[PATCH] bsp:stm32f4XXXX system clock configuration
Tomasz Gregorek
tomasz.gregorek at gmail.com
Sun Sep 21 16:13:30 UTC 2014
There are not only styles to be corrected. I will send a new version soon.
2014-09-20 20:41 GMT+02:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> Style comments from me. I will let those who know who the HW comment on
> that.
> On September 20, 2014 1:23:26 PM CDT, "tomasz.gregorek at gmail.com" <
> tomasz.gregorek at gmail.com> wrote:
> >From: Tomasz Gregorek <tomasz.gregorek at gmail.com>
> >Added simple math to caclulate register values for the PLL
> >and for the prescalers. It will try to keep 48MHz for the USB OTG FS.
> >Also it will slow down Flash memory for the high speeds.
> > c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h | 10 +
> > .../libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h | 41 ++++
> > .../libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h | 94 +++++++++
> >c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c | 211
> > 4 files changed, 356 insertions(+)
> >create mode 100644
> >c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> >diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> >b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> >index 59d13ef..d26f914 100644
> >--- a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> >+++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> >@@ -55,6 +55,16 @@
> >+ * @name STM32F4XXXX FLASH
> >+#include <bsp/stm32f4xxxx_flash.h>
> >+#define STM32F4_FLASH ((volatile stm32f4_flash *) (STM32F4_BASE +
> >0x40023C00))
> > #include <bsp/stm32_i2c.h>
> >diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> >b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> >new file mode 100644
> >index 0000000..31b3992
> >--- /dev/null
> >+++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> >@@ -0,0 +1,41 @@
> >+ * @file
> >+ * @ingroup stm32f4_flash
> >+ * @brief STM32F4XXXX FLASH support.
> >+ * Copyright (c) 2014 Tomasz Gregorek. All rights reserved.
> >+ * <tomasz.gregorek at gmial.com>
> >+ * The license and distribution terms for this file may be
> >+ * found in the file LICENSE in this distribution or at
> >+ * http://www.rtems.org/license/LICENSE.
> >+#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
> >+#define LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
> >+#include <bsp/utility.h>
> >+ * @defgroup stm32f10xxx_flash STM32F4XXXX FLASH Support
> >+ * @brief STM32F4FXXX FLASH Support
> >+typedef struct {
> >+ uint32_t acr;
> >+ uint32_t keyr;
> >+ uint32_t optkeyr;
> >+ uint32_t sr;
> >+ uint32_t cr;
> >+ uint32_t optcr;
> >+ uint32_t optcr1;
> >+} stm32f4_flash;
> >+#endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H */
> >diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> >b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> >index 8126340..ce85b8e 100644
> >--- a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> >+++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> >@@ -56,4 +56,98 @@ typedef struct {
> >+#define RCC_CR_HSION BSP_BIT32(0)
> >+#define RCC_CR_HSIRDY BSP_BIT32(1)
> >+#define RCC_CR_HSITRIM 3
> >+#define RCC_CR_HSICAL 8
> >+#define RCC_CR_HSEON BSP_BIT32(16)
> >+#define RCC_CR_HSERDY BSP_BIT32(17)
> >+#define RCC_CR_HSEBYP BSP_BIT32(18)
> >+#define RCC_CR_CSSON BSP_BIT32(19)
> >+#define RCC_CR_PLLON BSP_BIT32(24)
> >+#define RCC_CR_PLLRDY BSP_BIT32(25)
> >+#define RCC_CR_PLLI2SON BSP_BIT32(26)
> >+#define RCC_CR_PLLI2SRDY BSP_BIT32(27)
> >+#define RCC_PLLCFGR_PLLM 0
> >+#define RCC_PLLCFGR_PLLN 6
> >+#define RCC_PLLCFGR_PLLP 16
> >+#define RCC_PLLCFGR_PLLSRC_HSE BSP_BIT32(22)
> >+#define RCC_PLLCFGR_PLLSRC_HSI 0
> >+#define RCC_PLLCFGR_PLLQ 24
> >+#define RCC_CFGR_SW 0
> >+#define RCC_CFGR_SW_MASK 3
> >+#define RCC_CFGR_SW_HSI 0
> >+#define RCC_CFGR_SW_HSE 1
> >+#define RCC_CFGR_SW_PLL 2
> >+#define RCC_CFGR_SWS 2
> >+#define RCC_CFGR_SWS_MASK (3 << RCC_CFGR_SWS)
> >+#define RCC_CFGR_SWS_HSI 0
> >+#define RCC_CFGR_SWS_HSE (1 << RCC_CFGR_SWS)
> >+#define RCC_CFGR_SWS_PLL (2 << RCC_CFGR_SWS)
> >+#define RCC_CFGR_HPRE 4
> >+#define RCC_CFGR_HPRE_BY_1 0
> >+#define RCC_CFGR_HPRE_BY_2 ( 8 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_HPRE_BY_4 ( 9 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_HPRE_BY_8 (10 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_HPRE_BY_16 (11 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_HPRE_BY_64 (12 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_HPRE_BY_128 (13 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_HPRE_BY_256 (14 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_HPRE_BY_512 (15 << RCC_CFGR_HPRE)
> >+#define RCC_CFGR_PPRE1 10
> >+#define RCC_CFGR_PPRE1_BY_1 0
> >+#define RCC_CFGR_PPRE1_BY_2 (4 << RCC_CFGR_PPRE1)
> >+#define RCC_CFGR_PPRE1_BY_4 (5 << RCC_CFGR_PPRE1)
> >+#define RCC_CFGR_PPRE1_BY_8 (6 << RCC_CFGR_PPRE1)
> >+#define RCC_CFGR_PPRE1_BY_16 (7 << RCC_CFGR_PPRE1)
> >+#define RCC_CFGR_PPRE2 13
> >+#define RCC_CFGR_PPRE2_BY_1 0
> >+#define RCC_CFGR_PPRE2_BY_2 (4 << RCC_CFGR_PPRE2)
> >+#define RCC_CFGR_PPRE2_BY_4 (5 << RCC_CFGR_PPRE2)
> >+#define RCC_CFGR_PPRE2_BY_8 (6 << RCC_CFGR_PPRE2)
> >+#define RCC_CFGR_PPRE2_BY_16 (7 << RCC_CFGR_PPRE2)
> >+#define RCC_CFGR_RTCPRE 16
> >+#define RCC_CFGR_RTCPRE_SET(a) (a << RCC_CFGR_RTCPRE)
> >+#define RCC_CFGR_MCO1 21
> >+#define RCC_CFGR_MCO1_HSI 0
> >+#define RCC_CFGR_MCO1_LSE (1 << RCC_CFGR_MCO1)
> >+#define RCC_CFGR_MCO1_HSE (2 << RCC_CFGR_MCO1)
> >+#define RCC_CFGR_MCO1_PLL (3 << RCC_CFGR_MCO1)
> >+#define RCC_CFGR_I2SSRC BSP_BIT32(23)
> >+#define RCC_CFGR_MCO1PRE 24
> >+#define RCC_CFGR_MCO1PRE_BY_1 0
> >+#define RCC_CFGR_MCO1PRE_BY_2 (4 << RCC_CFGR_MCO1PRE)
> >+#define RCC_CFGR_MCO1PRE_BY_3 (5 << RCC_CFGR_MCO1PRE)
> >+#define RCC_CFGR_MCO1PRE_BY_4 (6 << RCC_CFGR_MCO1PRE)
> >+#define RCC_CFGR_MCO1PRE_BY_5 (7 << RCC_CFGR_MCO1PRE)
> >+#define RCC_CFGR_MCO2PRE 27
> >+#define RCC_CFGR_MCO2PRE_BY_1 0
> >+#define RCC_CFGR_MCO2PRE_BY_2 (4 << RCC_CFGR_MCO2PRE)
> >+#define RCC_CFGR_MCO2PRE_BY_3 (5 << RCC_CFGR_MCO2PRE)
> >+#define RCC_CFGR_MCO2PRE_BY_4 (6 << RCC_CFGR_MCO2PRE)
> >+#define RCC_CFGR_MCO2PRE_BY_5 (7 << RCC_CFGR_MCO2PRE)
> >+#define RCC_CFGR_MCO2 30
> >+#define RCC_CFGR_MCO2_SYSCLK 0
> >+#define RCC_CFGR_MCO2_PLLI2S (1 << RCC_CFGR_MCO2)
> >+#define RCC_CFGR_MCO2_HSE (2 << RCC_CFGR_MCO2)
> >+#define RCC_CFGR_MCO2_PLL (3 << RCC_CFGR_MCO2)
> > #endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_RCC_H */
> >diff --git a/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> >b/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> >index d337d3a..31823d1 100644
> >--- a/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> >+++ b/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> >@@ -17,9 +17,220 @@
> > #include <bsp/irq.h>
> > #include <bsp/bootcard.h>
> > #include <bsp/irq-generic.h>
> >+#include <bsp/stm32f4.h>
> >+#include <bsp/stm32f4xxxx_rcc.h>
> >+static rtems_status_code set_system_clk(uint32_t sysclk, uint32_t
> >hseclk, uint32_t hseflag);
> >+static void init_main_osc(void)
> >+ volatile stm32f4_rcc *rcc = STM32F4_RCC;
> >+ /* Revert to reset values */
> >+ rcc->cr |= RCC_CR_HSION; /* turn on HSI */
> >+ while (! (rcc->cr & RCC_CR_HSIRDY) );
> >+ rcc->cfgr &= 0x00000300; /* all prescalers to 0, clock source to HSI
> >+ rcc->cr &= 0xF0F0FFFD; /* turn off all clocks and PLL except HSI
> >+ set_system_clk(STM32F4_SYSCLK / 1000000L, STM32F4_HSE_OSCILLATOR /
> >1000000L, 1);
> >+ * Sets up clocks configuration to achieve desired system clock
> >+ * as close as possible with simple math
> >+ volatile stm32f4_flash *flash = STM32F4_FLASH;
> >+ rtems_interrupt_level level;
> >+ long timeout = 0;
> >+ const long timeoutset = 10000000L;
> >+ int srcclk = 0;
> >+ int pll_m = 0;
> >+ int pll_n = 0;
> >+ int pll_p = 0;
> >+ int pll_q = 0;
> >+ //int cr;
> No C++ style comments and no commented out code without good reason.
> >+ int ahbpre = 0;
> >+ int apbpre1 = 0;
> >+ int apbpre2 = 0;
> >+ if (sysclk == 16) {
> >+ rcc->cr |= 0x00000001; /* turn on HSI */
> >+ while (! (rcc->cr & (1 << RCC_CR_HSIRDY)) );
> >HSI */
> >+ flash->acr = 0; /* slow clock so no cache, no prefetch, no latency
> >+ return RTEMS_SUCCESSFUL;
> >+ if (hseclk == 0 || hseflag == 0) {
> >+ srcclk = 16;
> >+ hseflag = 0;
> >+ else {
> >+ srcclk = hseclk;
> >+ if (sysclk > 180) {
> >+ return RTEMS_INVALID_NUMBER;
> >+ else if (sysclk > 96) {
> >+ pll_n = sysclk; /* multpily by the desired speed in MHz */
> >+ pll_p = 0; /* divide by 2 */
> >+ else if (sysclk > 48) {
> >+ pll_n = sysclk >> 1; /* multpily by 2x the desired speed in MHz */
> >+ pll_p = 1; /* divide by 4 */
> >+ else if (sysclk > 24) {
> >+ pll_n = sysclk >> 2; /* multpily by 4x the desired speed in MHz */
> >+ pll_p = 3; /* divide by 8 */
> >+ else {
> >+ * Lets use 1MHz input for PLL so we get higher VCO output
> >+ * this way we get better value for the PLL_Q divader for the USB
> >+ * Though you might want to use 2MHz as per CPU specification:
> >+ * Caution:The software has to set these bits correctly to ensure
> >+ * that the VCO input frequency ranges from 1 to 2 MHz.
> >+ * It is recommended to select a frequency of 2 MHz to limit PLL
> >jitter.
> >+ pll_m = srcclk; /* divide by the oscilator speed in MHz */
> >+ pll_n <<= 1; /* multiply by requested clock x2 */
> >+ /* pll_q is a prescaler from VCO for the USB OTG FS, SDIO and RNG,
> >+ * should result in the 48MHz for the USB
> >+ pll_q = ((long)(srcclk * pll_n + srcclk * pll_n / 2)) / pll_m / 48;
> >+ if (pll_q < 2)
> >+ pll_q = 2;
> Pull the { up.
> >+ /* APB1 prescaler, APB1 clock must be < 42MHz */
> >+ apbpre1 = (sysclk * 100) / 42;
> >+ if (apbpre1 <= 100) {
> >+ apbpre1 = RCC_CFGR_PPRE1_BY_1;
> >+ else if (apbpre1 <= 200) {
> >+ apbpre1 = RCC_CFGR_PPRE1_BY_2;
> >+ else if (apbpre1 <= 400) {
> >+ apbpre1 = RCC_CFGR_PPRE1_BY_4;
> >+ else if (apbpre1 <= 800) {
> >+ apbpre1 = RCC_CFGR_PPRE1_BY_8;
> >+ else if (apbpre1) {
> >+ apbpre1 = RCC_CFGR_PPRE1_BY_16;
> >+ /* APB2 prescaler, APB2 clock must be < 84MHz */
> >+ apbpre2 = (sysclk * 100) / 84;
> >+ if (apbpre2 <= 100) {
> >+ apbpre2 = RCC_CFGR_PPRE2_BY_1;
> >+ else if (apbpre2 <= 200) {
> >+ apbpre2 = RCC_CFGR_PPRE2_BY_2;
> >+ else if (apbpre2 <= 400) {
> >+ apbpre2 = RCC_CFGR_PPRE2_BY_4;
> >+ else if (apbpre2 <= 800) {
> >+ apbpre2 = RCC_CFGR_PPRE2_BY_8;
> >+ else {
> >+ apbpre2 = RCC_CFGR_PPRE2_BY_16;
> I thought RTEMS style had } else and } else if. Is that right?
> If so adjust style.
> >+ rtems_interrupt_disable(level);
> >+ timeout = timeoutset;
> >+ while ((! (rcc->cr & RCC_CR_HSIRDY) ) && timeout--);
> >+ if (timeout == 0) while(1);
> >+ /* all prescalers to 0, clock source to HSI */
> >+ rcc->cfgr |= RCC_CFGR_SW_HSI;
> >+ while ( ( (rcc->cfgr & RCC_CFGR_SWS_MASK) != RCC_CFGR_SWS_HSI ) &&
> >--timeout );
> >+ /* turn off PLL */
> >+ rcc->cr &= ~ (RCC_CR_PLLON | RCC_CR_PLLRDY);
> >+ if (hseflag) {
> >+ rcc->cr |= RCC_CR_HSEON;
> >+ while ((! (rcc->cr & RCC_CR_HSERDY) ) && timeout--);
> >+ rcc->pllcfgr &= 0xF0BC8000; /* clear PLL prescalers */
> >+ /* set pll parameters */
> >+ rcc->pllcfgr |=(pll_m << RCC_PLLCFGR_PLLM) // input divider
> >+ | (pll_n << RCC_PLLCFGR_PLLN) // multiplier
> >+ | (pll_p << RCC_PLLCFGR_PLLP) // output divider from
> >table
> >+ // HSE v HSI
> >+ | (hseflag ? RCC_PLLCFGR_PLLSRC_HSE :
> >RCC_PLLCFGR_PLLSRC_HSI)
> >+ | (pll_q << RCC_PLLCFGR_PLLQ); // PLLQ
> >+ /* set prescalers for the internal busses */
> >+ rcc->cfgr |= apbpre1
> >+ | apbpre2
> >+ | ahbpre;
> >+ /* set flash parameters, hard coded for now for fast system clocks
> >+ flash->acr |= 5 // latency
> >+ | (1 << 9) // instruction cache
> >+ | (1 << 10);// data cache
> >+ /* turn on PLL */
> >+ rcc->cr |= RCC_CR_PLLON;
> >+ while ( (! (rcc->cr & RCC_CR_PLLRDY) ) && --timeout );
> >+ /* clock source to PLL */
> >+ rcc->cfgr = (rcc->cfgr & ~RCC_CFGR_SW_MASK) | RCC_CFGR_SW_PLL;
> >+ while ( ((rcc->cfgr & RCC_CFGR_SWS_MASK) != RCC_CFGR_SWS_PLL) &&
> >--timeout );
> >+ //if (timeout == 0) while(1);
> >+ rtems_interrupt_enable(level);
> > void bsp_start(void)
> >+ init_main_osc();
> > stm32f4_gpio_set_config_array(&stm32f4_start_config_gpio [0]);
> > bsp_interrupt_initialize();
> >2.1.0
> >_______________________________________________
> >devel mailing list
> >devel at rtems.org
> >http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140921/a31e4538/attachment-0001.html>
