[PATCH 35/42] DRVMGR: KEY_TYPE now a enum drvmgr_kt
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:33:02 UTC 2015
 c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c       |    8 ++--
 c/src/lib/libbsp/sparc/shared/1553/b1553brm.c      |    8 ++--
 c/src/lib/libbsp/sparc/shared/1553/b1553rt.c       |    4 +-
 c/src/lib/libbsp/sparc/shared/can/grcan.c          |    8 ++--
 .../libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c  |    4 +-
 .../libbsp/sparc/shared/drvmgr/leon2_amba_bus.c    |   40 ++++++++++----------
 c/src/lib/libbsp/sparc/shared/gpio/grgpio.c        |    4 +-
 c/src/lib/libbsp/sparc/shared/mem/mctrl.c          |    6 +-
 c/src/lib/libbsp/sparc/shared/net/greth.c          |    6 +-
 c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c   |    6 +-
 .../lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c  |    2 +-
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c    |    2 +-
 .../libbsp/sparc/shared/pci/gr_rasta_spw_router.c  |    2 +-
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c  |    2 +-
 c/src/lib/libbsp/sparc/shared/pci/grpci.c          |    6 +-
 c/src/lib/libbsp/sparc/shared/pci/grpci2.c         |    6 +-
 c/src/lib/libbsp/sparc/shared/pci/pcif.c           |    4 +-
 c/src/lib/libbsp/sparc/shared/spi/spictrl.c        |    2 +-
 c/src/lib/libbsp/sparc/shared/spw/grspw.c          |   18 ++++----
 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c      |    4 +-
 c/src/lib/libbsp/sparc/shared/timer/gptimer.c      |    8 ++--
 c/src/lib/libbsp/sparc/shared/tmtc/grtm.c          |    2 +-
 c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c  |    4 +-
 cpukit/libdrvmgr/drvmgr.h                          |   23 ++++++-----
 cpukit/libdrvmgr/drvmgr_print.c                    |    2 +-
 cpukit/libdrvmgr/drvmgr_res.c                      |    9 ++--
 cpukit/libmisc/shell/main_drvmgr.c                 |   16 ++++----
 27 files changed, 105 insertions(+), 101 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
index 677cea1..40ba93d 100644
--- a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
+++ b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
@@ -497,7 +497,7 @@ static int at697pci_init(struct at697pci_priv *priv)
 			/* User may override hardcoded IRQ setup */
 			keyname_sysirq[3] = 'A' + (pin-1);
 			value = drvmgr_dev_key_get(priv->dev,
-					keyname_sysirq, KEY_TYPE_INT);
+					keyname_sysirq, DRVMGR_KT_INT);
 			if ( value )
 				at697_pci_irq_table[pin-1] = value->i;
@@ -505,7 +505,7 @@ static int at697pci_init(struct at697pci_priv *priv)
 			keyname_pio[3] = 'A' + (pin-1);
-						keyname_pio, KEY_TYPE_INT);
+						keyname_pio, DRVMGR_KT_INT);
 			if ( value )
 				at697_pci_irq_pio_table[pin-1] = value->i;
@@ -517,13 +517,13 @@ static int at697pci_init(struct at697pci_priv *priv)
 	 * Defualt is to map system RAM at pci address 0x40000000 and system
 	 * SDRAM to pci address 0x60000000
-	value = drvmgr_dev_key_get(priv->dev, "tgtbar1", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "tgtbar1", DRVMGR_KT_INT);
 	if (value)
 		priv->bar1_pci_adr = value->i;
 	else
 		priv->bar1_pci_adr = SYSTEM_MAINMEM_START; /* default */
-	value = drvmgr_dev_key_get(priv->dev, "tgtbar2", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "tgtbar2", DRVMGR_KT_INT);
 	if (value)
 		priv->bar2_pci_adr = value->i;
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
index d998748..8a5efaf 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/b1553brm.c
@@ -454,7 +454,7 @@ int b1553brm_device_init(brm_priv *pDev)
 #endif
 	/* Get memory configuration from bus resources */
-	value = drvmgr_dev_key_get(pDev->dev, "dmaBaseAdr", KEY_TYPE_POINTER);
+	value = drvmgr_dev_key_get(pDev->dev, "dmaBaseAdr", DRVMGR_KT_POINTER);
 	if (value)
 		mem = (unsigned int)value->ptr;
@@ -505,17 +505,17 @@ int b1553brm_device_init(brm_priv *pDev)
 	pDev->cfg_clkdiv = 0;
 	pDev->cfg_freq = BRM_FREQ_24MHZ;
-	value = drvmgr_dev_key_get(pDev->dev, "clkSel", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "clkSel", DRVMGR_KT_INT);
 	if ( value ) {
 		pDev->cfg_clksel = value->i & CLKSEL_MASK;
-	value = drvmgr_dev_key_get(pDev->dev, "clkDiv", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "clkDiv", DRVMGR_KT_INT);
 	if ( value ) {
 		pDev->cfg_clkdiv = value->i & CLKDIV_MASK;
-	value = drvmgr_dev_key_get(pDev->dev, "coreFreq", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "coreFreq", DRVMGR_KT_INT);
 	if ( value ) {
 		pDev->cfg_freq = value->i & BRM_FREQ_MASK;
diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553rt.c b/c/src/lib/libbsp/sparc/shared/1553/b1553rt.c
index 321e569..b076abd 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/b1553rt.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/b1553rt.c
@@ -300,7 +300,7 @@ int b1553rt_device_init(rt_priv *pDev)
 #endif
     if (value)
@@ -362,7 +362,7 @@ int b1553rt_device_init(rt_priv *pDev)
     if ( value ) {
         pDev->cfg_freq = value->i & RT_FREQ_MASK;
diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan.c b/c/src/lib/libbsp/sparc/shared/can/grcan.c
index 1d7d1ba..c1d1271 100644
--- a/c/src/lib/libbsp/sparc/shared/can/grcan.c
+++ b/c/src/lib/libbsp/sparc/shared/can/grcan.c
@@ -1267,19 +1267,19 @@ static rtems_device_driver grcan_open(rtems_device_major_number major, rtems_dev
 	pDev->rxbuf_size = RX_BUF_SIZE;
 	/* Override default buffer sizes if available from bus resource */
-	value = drvmgr_dev_key_get(pDev->dev, "txBufSize", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "txBufSize", DRVMGR_KT_INT);
 	if ( value )
 		pDev->txbuf_size = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "rxBufSize", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "rxBufSize", DRVMGR_KT_INT);
 	if ( value )
 		pDev->rxbuf_size = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "txBufAdr", KEY_TYPE_POINTER);
+	value = drvmgr_dev_key_get(pDev->dev, "txBufAdr", DRVMGR_KT_POINTER);
 	if ( value )
 		pDev->txbuf_adr = value->ptr;
-	value = drvmgr_dev_key_get(pDev->dev, "rxBufAdr", KEY_TYPE_POINTER);
+	value = drvmgr_dev_key_get(pDev->dev, "rxBufAdr", DRVMGR_KT_POINTER);
 	if ( value )
 		pDev->rxbuf_adr = value->ptr;
diff --git a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c
index 3fc2463..f5fb35d 100644
--- a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c
+++ b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c
@@ -157,7 +157,7 @@ int ambapp_leon2_init1(struct drvmgr_dev *dev)
 	/* Try to get Configuration from resource configuration */
-	value = drvmgr_dev_key_get(dev, "busFreq", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(dev, "busFreq", DRVMGR_KT_INT);
 	if (value) {
 		/* Set frequency of AMBA bus if specified by user. The frequency
 		 * must be for AHB bus which IOAREA matches (AHB bus 0).
@@ -173,7 +173,7 @@ int ambapp_leon2_init1(struct drvmgr_dev *dev)
 	/* Note that this can be overrided by a driver on the AMBA PnP bus.*/
 	ambapp_freq_init(&priv->abus, NULL, freq_hz);
-	value = drvmgr_dev_key_get(dev, "drvRes", KEY_TYPE_POINTER);
+	value = drvmgr_dev_key_get(dev, "drvRes", DRVMGR_KT_POINTER);
 	if (!value) {
 		DBG("ambapp_leon2_init1: Failed getting resource drvRes\n");
 		config->resources = NULL;
diff --git a/c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c b/c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c
index bae2893..2e53ca3 100644
--- a/c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c
+++ b/c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c
@@ -81,40 +81,40 @@ struct leon2_isr_handler {
 struct drvmgr_key leon2_timers[] =
-	{"REG0", KEY_TYPE_INT, {0x80000040}},
-	{"IRQ0", KEY_TYPE_INT, {8}},
-	{"IRQ1", KEY_TYPE_INT, {9}},
-	KEY_EMPTY
+	{"REG0", DRVMGR_KT_INT, {0x80000040}},
+	{"IRQ0", DRVMGR_KT_INT, {8}},
+	{"IRQ1", DRVMGR_KT_INT, {9}},
+	DRVMGR_KEY_EMPTY
 struct drvmgr_key leon2_uart1[] =
-	{"REG0", KEY_TYPE_INT, {0x80000070}},
-	{"IRQ0", KEY_TYPE_INT, {3}},
-	KEY_EMPTY
+	{"REG0", DRVMGR_KT_INT, {0x80000070}},
+	{"IRQ0", DRVMGR_KT_INT, {3}},
+	DRVMGR_KEY_EMPTY
 struct drvmgr_key leon2_uart2[] =
-	{"REG0", KEY_TYPE_INT, {0x80000080}},
-	{"IRQ0", KEY_TYPE_INT, {2}},
-	KEY_EMPTY
+	{"REG0", DRVMGR_KT_INT, {0x80000080}},
+	{"IRQ0", DRVMGR_KT_INT, {2}},
+	DRVMGR_KEY_EMPTY
 struct drvmgr_key leon2_irqctrl[] =
-	{"REG0", KEY_TYPE_INT, {0x80000090}},
-	KEY_EMPTY
+	{"REG0", DRVMGR_KT_INT, {0x80000090}},
+	DRVMGR_KEY_EMPTY
 struct drvmgr_key leon2_gpio0[] =
-	{"REG0", KEY_TYPE_INT, {0x800000A0}},
-	{"IRQ0", KEY_TYPE_INT, {4}},
-	{"IRQ1", KEY_TYPE_INT, {5}},
-	{"IRQ2", KEY_TYPE_INT, {6}},
-	{"IRQ3", KEY_TYPE_INT, {7}},
-	KEY_EMPTY
+	{"REG0", DRVMGR_KT_INT, {0x800000A0}},
+	{"IRQ0", DRVMGR_KT_INT, {4}},
+	{"IRQ1", DRVMGR_KT_INT, {5}},
+	{"IRQ2", DRVMGR_KT_INT, {6}},
+	{"IRQ3", DRVMGR_KT_INT, {7}},
+	DRVMGR_KEY_EMPTY
 struct leon2_core leon2_std_cores[] =
@@ -163,7 +163,7 @@ static int leon2_amba_dev_register(
 	info->core_id = core->id.core_id;
 	/* Get information from bus configuration */
-	value = drvmgr_key_val_get(core->keys, "REG0", KEY_TYPE_INT);
+	value = drvmgr_key_val_get(core->keys, "REG0", DRVMGR_KT_INT);
 	if ( !value ) {
 		printk("leon2_amba_dev_register: Failed getting resource REG0\n");
 		info->reg_base = 0x00000000;
@@ -183,7 +183,7 @@ static int leon2_amba_dev_register(
 			irq_name[5] = '\0';
-		value = drvmgr_key_val_get(core->keys, irq_name, KEY_TYPE_INT);
+		value = drvmgr_key_val_get(core->keys, irq_name, DRVMGR_KT_INT);
 		if ( !value ) {
 			DBG("leon2_amba_dev_register: Failed getting resource IRQ%d for REG 0x%x\n", i, info->reg_base);
 			info->irqs[i] = 0;
diff --git a/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c b/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c
index 79926dc..7b02298 100644
--- a/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c
+++ b/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c
@@ -415,7 +415,7 @@ int grgpio_device_init(struct grgpio_priv *priv)
 	/* Let the user configure the port count, this might be needed
 	 * when the GPIO lines must not be changed (assigned during bootup)
-	value = drvmgr_dev_key_get(priv->dev, "nBits", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "nBits", DRVMGR_KT_INT);
 	if ( value ) {
 		priv->port_cnt = value->i;
 	} else {
@@ -434,7 +434,7 @@ int grgpio_device_init(struct grgpio_priv *priv)
 	/* Let the user configure the BYPASS register, this might be needed
 	 * to select which cores can do I/O on a pin.
-	value = drvmgr_dev_key_get(priv->dev, "bypass", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "bypass", DRVMGR_KT_INT);
 	if ( value ) {
 		priv->bypass = value->i;
 	} else {
diff --git a/c/src/lib/libbsp/sparc/shared/mem/mctrl.c b/c/src/lib/libbsp/sparc/shared/mem/mctrl.c
index 269a205..42c81c4 100644
--- a/c/src/lib/libbsp/sparc/shared/mem/mctrl.c
+++ b/c/src/lib/libbsp/sparc/shared/mem/mctrl.c
@@ -153,7 +153,7 @@ static int mctrl_init1(struct drvmgr_dev *dev)
 	strcpy(res_name, "mcfgX");
 	for(i=0; i<8; i++) {
 		res_name[4] = '1' + i;
-		value = drvmgr_dev_key_get(priv->dev, res_name, KEY_TYPE_INT);
+		value = drvmgr_dev_key_get(priv->dev, res_name, DRVMGR_KT_INT);
 		if ( value ) {
 			priv->mcfg[i] = value->i;
 			priv->configured |= (1<<i);
@@ -174,12 +174,12 @@ static int mctrl_init1(struct drvmgr_dev *dev)
 	for (i=0; i<9; i++) {
 		strcpy(res_name, "washXStart");
 		res_name[4] = '0' + i;
 		if ( value ) {
 			start = value->i;
 			strcpy(res_name, "washXLength");
 			if ( value ) {
 				length = value->i;
diff --git a/c/src/lib/libbsp/sparc/shared/net/greth.c b/c/src/lib/libbsp/sparc/shared/net/greth.c
index 5c5b263..13dabfe 100644
--- a/c/src/lib/libbsp/sparc/shared/net/greth.c
+++ b/c/src/lib/libbsp/sparc/shared/net/greth.c
@@ -1443,15 +1443,15 @@ int greth_device_init(struct greth_softc *sc)
     sc->rxbufs = 32;
     sc->phyaddr = -1;
-    value = drvmgr_dev_key_get(sc->dev, "txDescs", KEY_TYPE_INT);
+    value = drvmgr_dev_key_get(sc->dev, "txDescs", DRVMGR_KT_INT);
     if ( value && (value->i <= 128) )
         sc->txbufs = value->i;
-    value = drvmgr_dev_key_get(sc->dev, "rxDescs", KEY_TYPE_INT);
+    value = drvmgr_dev_key_get(sc->dev, "rxDescs", DRVMGR_KT_INT);
         sc->rxbufs = value->i;
-    value = drvmgr_dev_key_get(sc->dev, "phyAdr", KEY_TYPE_INT);
+    value = drvmgr_dev_key_get(sc->dev, "phyAdr", DRVMGR_KT_INT);
     if ( value && (value->i < 32) )
         sc->phyaddr = value->i;
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c b/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c
index 43b725f..9f19838 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c
@@ -516,7 +516,7 @@ int gr_cpci_leon4_n2x_init1(struct drvmgr_dev *dev)
 	 * Only the 2 MSB bits have an effect.
-	value = drvmgr_dev_key_get(priv->dev, "ahbmst2pci", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "ahbmst2pci", DRVMGR_KT_INT);
 	if (value)
 		priv->ahbmst2pci_map = value->i;
 	else
@@ -525,7 +525,7 @@ int gr_cpci_leon4_n2x_init1(struct drvmgr_dev *dev)
 	/* Let user override the default AMBA system frequency of the
 	 * CPU-bus of the remote GR-CPCI-LEON4-N2X. Default is 200MHz.
-	value = drvmgr_dev_key_get(priv->dev, "ambaFreq", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "ambaFreq", DRVMGR_KT_INT);
 	if (value)
 		priv->amba_freq_hz = value->i;
 	else
@@ -534,7 +534,7 @@ int gr_cpci_leon4_n2x_init1(struct drvmgr_dev *dev)
 	/* Let user determine clock-gating unit configuration. The default
 	 * is to turn all cores on (disable gating). PCI is always turned ON.
-	value = drvmgr_dev_key_get(priv->dev, "cgEnMask", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "cgEnMask", DRVMGR_KT_INT);
 	if (value)
 		priv->cg_en_mask = (value->i & CG_MASK) | 0x08;
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
index 25b512a..3289131 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
@@ -418,7 +418,7 @@ int gr_rasta_adcdac_init1(struct drvmgr_dev *dev)
 	 * goes out on the PCI bus.
 	 * Only the 4 MSB bits have an effect;
 	if (value)
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
index dd8a7b1..95bbee9 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
@@ -597,7 +597,7 @@ int gr_rasta_io_init1(struct drvmgr_dev *dev)
 	if (value)
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
index 6d53fea..8bce118 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
@@ -430,7 +430,7 @@ int gr_rasta_spw_router_init1(struct drvmgr_dev *dev)
 	if (value)
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
index c9cf8ea..c8ba4c4 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
@@ -609,7 +609,7 @@ int gr_rasta_tmtc_init1(struct drvmgr_dev *dev)
 	if (value)
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci.c b/c/src/lib/libbsp/sparc/shared/pci/grpci.c
index d9559d1..047f1c1 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci.c
@@ -545,21 +545,21 @@ static int grpci_init(struct grpci_priv *priv)
 			/* User may override Both hardcoded IRQ setup and Plug & Play IRQ */
 			keyname[3] = 'A' + (pin-1);
-			value = drvmgr_dev_key_get(priv->dev, keyname, KEY_TYPE_INT);
+			value = drvmgr_dev_key_get(priv->dev, keyname, DRVMGR_KT_INT);
 			if ( value )
 				grpci_pci_irq_table[pin-1] = value->i;
 	/* User may override DEFAULT_BT_ENABLED to enable/disable byte twisting */
-	value = drvmgr_dev_key_get(priv->dev, "byteTwisting", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "byteTwisting", DRVMGR_KT_INT);
 	if ( value )
 		priv->bt_enabled = value->i;
 	/* Use GRPCI target BAR1 to map CPU RAM to PCI, this is to make it
 	 * possible for PCI peripherals to do DMA directly to CPU memory.
 	if (value)
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
index 1b77921..9d8dea6 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
@@ -761,7 +761,7 @@ static int grpci2_init(struct grpci2_priv *priv)
 			if (value)
 				grpci2_pci_irq_table[pin-1] = value->i;
@@ -772,12 +772,12 @@ static int grpci2_init(struct grpci2_priv *priv)
 	if (value)
 	/* Let user Configure the 6 target BARs */
-	value = drvmgr_dev_key_get(priv->dev, "tgtBarCfg", KEY_TYPE_POINTER);
+	value = drvmgr_dev_key_get(priv->dev, "tgtBarCfg", DRVMGR_KT_POINTER);
 	if (value)
 		priv->barcfg = value->ptr;
 	else
diff --git a/c/src/lib/libbsp/sparc/shared/pci/pcif.c b/c/src/lib/libbsp/sparc/shared/pci/pcif.c
index 6d22fc3..c0b8fc9 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/pcif.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/pcif.c
@@ -457,14 +457,14 @@ static int pcif_init(struct pcif_priv *priv)
 			/* User may override Plug & Play IRQ */
 			if ( value )
 				pcif_pci_irq_table[pin-1] = value->i;
 	priv->irq_mask = 0xf;
-	value = drvmgr_dev_key_get(priv->dev, "", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "", DRVMGR_KT_INT);
 	if ( value )
 		priv->irq_mask = value->i & 0xf;
diff --git a/c/src/lib/libbsp/sparc/shared/spi/spictrl.c b/c/src/lib/libbsp/sparc/shared/spi/spictrl.c
index 1036fe2..2d63988 100644
--- a/c/src/lib/libbsp/sparc/shared/spi/spictrl.c
+++ b/c/src/lib/libbsp/sparc/shared/spi/spictrl.c
@@ -1005,7 +1005,7 @@ int spictrl_device_init(struct spictrl_priv *priv)
 	priv->regs->mode = 0;
 	/* Get custom */
-	value = drvmgr_dev_key_get(priv->dev, "slvSelFunc", KEY_TYPE_POINTER);
+	value = drvmgr_dev_key_get(priv->dev, "slvSelFunc", DRVMGR_KT_POINTER);
 	if ( value ) {
 		priv->slvSelFunc = value->ptr;
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw.c b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
index a145b1c..fd21303 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
@@ -536,39 +536,39 @@ int grspw_device_init(GRSPW_DEV *pDev)
 	/* Get Configuration from Bus resources (Let user override defaults) */
-	value = drvmgr_dev_key_get(pDev->dev, "txBdCnt", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "txBdCnt", DRVMGR_KT_INT);
 	if ( value )
 		pDev->txbufcnt = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "rxBdCnt", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "rxBdCnt", DRVMGR_KT_INT);
 	if ( value )
 		pDev->rxbufcnt = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "txDataSize", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "txDataSize", DRVMGR_KT_INT);
 	if ( value )
 		pDev->txdbufsize = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "txHdrSize", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "txHdrSize", DRVMGR_KT_INT);
 	if ( value )
 		pDev->txhbufsize = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "rxPktSize", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "rxPktSize", DRVMGR_KT_INT);
 	if ( value )
 		pDev->rxbufsize = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "rxDmaArea", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "rxDmaArea", DRVMGR_KT_INT);
 	if ( value )
 		pDev->rx_dma_area = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "txDataDmaArea", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "txDataDmaArea", DRVMGR_KT_INT);
 	if ( value )
 		pDev->tx_data_dma_area = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "txHdrDmaArea", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "txHdrDmaArea", DRVMGR_KT_INT);
 	if ( value )
 		pDev->tx_hdr_dma_area = value->i;
-	value = drvmgr_dev_key_get(pDev->dev, "bdDmaArea", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(pDev->dev, "bdDmaArea", DRVMGR_KT_INT);
 	if ( value )
 		pDev->bd_dma_area = value->i;
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index 7437f5e..037b63c 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -547,7 +547,7 @@ void *grspw_open(int dev_no)
 	 *  - 64 TX descriptors per DMA Channel
 	bdtabsize = 2 * BDTAB_SIZE * priv->hwsup.ndma_chans;
-	value = drvmgr_dev_key_get(priv->dev, "bdDmaArea", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "bdDmaArea", DRVMGR_KT_INT);
 	if (value) {
 		priv->bd_mem = value->i;
 		priv->bd_mem_alloced = 0;
@@ -2830,7 +2830,7 @@ static int grspw2_init3(struct drvmgr_dev *dev)
 	/* Let user limit the number of DMA channels on this core to save
 	 * space. Only the first nDMA channels will be available.
-	value = drvmgr_dev_key_get(priv->dev, "nDMA", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "nDMA", DRVMGR_KT_INT);
 	if (value && (value->i < priv->hwsup.ndma_chans))
 		priv->hwsup.ndma_chans = value->i;
diff --git a/c/src/lib/libbsp/sparc/shared/timer/gptimer.c b/c/src/lib/libbsp/sparc/shared/timer/gptimer.c
index 8d72f6d..e12ae7d 100644
--- a/c/src/lib/libbsp/sparc/shared/timer/gptimer.c
+++ b/c/src/lib/libbsp/sparc/shared/timer/gptimer.c
@@ -213,12 +213,12 @@ int gptimer_init1(struct drvmgr_dev *dev)
 		timer_start = LEON3_Cpu_Index;
 #endif
-	value = drvmgr_dev_key_get(dev, "timerStart", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(dev, "timerStart", DRVMGR_KT_INT);
 	if ( value) {
 		timer_start = value->i;
 		timer_cnt = timer_hw_cnt - timer_start;
-	value = drvmgr_dev_key_get(dev, "timerCnt", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(dev, "timerCnt", DRVMGR_KT_INT);
 	if ( value && (value->i < timer_cnt) ) {
 		timer_cnt = value->i;
@@ -264,7 +264,7 @@ int gptimer_init1(struct drvmgr_dev *dev)
 	 * that doing so for the Root-Bus GPTIMER may affect the RTEMS Clock
 	 * so that Clock frequency is wrong.
-	value = drvmgr_dev_key_get(priv->dev, "prescaler", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "prescaler", DRVMGR_KT_INT);
 	if ( value )
 		regs->scaler_reload = value->i;
@@ -312,7 +312,7 @@ int gptimer_init1(struct drvmgr_dev *dev)
 	 * the timer must be registered at the Clock Driver.
 #if defined(LEON3) && defined(RTEMS_DRVMGR_STARTUP)
-	value = drvmgr_dev_key_get(priv->dev, "clockTimer", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "clockTimer", DRVMGR_KT_INT);
 		LEON3_Timer_Regs = (void *)regs;
 		Clock_timer_register(timer_index[value->i]);
diff --git a/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c b/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c
index a7c628f..48b4631 100644
--- a/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c
+++ b/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c
@@ -578,7 +578,7 @@ static int grtm_device_init(struct grtm_priv *pDev)
 	/* Allocate Memory for Buffer Descriptor Table, or let user provide a custom
 	 * address.
-	value = drvmgr_dev_key_get(pDev->dev, "bdTabAdr", KEY_TYPE_POINTER);
+	value = drvmgr_dev_key_get(pDev->dev, "bdTabAdr", DRVMGR_KT_POINTER);
 	if ( value ) {
 		pDev->bds = (struct grtm_bd *)value->ptr;
 		pDev->_bds = (void *)value->ptr;
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
index 07f2d7d..50805f1 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
@@ -238,7 +238,7 @@ int apbuart_init1(struct drvmgr_dev *dev)
 		priv->condev.flags = 0;
-	value = drvmgr_dev_key_get(priv->dev, "syscon", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "syscon", DRVMGR_KT_INT);
 	if (value) {
 		if (value->i)
 			priv->condev.flags |= CONSOLE_FLAG_SYSCON;
@@ -250,7 +250,7 @@ int apbuart_init1(struct drvmgr_dev *dev)
 	priv->condev.ops.get_uart_attrs = apbuart_get_attributes;
 	/* Select 0=Polled, 1=IRQ, 2=Task-Driven UART Mode */
-	value = drvmgr_dev_key_get(priv->dev, "mode", KEY_TYPE_INT);
+	value = drvmgr_dev_key_get(priv->dev, "mode", DRVMGR_KT_INT);
 	if (value)
 		priv->mode = value->i;
 	else
diff --git a/cpukit/libdrvmgr/drvmgr.h b/cpukit/libdrvmgr/drvmgr.h
index 71a2850..1f5bc80 100644
--- a/cpukit/libdrvmgr/drvmgr.h
+++ b/cpukit/libdrvmgr/drvmgr.h
@@ -170,12 +170,15 @@ struct drvmgr_func {
 /* Key Data Types */
-#define KEY_TYPE_NONE		0
-#define KEY_TYPE_INT		1
-#define KEY_TYPE_STRING		2
-#define KEY_TYPE_POINTER	3
+enum drvmgr_kt {
+	DRVMGR_KT_ANY = -1,
+	DRVMGR_KT_NONE = 0,
+	DRVMGR_KT_INT = 1,
+	DRVMGR_KT_STRING = 2,
+	DRVMGR_KT_POINTER = 3,
-#define KEY_EMPTY	{NULL, KEY_TYPE_NONE, {0}}
+#define DRVMGR_KEY_EMPTY	{NULL, DRVMGR_KT_NONE, {0}}
 #define RES_EMPTY	{0, 0, NULL}
 #define MMAP_EMPTY	{0, 0, 0}
@@ -189,7 +192,7 @@ union drvmgr_key_value {
 /* One key. One Value. Holding information relevant to the driver. */
 struct drvmgr_key {
 	char			*key_name;	/* Name of key */
-	int			key_type;	/* How to interpret key_value */
+	enum drvmgr_kt		key_type;	/* How to interpret key_value */
 	union drvmgr_key_value	key_value;	/* The value or pointer to value */
@@ -438,7 +441,7 @@ extern int drvmgr_keys_get(struct drvmgr_dev *dev, struct drvmgr_key **keys);
 /*! Return the one key that matches key name from a driver keys array. The keys
  *  can be obtained using drvmgr_keys_get().
- * \param keys       An array of keys ended with KEY_EMPTY to search among.
+ * \param keys       An array of keys ended with DRVMGR_KEY_EMPTY to search among.
  * \param key_name   Name of key to search for among the keys.
 extern struct drvmgr_key *drvmgr_key_get(struct drvmgr_key *keys, char *key_name);
@@ -449,7 +452,7 @@ extern struct drvmgr_key *drvmgr_key_get(struct drvmgr_key *keys, char *key_name
  *  name), then determines if the type is correct. A pointer to the key value
  *  is returned.
  *  \param key_type   Data Type of value. INTEGER, ADDRESS, STRING.
  *  \return           Returns NULL if no value found matching Key Name and Key
@@ -458,7 +461,7 @@ extern struct drvmgr_key *drvmgr_key_get(struct drvmgr_key *keys, char *key_name
 extern union drvmgr_key_value *drvmgr_key_val_get(
 	char *key_name,
-	int key_type);
+	enum drvmgr_kt key_type);
 /*! Get key value from the bus resources matching [device, key name, key type]
  *  if no matching key is found NULL is returned.
@@ -475,7 +478,7 @@ extern union drvmgr_key_value *drvmgr_key_val_get(
 extern union drvmgr_key_value *drvmgr_dev_key_get(
 	char *key_name,
-	int key_type);
 /*** DRIVER INTERACE USED TO REQUEST INFORMATION/SERVICES FROM BUS DRIVER ***/
diff --git a/cpukit/libdrvmgr/drvmgr_print.c b/cpukit/libdrvmgr/drvmgr_print.c
index 9330867..aecf41c 100644
--- a/cpukit/libdrvmgr/drvmgr_print.c
+++ b/cpukit/libdrvmgr/drvmgr_print.c
@@ -135,7 +135,7 @@ void drvmgr_print_mem(void)
 				resmem += sizeof(struct drvmgr_drv_res);
 				key = res->keys;
-				while (key->key_type != KEY_TYPE_NONE) {
+				while (key->key_type != DRVMGR_KT_NONE) {
 					resmem += sizeof
 						(struct drvmgr_key);
 					key++;
diff --git a/cpukit/libdrvmgr/drvmgr_res.c b/cpukit/libdrvmgr/drvmgr_res.c
index 5faa61e..0322a98 100644
--- a/cpukit/libdrvmgr/drvmgr_res.c
+++ b/cpukit/libdrvmgr/drvmgr_res.c
@@ -61,7 +61,7 @@ struct drvmgr_key *drvmgr_key_get(
 		return NULL;
 	key = keys;
 		if (strcmp(key_name, key->key_name) == 0)
 			return key;
 		key++;
@@ -72,14 +72,15 @@ struct drvmgr_key *drvmgr_key_get(
 	char *key_name,
-	int key_type)
 	struct drvmgr_key *key_match;
 	key_match = drvmgr_key_get(keys, key_name);
 	if (key_match) {
 		/* Found key, put pointer to value into */
-		if ((key_type == -1) || (key_match->key_type == key_type))
+		if ((key_type == DRVMGR_KT_ANY) ||
+		    (key_match->key_type == key_type))
 			return &key_match->key_value;
 	return NULL;
@@ -88,7 +89,7 @@ union drvmgr_key_value *drvmgr_key_val_get(
 	char *key_name,
-	int key_type)
 	struct drvmgr_key *keys = NULL;
diff --git a/cpukit/libmisc/shell/main_drvmgr.c b/cpukit/libmisc/shell/main_drvmgr.c
index a93f6e0..8779d19 100644
--- a/cpukit/libmisc/shell/main_drvmgr.c
+++ b/cpukit/libmisc/shell/main_drvmgr.c
@@ -149,7 +149,7 @@ static void shell_drvmgr_print_key_array(struct drvmgr_key *keys)
   struct drvmgr_key *key;
   static char *type_strs[4] = {"UNKNOWN","INTEGER","STRING ","POINTER"};
-  int type;
+  enum drvmgr_kt type;
   union drvmgr_key_value *val;
   if (keys == NULL) {
@@ -158,23 +158,23 @@ static void shell_drvmgr_print_key_array(struct drvmgr_key *keys)
   key = &keys[0];
-    if (key->key_type > KEY_TYPE_POINTER)
-      type = 0;
+    if (key->key_type > DRVMGR_KT_POINTER)
+      type = DRVMGR_KT_NONE;
     else
       type = key->key_type;
     printf("  NAME=%-14s TYPE=%s  VALUE=", key->key_name, type_strs[type]);
     val = &key->key_value;
     switch (type) {
       default:
-      case 0:
-      case KEY_TYPE_INT:
+      case DRVMGR_KT_NONE:
+      case DRVMGR_KT_INT:
         printf("0x%x (%d)\n", val->i, val->i);
         break;
-      case KEY_TYPE_STRING:
+      case DRVMGR_KT_STRING:
         printf("%s\n", val->str);
         break;
-      case KEY_TYPE_POINTER:
+      case DRVMGR_KT_POINTER:
         printf("%p\n", val->ptr);
         break;
1.7.0.4
