xilinx microblaze
emu at e-bbes.com emu at e-bbes.com
Fri Aug 7 11:00:25 UTC 2015
Zitat von Hesham ALMatary <heshamelmatary at gmail.com>:
> Hi,
> I've built it early this morning, and it went smoothly, no errors. So,
> I suspect it's something with your tools, and perhaps it's better to
> update it and try again as Chris suggested.
Yes, I run an update of Cygwin (but wasn't really old), and I started it again
with --jobs=none.
So far, the log file is twice the size of yesterdays, so it seems that it
was a problem with the tools.
will report, if it fails again.
> FYI, there's some initial port that runs hello world here [1]. I'll
> most likely work on rebasing and improving it soon, and perhaps revive
> the discussion of the upstreaming process, if it's of interest.
> [1] http://github.com/heshamelmatary/rtems-microblaze
Thanks, I definitely will have a look at it.
so, any input welcome ;-)
All the best & thanks again
> Best,
> Hesham
> On Fri, Aug 7, 2015 at 7:50 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 7/08/2015 3:01 pm, emanuel stiebler wrote:
>>> should it still work, didn't see anything about it for a while on this
>>> list, tried yesterday, and the source-builder failed in newlib:
>> Can you please try '--jobs=none' on the RSB command line ?
>> I wonder if this is a GNU make and cgywin dll issue. If your cygwin
>> updated ?
>> Chris
>> devel mailing list
>> devel at rtems.org
> Hesham
