[PATCH] sp13: Document message buffer usage and adjust configuration
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Apr 15 19:41:01 UTC 2015
testsuites/sptests/sp13/system.h | 23 +++++++++++++++++++----
1 file changed, 19 insertions(+), 4 deletions(-)
diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
index 3b170bf..8e5ffbb 100644
--- a/testsuites/sptests/sp13/system.h
+++ b/testsuites/sptests/sp13/system.h
@@ -66,13 +66,28 @@ TEST_EXTERN rtems_name Queue_name[ 4 ]; /* array of queue names */
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
- * First three created in init.c, last created in task1.c.
+ * Created in init.c:
+ * Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) (1600)
+ * Q2 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) (160)
+ * Q3 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) (1600)
+ * Q1 and Q2 deleted in task1.c
+ * Q1 recreated in task1.c
+ * Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 ) (2000)
+ * Q1 deleted again in task1.c.
+ * Q1 repeatedly created and deleted for 2 messages of 1-1030 bytes
+ * in length
+ * Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 1030, 2 ) (2000)
+ * Thus the peak message memory needed is technically only:
+ * Q3 + third instance of Q1 at peak of two 1030 byte messages.
#define CONFIGURE_MESSAGE_BUFFER_MEMORY \
CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
- CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + \
- CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
+ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 1030, 2 )
#define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
1.9.3
