFGR_MCO2           30
>+#define RCC_CFGR_MCO2_SYSCLK    0
>+#define RCC_CFGR_MCO2_PLLI2S    (1 << RCC_CFGR_MCO2)
>+#define RCC_CFGR_MCO2_HSE       (2 << RCC_CFGR_MCO2)
>+#define RCC_CFGR_MCO2_PLL       (3 << RCC_CFGR_MCO2)
> #endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_RCC_H */
>diff --git a/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
>b/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
>index d337d3a..31823d1 100644
>--- a/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
>+++ b/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
>@@ -17,9 +17,220 @@
> #include <bsp/irq.h>
> #include <bsp/bootcard.h>
> #include <bsp/irq-generic.h>
>+#include <bsp/stm32f4.h>
>+#include <bsp/stm32f4xxxx_rcc.h>
>+static rtems_status_code set_system_clk(uint32_t sysclk, uint32_t
>hseclk, uint32_t hseflag);
>+static void init_main_osc(void)
>+  volatile stm32f4_rcc *rcc = STM32F4_RCC;
>+  /* Revert to reset values */
>+  rcc->cr   |= RCC_CR_HSION; /* turn on HSI */
>+  while (! (rcc->cr & RCC_CR_HSIRDY) );
>+  rcc->cfgr &= 0x00000300; /* all prescalers to 0, clock source to HSI
>+  rcc->cr   &= 0xF0F0FFFD; /* turn off all clocks and PLL except HSI
>+  set_system_clk(STM32F4_SYSCLK / 1000000L, STM32F4_HSE_OSCILLATOR /
>1000000L, 1);
>+ * Sets up clocks configuration to achieve desired system clock
>+ * as close as possible with simple math
>+  volatile stm32f4_flash *flash = STM32F4_FLASH;
>+  rtems_interrupt_level level;
>+  long timeout = 0;
>+  const long timeoutset = 10000000L;
>+  int srcclk = 0;
>+  int pll_m = 0;
>+  int pll_n = 0;
>+  int pll_p = 0;
>+  int pll_q = 0;
>+  //int cr;
No C++ style comments and no commented out code without good reason.
>+  int ahbpre = 0;
>+  int apbpre1 = 0;
>+  int apbpre2 = 0;
>+  if (sysclk == 16) {
>+    rcc->cr   |= 0x00000001; /* turn on HSI */
>+    while (! (rcc->cr & (1 << RCC_CR_HSIRDY)) );
>HSI */
>+    flash->acr = 0; /* slow clock so no cache, no prefetch, no latency
>+    return RTEMS_SUCCESSFUL;
>+  if (hseclk == 0 || hseflag == 0) {
>+    srcclk = 16;
>+    hseflag = 0;
>+  else {
>+    srcclk = hseclk;
>+  if (sysclk > 180) {
>+    return RTEMS_INVALID_NUMBER;
>+  else if (sysclk > 96) {
>+    pll_n = sysclk; /* multpily by the desired speed in MHz */
>+    pll_p = 0; /* divide by 2 */
>+  else if (sysclk > 48) {
>+    pll_n = sysclk >> 1; /* multpily by 2x the desired speed in MHz */
>+    pll_p = 1; /* divide by 4 */
>+  else if (sysclk > 24) {
>+    pll_n = sysclk >> 2; /* multpily by 4x the desired speed in MHz */
>+    pll_p = 3; /* divide by 8 */
>+  else {
>+   * Lets use 1MHz input for PLL so we get higher VCO output
>+   * this way we get better value for the PLL_Q divader for the USB
>+   * Though you might want to use 2MHz as per CPU specification:
>+   * Caution:The software has to set these bits correctly to ensure
>+   * that the VCO input frequency ranges from 1 to 2 MHz.
>+   * It is recommended to select a frequency of 2 MHz to limit PLL
>jitter.
>+  pll_m = srcclk; /* divide by the oscilator speed in MHz */
>+  pll_n <<= 1; /* multiply by requested clock x2 */
>+  /* pll_q is a prescaler from VCO for the USB OTG FS, SDIO and RNG,
>+   * should result in the 48MHz for the USB
>+  pll_q = ((long)(srcclk * pll_n + srcclk * pll_n / 2)) / pll_m / 48;
>+  if (pll_q < 2)
>+    pll_q = 2;
Pull the { up.
>+  /* APB1 prescaler, APB1 clock must be < 42MHz */
>+  apbpre1 = (sysclk * 100) / 42;
>+  if (apbpre1 <= 100) {
>+    apbpre1 = RCC_CFGR_PPRE1_BY_1;
>+  else if (apbpre1 <= 200) {
>+    apbpre1 = RCC_CFGR_PPRE1_BY_2;
>+  else if (apbpre1 <= 400) {
>+    apbpre1 = RCC_CFGR_PPRE1_BY_4;
>+  else if (apbpre1 <= 800) {
>+    apbpre1 = RCC_CFGR_PPRE1_BY_8;
>+  else if (apbpre1) {
>+    apbpre1 = RCC_CFGR_PPRE1_BY_16;
>+  /* APB2 prescaler, APB2 clock must be < 84MHz */
>+  apbpre2 = (sysclk * 100) / 84;
>+  if (apbpre2 <= 100) {
>+    apbpre2 = RCC_CFGR_PPRE2_BY_1;
>+  else if (apbpre2 <= 200) {
>+    apbpre2 = RCC_CFGR_PPRE2_BY_2;
>+  else if (apbpre2 <= 400) {
>+    apbpre2 = RCC_CFGR_PPRE2_BY_4;
>+  else if (apbpre2 <= 800) {
>+    apbpre2 = RCC_CFGR_PPRE2_BY_8;
>+  else {
>+    apbpre2 = RCC_CFGR_PPRE2_BY_16;
I thought RTEMS style had } else and } else if. Is that right?
If so adjust style.
>+  rtems_interrupt_disable(level);
>+  timeout = timeoutset;
>+  while ((! (rcc->cr & RCC_CR_HSIRDY) ) && timeout--);
>+  if (timeout == 0) while(1);
>+  /* all prescalers to 0, clock source to HSI */
>+  rcc->cfgr |= RCC_CFGR_SW_HSI;
>+  while ( ( (rcc->cfgr & RCC_CFGR_SWS_MASK) != RCC_CFGR_SWS_HSI ) &&
>--timeout );
>+  /* turn off PLL */
>+  rcc->cr   &= ~ (RCC_CR_PLLON | RCC_CR_PLLRDY);
>+  if (hseflag) {
>+    rcc->cr |= RCC_CR_HSEON;
>+    while ((! (rcc->cr & RCC_CR_HSERDY) ) && timeout--);
>+  rcc->pllcfgr &= 0xF0BC8000; /* clear PLL prescalers */
>+  /* set pll parameters */
>+  rcc->pllcfgr |=(pll_m << RCC_PLLCFGR_PLLM)  // input divider
>+               | (pll_n << RCC_PLLCFGR_PLLN)  // multiplier
>+               | (pll_p << RCC_PLLCFGR_PLLP)  // output divider from
>table
>+                                              // HSE v HSI
>+               | (hseflag ? RCC_PLLCFGR_PLLSRC_HSE :
>RCC_PLLCFGR_PLLSRC_HSI)
>+               | (pll_q << RCC_PLLCFGR_PLLQ); // PLLQ
>+  /* set prescalers for the internal busses */
>+  rcc->cfgr    |= apbpre1
>+               |  apbpre2
>+               |  ahbpre;
>+  /* set flash parameters, hard coded for now for fast system clocks
>+  flash->acr  |= 5        // latency
>+              | (1 << 9)  // instruction cache
>+              | (1 << 10);// data cache
>+  /* turn on PLL */
>+  rcc->cr   |= RCC_CR_PLLON;
>+  while ( (! (rcc->cr & RCC_CR_PLLRDY) ) && --timeout );
>+  /* clock source to PLL */
>+  rcc->cfgr = (rcc->cfgr & ~RCC_CFGR_SW_MASK) | RCC_CFGR_SW_PLL;
>+  while ( ((rcc->cfgr & RCC_CFGR_SWS_MASK) != RCC_CFGR_SWS_PLL) &&
>--timeout );
>+  //if (timeout == 0) while(1);
>+  rtems_interrupt_enable(level);
> void bsp_start(void)
>+  init_main_osc();
>   stm32f4_gpio_set_config_array(&stm32f4_start_config_gpio [0]);
>   bsp_interrupt_initialize();
>2.1.0
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
