[PATCH 34/42] DRVMGR: renamed info_dev to get_info_dev
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:33:01 UTC 2015
 c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c |    2 +-
 cpukit/libdrvmgr/drvmgr.h                         |    3 ++-
 cpukit/libdrvmgr/drvmgr_print.c                   |    6 +++---
 cpukit/libpci/pci_bus.c                           |    2 +-
 4 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
index 63b605a..922c43b 100644
--- a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
+++ b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
@@ -73,7 +73,7 @@ struct drvmgr_bus_ops ambapp_bus_ops =
 	.get_params	= ambapp_get_params,
 	.get_freq	= ambapp_bus_freq_get,
 #ifdef AMBAPPBUS_INFO_AVAIL
-	.info_dev	= ambapp_dev_info,
+	.get_info_dev	= ambapp_dev_info,
 #endif
diff --git a/cpukit/libdrvmgr/drvmgr.h b/cpukit/libdrvmgr/drvmgr.h
index 6780efe..71a2850 100644
--- a/cpukit/libdrvmgr/drvmgr.h
+++ b/cpukit/libdrvmgr/drvmgr.h
@@ -145,7 +145,8 @@ struct drvmgr_bus_ops {
 	/*! Function called to request information about a device. The bus
 	 *  driver interpret the bus-specific information about the device.
-	void	(*info_dev)(struct drvmgr_dev *, void (*print)(void *p, char *str), void *p);
+	void	(*get_info_dev)(struct drvmgr_dev *,
+				void (*print)(void *p, char *str), void *p);
 #define BUS_OPS_NUM (sizeof(struct drvmgr_bus_ops)/sizeof(void (*)(void)))
diff --git a/cpukit/libdrvmgr/drvmgr_print.c b/cpukit/libdrvmgr/drvmgr_print.c
index 206b9fe..9330867 100644
--- a/cpukit/libdrvmgr/drvmgr_print.c
+++ b/cpukit/libdrvmgr/drvmgr_print.c
@@ -261,10 +261,10 @@ void drvmgr_info_dev(struct drvmgr_dev *dev, unsigned int options)
 		printf("  --- DEVICE INFO FROM BUS DRIVER ---\n");
 		if (!dev->parent)
 			printf("  !! device has no parent bus !!\n");
-		else if (dev->parent->ops->info_dev)
-			dev->parent->ops->info_dev(dev, print_info, NULL);
+		else if (dev->parent->ops->get_info_dev)
+			dev->parent->ops->get_info_dev(dev, print_info, NULL);
 		else
-			printf("  Bus doesn't implement info_dev func\n");
+			printf("  Bus doesn't implement get_info_dev func\n");
 	if (options & OPTION_DEV_DRVINFO) {
diff --git a/cpukit/libpci/pci_bus.c b/cpukit/libpci/pci_bus.c
index 0e917c0..7c2f18b 100644
--- a/cpukit/libpci/pci_bus.c
+++ b/cpukit/libpci/pci_bus.c
@@ -94,7 +94,7 @@ struct drvmgr_bus_ops pcibus_ops = {
 	.get_params	= pcibus_get_params,
 	.get_freq	= pcibus_get_freq,
 #ifdef PCIBUS_INFO
-	.info_dev	= pcibus_dev_info,
+	.get_info_dev	= pcibus_dev_info,
 #endif
1.7.0.4
