[PATCH 33/42] DRVMGR: change name of freq_get to get_freq
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:33:00 UTC 2015
 c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c |    2 +-
 cpukit/libdrvmgr/drvmgr.h                         |    2 +-
 cpukit/libdrvmgr/drvmgr_drvinf.c                  |    4 ++--
 cpukit/libpci/pci_bus.c                           |    6 +++---
 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
index 4c58b2b..63b605a 100644
--- a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
+++ b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
@@ -71,7 +71,7 @@ struct drvmgr_bus_ops ambapp_bus_ops =
 	.int_mask	= ambapp_int_mask,
 	.int_unmask	= ambapp_int_unmask,
 	.get_params	= ambapp_get_params,
-	.freq_get	= ambapp_bus_freq_get,
+	.get_freq	= ambapp_bus_freq_get,
 #ifdef AMBAPPBUS_INFO_AVAIL
 	.info_dev	= ambapp_dev_info,
 #endif
diff --git a/cpukit/libdrvmgr/drvmgr.h b/cpukit/libdrvmgr/drvmgr.h
index a084245..6780efe 100644
--- a/cpukit/libdrvmgr/drvmgr.h
+++ b/cpukit/libdrvmgr/drvmgr.h
@@ -141,7 +141,7 @@ struct drvmgr_bus_ops {
 	/* Get Parameters */
 	int	(*get_params)(struct drvmgr_dev *, struct drvmgr_bus_params *);
 	/* Get Frequency of Bus */
-	int	(*freq_get)(struct drvmgr_dev*, int, unsigned int*);
+	int	(*get_freq)(struct drvmgr_dev*, int, unsigned int*);
 	/*! Function called to request information about a device. The bus
 	 *  driver interpret the bus-specific information about the device.
diff --git a/cpukit/libdrvmgr/drvmgr_drvinf.c b/cpukit/libdrvmgr/drvmgr_drvinf.c
index 45926f1..e0cd50d 100644
--- a/cpukit/libdrvmgr/drvmgr_drvinf.c
+++ b/cpukit/libdrvmgr/drvmgr_drvinf.c
@@ -54,10 +54,10 @@ int drvmgr_freq_get(
 	int options,
 	unsigned int *freq_hz)
-	if (!dev || !dev->parent || !dev->parent->ops->freq_get)
+	if (!dev || !dev->parent || !dev->parent->ops->get_freq)
 		return -1;
-	return dev->parent->ops->freq_get(dev, options, freq_hz);
+	return dev->parent->ops->get_freq(dev, options, freq_hz);
 /* Get driver prefix */
diff --git a/cpukit/libpci/pci_bus.c b/cpukit/libpci/pci_bus.c
index 3cc840d..0e917c0 100644
--- a/cpukit/libpci/pci_bus.c
+++ b/cpukit/libpci/pci_bus.c
@@ -61,7 +61,7 @@ int pcibus_int_unregister(
 int pcibus_int_clear(
 	struct drvmgr_dev *dev,
 	int index);
-int pcibus_freq_get(
+static int pcibus_get_freq(
 	int options,
 	unsigned int *freq_hz);
@@ -92,7 +92,7 @@ struct drvmgr_bus_ops pcibus_ops = {
 	.int_mask	= NULL,
 	.int_unmask	= NULL,
 	.get_params	= pcibus_get_params,
-	.freq_get	= pcibus_freq_get,
+	.get_freq	= pcibus_get_freq,
 #ifdef PCIBUS_INFO
 	.info_dev	= pcibus_dev_info,
 #endif
@@ -255,7 +255,7 @@ int pcibus_int_clear(
 	return 0;
 	int options,
1.7.0.4
