BSP specific settings
Tue Sep 30 14:45:39 UTC 2014
Hello Daniel,
On 30/09/14 16:30, Daniel Cederman wrote:
> I would like to add a way for the user of the leon3 bsp to specify the irq that
> should be used for IPIs. Is it adding an option to configure.ac for the bsp
> that is the recommended way? Or does there exist a supported way of setting bsp
> specific parameters similar to how it is done with confdefs.h? So that the
> kernel does not need to be recompiled to change it?
if you are happy with a build time option, then the BSP options in the
configure.ac are the standard way to do this.  I don't think we want this for
the LEON3 BSPs.
If you need a link time option, then there is no standard way to do this on the
BSP level.  Most BSPs use some sort of weak tables or functions.  The LEON3 BSP
already uses such a thing for debug_uart_index for example.  The
a9mpcore_clock_periphclk() function is another example on ARM.  If you use
this, then I would place it in bsp.h and add an appropriate comment.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
