[PATCH] score: Add Watchdog_Header
Fri Apr 10 14:19:48 UTC 2015
This type is intended to encapsulate all state to manage a watchdog
chain.
Update #2307.
 cpukit/rtems/include/rtems/rtems/timerimpl.h    |  5 +-
 cpukit/rtems/src/timerreset.c                   |  2 +-
 cpukit/rtems/src/timerserver.c                  | 37 +++++++--------
 cpukit/score/include/rtems/score/watchdogimpl.h | 62 +++++++++++++++++--------
 cpukit/score/src/coretodset.c                   |  4 +-
 cpukit/score/src/watchdog.c                     |  6 +--
 cpukit/score/src/watchdogadjust.c               |  8 ++--
 cpukit/score/src/watchdogadjusttochain.c        | 13 +++---
 cpukit/score/src/watchdoginsert.c               |  6 +--
 cpukit/score/src/watchdogtickle.c               |  9 ++--
 testsuites/sptests/spintrcritical08/init.c      |  6 +--
 testsuites/sptests/spintrcritical09/init.c      |  6 +--
 testsuites/sptests/spsize/size.c                |  4 +-
 13 files changed, 94 insertions(+), 74 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/timerimpl.h b/cpukit/rtems/include/rtems/rtems/timerimpl.h
index 667a86a..b695d5e 100644
--- a/cpukit/rtems/include/rtems/rtems/timerimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/timerimpl.h
@@ -21,6 +21,7 @@
 #include <rtems/rtems/timer.h>
+#include <rtems/score/watchdogimpl.h>
 #ifdef __cplusplus
 extern "C" {
@@ -64,9 +65,9 @@ typedef struct {
   Watchdog_Control System_watchdog;
-   * @brief Chain for watchdogs which will be triggered by the timer server.
+   * @brief Watchdog header managed by the timer server.
-  Chain_Control Chain;
+  Watchdog_Header Header;
    * @brief Last known time snapshot of the timer server.
diff --git a/cpukit/rtems/src/timerreset.c b/cpukit/rtems/src/timerreset.c
index 8afb7ab..495780a 100644
--- a/cpukit/rtems/src/timerreset.c
+++ b/cpukit/rtems/src/timerreset.c
@@ -52,7 +52,7 @@ rtems_status_code rtems_timer_reset(
     case OBJECTS_LOCAL:
       if ( the_timer->the_class == TIMER_INTERVAL ) {
         _Watchdog_Remove( &the_timer->Ticker );
-        _Watchdog_Insert( &_Watchdog_Ticks_chain, &the_timer->Ticker );
+        _Watchdog_Insert( &_Watchdog_Ticks_header, &the_timer->Ticker );
       } else if ( the_timer->the_class == TIMER_INTERVAL_ON_TASK ) {
         Timer_server_Control *timer_server = _Timer_server;
diff --git a/cpukit/rtems/src/timerserver.c b/cpukit/rtems/src/timerserver.c
index 00f29cc..25191e4 100644
--- a/cpukit/rtems/src/timerserver.c
+++ b/cpukit/rtems/src/timerserver.c
@@ -31,7 +31,6 @@
 #include <rtems/score/isrlevel.h>
-#include <rtems/score/watchdogimpl.h>
 static Timer_server_Control _Timer_server_Default;
@@ -51,9 +50,9 @@ static void _Timer_server_Reset_interval_system_watchdog(
   _Timer_server_Stop_interval_system_watchdog( ts );
   _ISR_Disable( level );
-  if ( !_Chain_Is_empty( &ts->Interval_watchdogs.Chain ) ) {
+  if ( !_Watchdog_Is_empty( &ts->Interval_watchdogs.Header ) ) {
     Watchdog_Interval delta_interval =
-      _Watchdog_First( &ts->Interval_watchdogs.Chain )->delta_interval;
+      _Watchdog_First( &ts->Interval_watchdogs.Header )->delta_interval;
     _ISR_Enable( level );
@@ -84,9 +83,9 @@ static void _Timer_server_Reset_tod_system_watchdog(
   _Timer_server_Stop_tod_system_watchdog( ts );
-  if ( !_Chain_Is_empty( &ts->TOD_watchdogs.Chain ) ) {
+  if ( !_Watchdog_Is_empty( &ts->TOD_watchdogs.Header ) ) {
-      _Watchdog_First( &ts->TOD_watchdogs.Chain )->delta_interval;
+      _Watchdog_First( &ts->TOD_watchdogs.Header )->delta_interval;
@@ -107,9 +106,9 @@ static void _Timer_server_Insert_timer(
   if ( timer->the_class == TIMER_INTERVAL_ON_TASK ) {
-    _Watchdog_Insert( &ts->Interval_watchdogs.Chain, &timer->Ticker );
+    _Watchdog_Insert( &ts->Interval_watchdogs.Header, &timer->Ticker );
   } else if ( timer->the_class == TIMER_TIME_OF_DAY_ON_TASK ) {
-    _Watchdog_Insert( &ts->TOD_watchdogs.Chain, &timer->Ticker );
+    _Watchdog_Insert( &ts->TOD_watchdogs.Header, &timer->Ticker );
@@ -144,8 +143,8 @@ static void _Timer_server_Insert_timer_and_make_snapshot(
     snapshot = _Watchdog_Ticks_since_boot;
     last_snapshot = ts->Interval_watchdogs.last_snapshot;
-      first_watchdog = _Watchdog_First( &ts->Interval_watchdogs.Chain );
+      first_watchdog = _Watchdog_First( &ts->Interval_watchdogs.Header );
        *  We assume adequate unsigned arithmetic here.
@@ -163,7 +162,7 @@ static void _Timer_server_Insert_timer_and_make_snapshot(
     ts->Interval_watchdogs.last_snapshot = snapshot;
     if ( !ts->active ) {
       _Timer_server_Reset_interval_system_watchdog( ts );
@@ -176,8 +175,8 @@ static void _Timer_server_Insert_timer_and_make_snapshot(
     snapshot = (Watchdog_Interval) _TOD_Seconds_since_epoch();
     last_snapshot = ts->TOD_watchdogs.last_snapshot;
-      first_watchdog = _Watchdog_First( &ts->TOD_watchdogs.Chain );
+      first_watchdog = _Watchdog_First( &ts->TOD_watchdogs.Header );
       delta_interval = first_watchdog->delta_interval;
       if ( snapshot > last_snapshot ) {
@@ -201,7 +200,7 @@ static void _Timer_server_Insert_timer_and_make_snapshot(
     ts->TOD_watchdogs.last_snapshot = snapshot;
       _Timer_server_Reset_tod_system_watchdog( ts );
@@ -244,7 +243,7 @@ static void _Timer_server_Process_interval_watchdogs(
   watchdogs->last_snapshot = snapshot;
-  _Watchdog_Adjust_to_chain( &watchdogs->Chain, delta, fire_chain );
+  _Watchdog_Adjust_to_chain( &watchdogs->Header, delta, fire_chain );
 static void _Timer_server_Process_tod_watchdogs(
@@ -259,7 +258,7 @@ static void _Timer_server_Process_tod_watchdogs(
    *  Process the seconds chain.  Start by checking that the Time
    *  of Day (TOD) has not been set backwards.  If it has then
-   *  we want to adjust the watchdogs->Chain to indicate this.
+   *  we want to adjust the watchdogs->Header to indicate this.
@@ -267,7 +266,7 @@ static void _Timer_server_Process_tod_watchdogs(
      *  TOD has been set forward.
     delta = snapshot - last_snapshot;
   } else if ( snapshot < last_snapshot ) {
@@ -275,7 +274,7 @@ static void _Timer_server_Process_tod_watchdogs(
       *  TOD has been set backwards.
      delta = last_snapshot - snapshot;
-     _Watchdog_Adjust_backward( &watchdogs->Chain, delta );
+     _Watchdog_Adjust_backward( &watchdogs->Header, delta );
@@ -543,8 +542,8 @@ rtems_status_code rtems_timer_initiate_server(
    *  Initialize the timer lists that the server will manage.
-  _Chain_Initialize_empty( &ts->Interval_watchdogs.Chain );
-  _Chain_Initialize_empty( &ts->TOD_watchdogs.Chain );
+  _Watchdog_Header_initialize( &ts->Interval_watchdogs.Header );
+  _Watchdog_Header_initialize( &ts->TOD_watchdogs.Header );
    *  Initialize the timers that will be used to control when the
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index 9eb0951..8408fd0 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -53,6 +53,16 @@ extern "C" {
+ * @brief Watchdog header.
+typedef struct {
+   * @brief The chain of active or transient watchdogs.
+  Chain_Control Chain;
+} Watchdog_Header;
  *  @brief Watchdog synchronization level.
  *  This used for synchronization purposes
@@ -73,14 +83,14 @@ SCORE_EXTERN volatile uint32_t    _Watchdog_Sync_count;
  *  This is the watchdog chain which is managed at ticks.
-SCORE_EXTERN Chain_Control _Watchdog_Ticks_chain;
+SCORE_EXTERN Watchdog_Header _Watchdog_Ticks_header;
  *  @brief Watchdog chain which is managed at second boundaries.
  *  This is the watchdog chain which is managed at second boundaries.
-SCORE_EXTERN Chain_Control _Watchdog_Seconds_chain;
+SCORE_EXTERN Watchdog_Header _Watchdog_Seconds_header;
  *  @brief Initialize the watchdog handler.
@@ -112,7 +122,7 @@ Watchdog_States _Watchdog_Remove (
  *  @param[in] units The units of ticks to adjust.
 void _Watchdog_Adjust_backward(
-  Chain_Control     *header,
+  Watchdog_Header   *header,
   Watchdog_Interval  units
@@ -126,7 +136,7 @@ void _Watchdog_Adjust_backward(
 void _Watchdog_Adjust_forward(
@@ -145,9 +155,9 @@ void _Watchdog_Adjust_forward(
  *  @note This always adjusts forward.
 void _Watchdog_Adjust_to_chain(
-  Watchdog_Interval            units_arg,
-  Chain_Control               *to_fire
+  Watchdog_Interval  units_arg,
+  Chain_Control     *to_fire
@@ -163,8 +173,8 @@ void _Watchdog_Adjust_to_chain(
  *  @param[in] the_watchdog is the watchdog to insert
 void _Watchdog_Insert (
-  Watchdog_Control      *the_watchdog
+  Watchdog_Control *the_watchdog
@@ -178,7 +188,7 @@ void _Watchdog_Insert (
  *  @param[in] header is the watchdog chain to tickle
 void _Watchdog_Tickle (
@@ -250,7 +260,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Deactivate(
 RTEMS_INLINE_ROUTINE void _Watchdog_Tickle_ticks( void )
-  _Watchdog_Tickle( &_Watchdog_Ticks_chain );
+  _Watchdog_Tickle( &_Watchdog_Ticks_header );
@@ -262,7 +272,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Tickle_ticks( void )
 RTEMS_INLINE_ROUTINE void _Watchdog_Tickle_seconds( void )
-  _Watchdog_Tickle( &_Watchdog_Seconds_chain );
+  _Watchdog_Tickle( &_Watchdog_Seconds_header );
@@ -281,7 +291,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Insert_ticks(
   the_watchdog->initial = units;
-  _Watchdog_Insert( &_Watchdog_Ticks_chain, the_watchdog );
+  _Watchdog_Insert( &_Watchdog_Ticks_header, the_watchdog );
@@ -300,7 +310,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Insert_seconds(
-  _Watchdog_Insert( &_Watchdog_Seconds_chain, the_watchdog );
+  _Watchdog_Insert( &_Watchdog_Seconds_header, the_watchdog );
@@ -318,7 +328,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Reset(
   (void) _Watchdog_Remove( the_watchdog );
@@ -356,11 +366,11 @@ RTEMS_INLINE_ROUTINE Watchdog_Control *_Watchdog_Previous(
 RTEMS_INLINE_ROUTINE Watchdog_Control *_Watchdog_First(
-  return ( (Watchdog_Control *) _Chain_First( header ) );
+  return ( (Watchdog_Control *) _Chain_First( &header->Chain ) );
@@ -370,12 +380,26 @@ RTEMS_INLINE_ROUTINE Watchdog_Control *_Watchdog_First(
 RTEMS_INLINE_ROUTINE Watchdog_Control *_Watchdog_Last(
-  return ( (Watchdog_Control *) _Chain_Last( header ) );
+  return ( (Watchdog_Control *) _Chain_Last( &header->Chain ) );
+RTEMS_INLINE_ROUTINE bool _Watchdog_Is_empty(
+  const Watchdog_Header *header
+  return _Chain_Is_empty( &header->Chain );
+RTEMS_INLINE_ROUTINE void _Watchdog_Header_initialize(
+  _Chain_Initialize_empty( &header->Chain );
diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
index 8c4ef8b..7c7731a 100644
--- a/cpukit/score/src/coretodset.c
+++ b/cpukit/score/src/coretodset.c
@@ -31,12 +31,12 @@ void _TOD_Set_with_timestamp(
   Watchdog_Interval seconds_next = _Timestamp_Get_seconds( tod_as_timestamp );
   Watchdog_Interval seconds_now;
   ISR_lock_Context lock_context;
-  Chain_Control *header;
+  Watchdog_Header *header;
   _Thread_Disable_dispatch();
   seconds_now = _TOD_Seconds_since_epoch();
-  header = &_Watchdog_Seconds_chain;
+  header = &_Watchdog_Seconds_header;
   if ( seconds_next < seconds_now )
     _Watchdog_Adjust_backward( header, seconds_now - seconds_next );
diff --git a/cpukit/score/src/watchdog.c b/cpukit/score/src/watchdog.c
index 4b093d5..0db60ef 100644
--- a/cpukit/score/src/watchdog.c
+++ b/cpukit/score/src/watchdog.c
@@ -21,8 +21,6 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/score/isr.h>
 void _Watchdog_Handler_initialization( void )
@@ -31,6 +29,6 @@ void _Watchdog_Handler_initialization( void )
   _Watchdog_Sync_level = 0;
   _Watchdog_Ticks_since_boot = 0;
-  _Chain_Initialize_empty( &_Watchdog_Ticks_chain );
-  _Chain_Initialize_empty( &_Watchdog_Seconds_chain );
+  _Watchdog_Header_initialize( &_Watchdog_Ticks_header );
+  _Watchdog_Header_initialize( &_Watchdog_Seconds_header );
diff --git a/cpukit/score/src/watchdogadjust.c b/cpukit/score/src/watchdogadjust.c
index 5d84104..687f063 100644
--- a/cpukit/score/src/watchdogadjust.c
+++ b/cpukit/score/src/watchdogadjust.c
@@ -23,7 +23,7 @@
@@ -31,7 +31,7 @@ void _Watchdog_Adjust_backward(
-  if ( !_Chain_Is_empty( header ) ) {
+  if ( !_Watchdog_Is_empty( header ) ) {
      _Watchdog_First( header )->delta_interval += units;
@@ -39,7 +39,7 @@ void _Watchdog_Adjust_backward(
@@ -47,7 +47,7 @@ void _Watchdog_Adjust_forward(
-  while ( !_Chain_Is_empty( header ) && units > 0 ) {
+  while ( !_Watchdog_Is_empty( header ) && units > 0 ) {
     Watchdog_Control *first = _Watchdog_First( header );
     if ( units < first->delta_interval ) {
diff --git a/cpukit/score/src/watchdogadjusttochain.c b/cpukit/score/src/watchdogadjusttochain.c
index 1cddcbc..1926656 100644
--- a/cpukit/score/src/watchdogadjusttochain.c
+++ b/cpukit/score/src/watchdogadjusttochain.c
@@ -18,14 +18,13 @@
 #include "config.h"
 #endif
+#include <rtems/score/isrlevel.h>
@@ -36,7 +35,7 @@ void _Watchdog_Adjust_to_chain(
   while ( 1 ) {
-    if ( _Chain_Is_empty( header ) ) {
+    if ( _Watchdog_Is_empty( header ) ) {
       break;
@@ -63,7 +62,7 @@ void _Watchdog_Adjust_to_chain(
       _ISR_Flash( level );
         break;
       if ( first->delta_interval != 0 )
diff --git a/cpukit/score/src/watchdoginsert.c b/cpukit/score/src/watchdoginsert.c
index 3169c80..272cac8 100644
--- a/cpukit/score/src/watchdoginsert.c
+++ b/cpukit/score/src/watchdoginsert.c
@@ -18,12 +18,12 @@
 #include "config.h"
 #endif
+#include <rtems/score/percpu.h>
 void _Watchdog_Insert(
diff --git a/cpukit/score/src/watchdogtickle.c b/cpukit/score/src/watchdogtickle.c
index 8e410a5..8c1a3a7 100644
--- a/cpukit/score/src/watchdogtickle.c
+++ b/cpukit/score/src/watchdogtickle.c
@@ -18,12 +18,11 @@
 #include "config.h"
 #endif
 void _Watchdog_Tickle(
   ISR_Level level;
@@ -38,7 +37,7 @@ void _Watchdog_Tickle(
     goto leave;
   the_watchdog = _Watchdog_First( header );
@@ -110,7 +109,7 @@ void _Watchdog_Tickle(
-   } while ( !_Chain_Is_empty( header ) &&
+   } while ( !_Watchdog_Is_empty( header ) &&
              (the_watchdog->delta_interval == 0) );
 leave:
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index 7a1353d..13544b2 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -46,10 +46,10 @@ static rtems_timer_service_routine test_release_from_isr(
   void     *arg
-  Chain_Control *chain = &_Watchdog_Ticks_chain;
+  Watchdog_Header *header = &_Watchdog_Ticks_header;
-  if ( !_Chain_Is_empty( chain ) ) {
-    Watchdog_Control *watchdog = _Watchdog_First( chain );
+    Watchdog_Control *watchdog = _Watchdog_First( header );
     if (
diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
index bc942d5..2f9caa5 100644
--- a/testsuites/sptests/spintrcritical09/init.c
+++ b/testsuites/sptests/spintrcritical09/init.c
@@ -43,10 +43,10 @@ static rtems_timer_service_routine test_release_from_isr(
   void     *arg
     if (
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index f427bd2..f00da0d 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -402,8 +402,8 @@ uninitialized =
 /*watchdog.h*/  (sizeof _Watchdog_Sync_level)             +
                 (sizeof _Watchdog_Sync_count)             +
                 (sizeof _Watchdog_Ticks_since_boot)       +
-                (sizeof _Watchdog_Ticks_chain)            +
-                (sizeof _Watchdog_Seconds_chain)          +
+                (sizeof _Watchdog_Ticks_header)           +
+                (sizeof _Watchdog_Seconds_header)         +
 /*wkspace.h*/   (sizeof _Workspace_Area);
1.8.4.5
