[PATCH] lwIP configuration & build files
Ragunath ragunath3252 at gmail.com
Sun Aug 9 09:43:43 UTC 2015
Patch to build lwip with RTEMS Resource builder. It builds the lwip sources and creates a library.
 rtems/config/4.11/net/lwip.bset  | 20 +++++++++++++++
 rtems/config/net/lwip-1-1.cfg    | 27 ++++++++++++++++++++
 source-builder/config/lwip-1.cfg | 54 ++++++++++++++++++++++++++++++++++++++++
 3 files changed, 101 insertions(+)
 create mode 100644 rtems/config/4.11/net/lwip.bset
 create mode 100644 rtems/config/net/lwip-1-1.cfg
 create mode 100644 source-builder/config/lwip-1.cfg
diff --git a/rtems/config/4.11/net/lwip.bset b/rtems/config/4.11/net/lwip.bset
new file mode 100644
index 0000000..71f7841
--- /dev/null
+++ b/rtems/config/4.11/net/lwip.bset
@@ -0,0 +1,20 @@
+# Build set for LWIP
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build LWIP.
+net/lwip-1-1.cfg
diff --git a/rtems/config/net/lwip-1-1.cfg b/rtems/config/net/lwip-1-1.cfg
index 0000000..cf25963
--- /dev/null
+++ b/rtems/config/net/lwip-1-1.cfg
@@ -0,0 +1,27 @@
+#  LWIP MASTER
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# LWIP Version
+%define lwip_version lwip-c2ebf5544b4268eac9b32c7f3a689ff646d96eef
+#Will be modified to be pointing to RTEMS repo
+%define rtems_ragu_git https://raw.githubusercontent.com/ragunath3252/lwip-nodrv/master
+# Patch for RTEMS support.
+%patch add lwip %{rtems_ragu_git}/rtems.patch
+%hash  md5 rtems.patch 489c0def3a89e538fb526a5396bf27ca
+# LWIP Build configuration
+%include %{_configdir}/lwip-1.cfg
diff --git a/source-builder/config/lwip-1.cfg b/source-builder/config/lwip-1.cfg
index 0000000..a90fde1
--- /dev/null
+++ b/source-builder/config/lwip-1.cfg
@@ -0,0 +1,54 @@
+# LWIP MASTER  Version 1. commit -- c2ebf5544b4268eac9b32c7f3a689ff646d96eef
+# This configuration file configure's, make's and install's LWIP.
+%define release 1
+%endif
+Name:      lwip-%{lwip_version}-%{_host}-%{release}
+Summary:   Light weight TCP/IP stack
+Version:   %{lwip_version}
+Release:   %{release}
+URL: 	   http://git.savannah.gnu.org/cgit/lwip.git
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# LWIP Source
+%source set lwip git://git.sv.gnu.org/lwip.git?fetch?reset=hard?branch=master?checkout=c2ebf5544b4268eac9b32c7f3a689ff646d96eef
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_lwip="%{lwip_version}"
+  %source setup lwip -q -n %{lwip_version}
+  %patch setup lwip -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+  cd ${build_top}/%{lwip_version}
+  export RTEMS_MAKEFILE_PATH=%{_exec_prefix}
+  %{__make} all
+#  cd ${build_top}
+#%install
+  build_top=$(pwd)/%{lwip_version}
+  %{__make} install
1.9.1
