BSP specific settings
Daniel Cederman cederman at gaisler.com
Tue Sep 30 14:57:54 UTC 2014
On 2014-09-30 16:45, Sebastian Huber wrote:
> If you need a link time option, then there is no standard way to do this
> on the BSP level.  Most BSPs use some sort of weak tables or functions.
> The LEON3 BSP already uses such a thing for debug_uart_index for
> example.
Ok, then I'll do something similar for this.
> The a9mpcore_clock_periphclk() function is another example on
> ARM.  If you use this, then I would place it in bsp.h and add an
> appropriate comment.
Will do. Thank you for your help and quick reply!
/Daniel C
