i386 build fail
Fri Aug 7 19:49:59 UTC 2015
On 8/7/2015 2:25 PM, Gedare Bloom wrote:
>   This screenshot appears to show results from running apt.
> What guide are you following to try to build rtems? The best guide is
> the GSoC getting started guide on our Trac wiki, first you may want to
> follow it exactly to build the sparc/sis, and then switch the
> architecture with i386 and the bsp with pc386.
And it looks like you are installing Debian packages. There have never
been officially released binaries in .deb format.
Now the project has moved to having people use the RTEMS Source Builder
(https://git.rtems.org/rtems-source-builder/) to build the tools from
source. This makes it possible to support a much wider variety of
host operating systems and versions.
The GSOC Getting Started has good instructions.
> Gedare
> On Fri, Aug 7, 2015 at 3:12 PM, punit vara <punitvara at gmail.com> wrote:
>> I have tried to build rtems-i386 in my laptop .I am using Ubuntu 15.04
>> 64-bit .I have tried 5-6 times but all times build fail error.So please help
>> to fix this error.
>> Please find the attachment of error screenshot
