[PATCH] Led.h: Minor code adjustments for clarity, and cleaned up comments
Jeff Mayes
Jeff.Mayes at OARcorp.com
Wed Apr 15 17:21:58 UTC 2015
led/README | 8 ++---
led/led.h | 98 +++++++++++++++++++++++++++++++++++++++++++++++++-------------
2 files changed, 81 insertions(+), 25 deletions(-)
diff --git a/led/README b/led/README
index 4a2ab42..e78f1fd 100644
--- a/led/README
+++ b/led/README
@@ -1,12 +1,10 @@
This is a set of example RTEMS programs. Most of these programs are
-demonstrations various ways to use inter-task communication to
-turn and LED on and off at a fixed rate.
+demonstrations that show various ways to use inter-task communication
+to turn a LED on and off at a fixed rate.
-You must edit led.h so it knows how to turn an LED on and off on your
-target hardware.
+You must edit the led.h file to set your target hardware.
The example programs form a logical sequence in the following order:
hello_world_c
posix_hello_world
ticker
diff --git a/led/led.h b/led/led.h
index 3fee684..eecf100 100644
--- a/led/led.h
+++ b/led/led.h
@@ -38,10 +38,12 @@
#elif defined(MPC8313ERDB)
-/* This rotates a single LED off around the back of 8. */
+ * This rotates a single LED off around the back of 8.
volatile uint8_t *MPC8313_LED_REG;
uint8_t MPC8313_LED_Values[] =
- { 0x01, 0x02, 0x04, 0x08, 0x80, 0x40, 0x20, 0x10};
+ {0x01, 0x02, 0x04, 0x08, 0x80, 0x40, 0x20, 0x10};
uint8_t MPC8313_LED_Count;
#define LED_INIT() \
@@ -53,7 +55,7 @@ uint8_t MPC8313_LED_Count;
#define LED_ROTATE() \
do { \
*MPC8313_LED_REG = MPC8313_LED_Values[MPC8313_LED_Count]; \
- /* printk( "v=0x%02x ", MPC8313_LED_Values[MPC8313_LED_Count] ); */ \
+ /* printk("v=0x%02x ", MPC8313_LED_Values[MPC8313_LED_Count]); */ \
if ( ++MPC8313_LED_Count == 9 ) \
MPC8313_LED_Count = 0; \
} while (0)
@@ -62,23 +64,79 @@ uint8_t MPC8313_LED_Count;
#define LED_OFF() LED_ROTATE()
#elif defined(BCM2835_GPIO_REGS_BASE)
-// Raspberry Pi
-#define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3))
-#define OUT_GPIO(g) *(gpio+((g)/10)) |= (1<<(((g)%10)*3))
-#define GPIO_SET *(gpio+7) // sets bits which are 1 ignores bits which are 0
-#define GPIO_CLR *(gpio+10) // clears bits which are 1 ignores bits which are 0
-// For GPIO# >= 32 (RPi B+)
-#define GPIO_SET_EXT *(gpio+8) // sets bits which are 1 ignores bits which are 0
-#define GPIO_CLR_EXT *(gpio+11) // clears bits which are 1 ignores bits which are 0
-// RPi B
-//#define LED_INIT() do { unsigned int *gpio = (unsigned int *)BCM2835_GPIO_REGS_BASE; OUT_GPIO(16);} while(0)
-//#define LED_ON() do { unsigned int *gpio = (unsigned int *)BCM2835_GPIO_REGS_BASE; GPIO_CLR = 1 << 16;} while(0)
-//#define LED_OFF() do { unsigned int *gpio = (unsigned int *)BCM2835_GPIO_REGS_BASE; GPIO_SET = 1 << 16;} while(0)
-// RPi B+ => led 47
-#define LED_INIT() do { unsigned int *gpio = (unsigned int *)BCM2835_GPIO_REGS_BASE; OUT_GPIO(47);} while(0)
-#define LED_ON() do { unsigned int *gpio = (unsigned int *)BCM2835_GPIO_REGS_BASE; GPIO_CLR_EXT = 1 << (47 % 32);} while(0)
-#define LED_OFF() do { unsigned int *gpio = (unsigned int *)BCM2835_GPIO_REGS_BASE; GPIO_SET_EXT = 1 << (47 % 32);} while(0)
+ * Raspberry Pi - set the #define to match your model
+ * #define PI_MODEL_B 1
+ * #define PI_MODEL_B_PLUS 1
+ #define PI_MODEL_B 1
+ #define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3))
+ #define OUT_GPIO(g) *(gpio+((g)/10)) |= (1<<(((g)%10)*3))
+ * For the base GPIO pins:
+ * SET: sets bits which are 1, ignores bits which are 0
+ * CLR: clears bits which are 1, ignores bits which are 0
+ #define GPIO_SET *(gpio+7)
+ #define GPIO_CLR *(gpio+10)
+ * For the extended GPIO# >= 32 (RPi B+ and maybe Pi2?)
+ * SET_EXT: sets bits which are 1, ignores bits which are 0
+ * CLR_EXT: clears bits which are 1, ignores bits which are 0
+ #define GPIO_SET_EXT *(gpio+8)
+ #define GPIO_CLR_EXT *(gpio+11)
+ #if PI_MODEL_B
+ * For RPi B, GPIO16 drives the ACT status LED on the board, so
+ * use pin 16. Alternatively, GPIO17 (pin #11 on the board) can be used
+ * to connect an external LED.
+ #define PI_LED_PIN 16
+ #define LED_INIT() \
+ do { \
+ unsigned int *gpio = (unsigned int *)BCM2835_GPIO_REGS_BASE; \
+ OUT_GPIO(PI_LED_PIN); \
+ } while(0)
+ #define LED_ON() \
+ do { \
+ GPIO_CLR = 1 << PI_LED_PIN; \
+ } while(0)
+ #define LED_OFF() \
+ do { \
+ GPIO_SET = 1 << PI_LED_PIN; \
+ } while(0)
+ #elif PI_MODEL_BPLUS
+ * For RPi B+, use LED mapped to pin 47
+ #define PI_LED_PIN 47
+ do { \
+ } while(0)
+ do { \
+ GPIO_CLR_EXT = 1 << (PI_LED_PIN % 32); \
+ } while(0)
+ do { \
+ GPIO_SET_EXT = 1 << (PI_LED_PIN % 32); \
+ } while(0)
+ #else
+ #error "Pi LED: Pick a model"
+ #endif
#else
/* default case is to print */
1.9.3
