Make 4.11 Branch Next Monday?
Peter Dufault dufault at hda.com
Thu Apr 23 07:37:33 UTC 2015
I will set aside time to test the MPC5554 against the latest head this weekend.  I haven’t upgraded in a while.
> On Apr 22, 2015, at 21:06 , Chris Johns <chrisj at rtems.org> wrote:
> On 23/04/2015 12:23 am, Joel Sherrill wrote:
>> Hi
>> I want to branch early next week. That should give Chris time to get back
>> up to speed from his holiday and everyone else a chance to make final
>> testing and pushes. Please don't break anything.
> I am back and up to speed. I am happy to branch this Friday (your time).
> So this means master is frozen ?
> Amar are you able to guide us as this is the first time with git ?
> Sebastian are you ok with your clean up stuff ?
>> I just posted a handful of patches that my build of all BSPs with networking
>> and TCP/IP enabled pointed out the need for. I still haven't reviewed my
>> test
>> run on all gdb and qemu simulator BSPs. That needs a review but watching
>> on and off as they ran, I didn't see any blockers. The issues I know of are:
>> Biggest issues:
>> + xilinx BSP does not run on qemu for me. qemu doesn't build on Centos 6
>> and the one I built on a recent Fedora worked for every BSP except xilinx.
> I will try and take a look.
>> + review of getting started docs
>> + release procedure. We will just have to fight through this.
> Yeap.
>> Let it slide issues:
>> + nios2, or1k, and lm32 can't link C++ samples.
>> + still no moxie tools
> Ok.
> Chris
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
