[PATCH] RTEMS specific changes for lwIP
Ragunath
ragunath3252 at gmail.com
Sun Aug 9 09:45:52 UTC 2015
.gitignore | 1 +
Makefile | 170 +++++++++++
ports/include/arch/cc.h | 123 ++++++++
ports/include/arch/perf.h | 38 +++
ports/include/arch/sys_arch.h | 59 ++++
ports/include/lwipopts.h | 178 ++++++++++++
ports/sys_arch.c | 663 ++++++++++++++++++++++++++++++++++++++++++
src/include/lwip/opt.h | 2 +-
8 files changed, 1233 insertions(+), 1 deletion(-)
create mode 100644 .gitignore
create mode 100644 Makefile
create mode 100755 ports/include/arch/cc.h
create mode 100755 ports/include/arch/perf.h
create mode 100644 ports/include/arch/sys_arch.h
create mode 100755 ports/include/lwipopts.h
create mode 100644 ports/sys_arch.c
diff --git a/.gitignore b/.gitignore
new file mode 100644
index 0000000..c81beb4
--- /dev/null
+++ b/.gitignore
@@ -0,0 +1 @@
+o-optimize/*
diff --git a/Makefile b/Makefile
index 0000000..0cbae64
--- /dev/null
+++ b/Makefile
@@ -0,0 +1,170 @@
+include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
+include $(RTEMS_CUSTOM)
+include $(PROJECT_ROOT)/make/leaf.cfg
+#### CONFIG ####################################################################
+#For debugging symbols add -DLWIP_DEBUG
+# COMPILER/LINKER
+CFLAGS+=-g -O2 \
+ -Wall
+# OUTPUT
+LWIP_EXEC=lwip
+#### PATHS #####################################################################
+# LWIP
+LWIP_PATH=.
+LWIP_SRC_PATH=$(LWIP_PATH)/src
+LWIP_API_PATH=$(LWIP_SRC_PATH)/api
+LWIP_CORE_PATH=$(LWIP_SRC_PATH)/core
+LWIP_INCL_PATH=$(LWIP_SRC_PATH)/include
+LWIP_NETIF_PATH=$(LWIP_SRC_PATH)/netif
+# ARCH
+LWIPARCH_PATH=$(LWIP_PATH)/ports
+LWIPARCH_SRC_PATH=$(LWIPARCH_PATH)
+LWIPARCH_INCL_PATH=$(LWIPARCH_PATH)/include
+# DRIVER
+LWIPDRIVER_PATH=$(LWIP_PATH)/ports
+LWIPDRIVER_SRC_PATH=$(LWIPDRIVER_PATH)/netif
+LWIPDRIVER_INCL_PATH=$(LWIPDRIVER_PATH)/include/netif
+#### SOURCES ###################################################################
+## CORE
+CORE_SRC=$(wildcard $(LWIP_CORE_PATH)/*.c)
+## IPv4
+IPV4_SRC=$(wildcard $(LWIP_CORE_PATH)/ipv4/*.c)
+## IPv6
+IPV6_SRC=$(wildcard $(LWIP_CORE_PATH)/ipv6/*.c)
+## SNMP
+SNMP_SRC=$(wildcard $(LWIP_CORE_PATH)/snmp/*.c)
+## API
+API_SRC=$(wildcard $(LWIP_API_PATH)/*.c )
+## NETIF
+NETIF_SRC=$(wildcard $(LWIP_NETIF_PATH)/*.c) \
+ $(wildcard $(LWIP_NETIF_PATH)/ppp/*.c) \
+ $(wildcard $(LWIP_NETIF_PATH)/ppp/polarssl/*.c)
+ARCH_SRC=$(wildcard $(LWIPARCH_SRC_PATH)/*.c)
+# DRIVER
+DRIVER_SRC=$(wildcard $(LWIPDRIVER_SRC_PATH)/*.c ) \
+ $(wildcard $(LWIPDRIVER_SRC_PATH)/*.S )
+SOURCES = $(DRIVER_SRC) $(SNMP_SRC)\
+ $(CORE_SRC) $(IPV4_SRC) $(API_SRC) $(NETIF_SRC) $(ARCH_SRC)
+#### HEADERS ###################################################################
+## CORE
+CORE_H=$(LWIP_INCL_PATH)
+## IPv4
+#IPV4_H=$(LWIP_INCL_PATH)/ipv4
+## IPv6
+#IPV6_H=$(LWIP_INCL_PATH)/ipv6
+## POSIX
+POSIX_H=$(LWIP_INCL_PATH)/posix
+##POSIX_SYS
+POSIX_SYS_H=$(LWIP_INCL_PATH)/posix/sys
+## NETIF
+NETIF_H=$(LWIP_INCL_PATH)/netif
+NETIF_H_PPP=$(LWIP_INCL_PATH)/netif/ppp
+NETIF_H_PPP_POLARSSL=$(LWIP_INCL_PATH)/netif/ppp/polarssl
+## ARCH
+ARCH_H=$(LWIPARCH_INCL_PATH)
+## DRIVER
+DRIVER_H=$(LWIPDRIVER_INCL_PATH)
+# HEADERS
+HEADERS=-I$(CORE_H) -I$(POSIX_H) -I$(POSIX_SYS_H) -I$(NETIF_H) \
+ -I$(NETIF_H_PPP) -I$(NETIF_H_PPP_POLARSSL) -I$(ARCH_H) \
+ -I$(DRIVER_H)
+BIN=${ARCH}/$(LWIP_EXEC).bin
+LIB=${ARCH}/lib$(LWIP_EXEC).a
+# optional managers required
+MANAGERS=all
+# C source names
+CSRCS=$(filter %.c ,$(SOURCES))
+COBJS=$(patsubst %.c,${ARCH}/%.o,$(notdir $(CSRCS)))
+ASMSRCS=$(filter %.S , $(SOURCES))
+ASMOBJS=$(patsubst %.S,${ARCH}/%.o,$(notdir $(ASMSRCS)))
+OBJS=$(COBJS) $(ASMOBJS)
+all:${ARCH} $(LIB)
+$(LIB): $(OBJS)
+ $(AR) rcs $@ $^
+${ARCH}/%.o: $(LWIP_CORE_PATH)/%.c
+ ${COMPILE.c} $(AM_CPPFLAGS) $(AM_CXXFLAGS) -o $@ $<
+${ARCH}/%.o: $(LWIP_CORE_PATH)/ipv4/%.c
+${ARCH}/%.o: $(LWIP_CORE_PATH)/ipv6/%.c
+${ARCH}/%.o: $(LWIP_CORE_PATH)/snmp/%.c
+${ARCH}/%.o: $(LWIP_API_PATH)/%.c
+${ARCH}/%.o: $(LWIP_NETIF_PATH)/%.c
+${ARCH}/%.o: $(LWIP_NETIF_PATH)/ppp/%.c
+${ARCH}/%.o: $(LWIP_NETIF_PATH)/ppp/polarssl/%.c
+${ARCH}/%.o: $(LWIPARCH_SRC_PATH)/%.c
+${ARCH}/%.o: $(LWIPDRIVER_SRC_PATH)/%.S
+${ARCH}/%.o: $(LWIPDRIVER_SRC_PATH)/%.c
+INSTALL_DIR=$(RTEMS_MAKEFILE_PATH)/lwip
+install:
+ rm -rf $(INSTALL_DIR)
+ mkdir -p $(INSTALL_DIR)/include
+ mkdir -p $(INSTALL_DIR)/lib
+ cp $(LIB) $(INSTALL_DIR)/lib
+ cp -r $(CORE_H) $(INSTALL_DIR)
+ cp $(LWIPARCH_INCL_PATH)/lwipopts.h $(INSTALL_DIR)/include
+ cp -r $(LWIPARCH_INCL_PATH)/arch $(INSTALL_DIR)/include
+CPPFLAGS+=$(HEADERS)
diff --git a/ports/include/arch/cc.h b/ports/include/arch/cc.h
new file mode 100755
index 0000000..04ec89f
--- /dev/null
+++ b/ports/include/arch/cc.h
@@ -0,0 +1,123 @@
+ * Copyright (c) 2001-2003 Swedish Institute of Computer Science.
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. The name of the author may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+ * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+ * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+ * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+ * This file is part of the lwIP TCP/IP stack.
+ * Author: Adam Dunkels <adam at sics.se>
+#ifndef __CC_H__
+#define __CC_H__
+typedef unsigned char u8_t;
+typedef signed char s8_t;
+typedef unsigned short u16_t;
+typedef signed short s16_t;
+typedef unsigned int u32_t;
+typedef signed int s32_t;
+typedef u32_t mem_ptr_t;
+#ifndef BYTE_ORDER
+#define BYTE_ORDER LITTLE_ENDIAN
+#endif
+#if defined(__arm__) && defined(__ARMCC_VERSION)
+ // Setup PACKing macros for KEIL/RVMDK Tools
+ #define PACK_STRUCT_BEGIN __packed
+ #define PACK_STRUCT_STRUCT
+ #define PACK_STRUCT_END
+ #define PACK_STRUCT_FIELD(x) x
+#elif defined (__IAR_SYSTEMS_ICC__)
+ // Setup PACKing macros for IAR Tools
+ #define PACK_STRUCT_USE_INCLUDES
+#elif defined (__TMS470__)
+#else
+ // Setup PACKing macros for GCC Tools
+ #define PACK_STRUCT_STRUCT __attribute__ ((__packed__))
+#endif
+#ifdef LWIP_CACHE_ENABLED
+ * Make the PBUF POOL cacheline aligned.
+#ifdef __IAR_SYSTEMS_ICC__
+#pragma data_alignment=SOC_CACHELINE_SIZE_BYTES
+extern u8_t memp_memory_PBUF_POOL_base[];
+#else /*By default, GCC */
+extern u8_t memp_memory_PBUF_POOL_base[] __attribute__ ((aligned (SOC_CACHELINE_SIZE_BYTES)));
+#endif
+#endif
+/* Define (sn)printf formatters for these lwIP types */
+#define X8_F "02x"
+#define U16_F "u"
+#define S16_F "d"
+#define X16_F "x"
+#define U32_F "u"
+#define S32_F "d"
+#define X32_F "x"
+#include <stdio.h>
+#include <stdlib.h>
+#include <bsp.h>
+#define LWIP_PLATFORM_DIAG(x) do { \
+ printk("[%s - %s - %d] ", __PRETTY_FUNCTION__, __FILE__, __LINE__); \
+ printk x; \
+ } while(0)
+#ifdef LWIP_DEBUG //DEBUG
+extern void __error__(char *pcFilename, unsigned long ulLine);
+#define LWIP_PLATFORM_ASSERT(expr) printk("[%s - %s - %d] ", expr , __FILE__, __LINE__);
+ //if(!(expr))
+ //__error__(__FILE__, __LINE__);
+#else
+#endif
+#endif /* __CC_H__ */
diff --git a/ports/include/arch/perf.h b/ports/include/arch/perf.h
index 0000000..d754157
--- /dev/null
+++ b/ports/include/arch/perf.h
@@ -0,0 +1,38 @@
+ * OF SUCH DAMAGE.
+#ifndef __PERF_H__
+#define __PERF_H__
+#define PERF_START /* null definition */
+#define PERF_STOP(x) /* null definition */
+#endif /* __PERF_H__ */
diff --git a/ports/include/arch/sys_arch.h b/ports/include/arch/sys_arch.h
index 0000000..32f0d99
--- /dev/null
+++ b/ports/include/arch/sys_arch.h
@@ -0,0 +1,59 @@
+ * OF SUCH DAMAGE.
+#ifndef LWIP_ARCH_SYS_ARCH_H
+#define LWIP_ARCH_SYS_ARCH_H
+#include <errno.h>
+#define SYS_MBOX_NULL NULL
+#define SYS_SEM_NULL NULL
+typedef u32_t sys_prot_t;
+struct sys_sem;
+typedef struct sys_sem * sys_sem_t;
+#define sys_sem_valid(sem) (((sem) != NULL) && (*(sem) != NULL))
+#define sys_sem_set_invalid(sem) do { if((sem) != NULL) { *(sem) = NULL; }}while(0)
+/* let sys.h use binary semaphores for mutexes */
+#define LWIP_COMPAT_MUTEX 1
+struct sys_mbox;
+typedef struct sys_mbox *sys_mbox_t;
+#define sys_mbox_valid(mbox) ((*(mbox) != NULL))
+#define sys_mbox_set_invalid(mbox) do { if((mbox) != NULL) { *(mbox) = NULL; }}while(0)
+struct sys_thread;
+typedef struct sys_thread * sys_thread_t;
+#endif /* LWIP_ARCH_SYS_ARCH_H */
diff --git a/ports/include/lwipopts.h b/ports/include/lwipopts.h
index 0000000..169ba46
--- /dev/null
+++ b/ports/include/lwipopts.h
@@ -0,0 +1,178 @@
+ * \file lwipopts.h - Configuration options for lwIP
+ * Copyright (c) 2010 Texas Instruments Incorporated
+ * Copyright (c) 2001-2004 Swedish Institute of Computer Science.
+ * OF SUCH DAMAGE.
+#ifndef __LWIPOPTS_H__
+#define __LWIPOPTS_H__
+** CONFIGURATIONS
+** The below macro should be defined for using lwIP with cache. For cache
+** enabling, pbuf pool shall be cache line aligned. This is done by using
+** separate pool for each memory. The alignment of pbuf pool to cache line
+** size is done in /ports/cpsw/include/arch/cc.h.
+/*#define LWIP_CACHE_ENABLED*/
+#define SOC_CACHELINE_SIZE_BYTES 64 /* Number of bytes in
+ a cache line */
+** The timeout for DHCP completion. lwIP library will wait for DHCP
+** completion for (LWIP_DHCP_TIMEOUT / 100) seconds.
+#define LWIP_DHCP_TIMEOUT 500
+** The number of times DHCP is attempted. Each time, the library will wait
+** for (LWIP_DHCP_TIMEOUT / 100) seconds for DHCP completion.
+#define NUM_DHCP_TRIES 5
+#define LWIP_ETHERNET 1
+#define LWIP_ARP 1
+** lwIP SPECIFIC DEFINITIONS - To be used by lwIP stack
+#define HOST_TMR_INTERVAL 0
+#define DYNAMIC_HTTP_HEADERS
+** Platform specific locking
+#define SYS_LIGHTWEIGHT_PROT 1
+#define NO_SYS 0
+#define NO_SYS_NO_TIMERS 0
+** Memory Options
+#define MEM_ALIGNMENT 4
+#define MEM_SIZE (256 * 1024) /* 128K */
+#define MEMP_NUM_PBUF 96
+#define MEMP_NUM_TCP_PCB 32
+#define MEMP_NUM_TCP_SEG 32
+#define PBUF_POOL_SIZE 512
+#define MEMP_SEPARATE_POOLS 1 /* We want the pbuf
+ pool cache line
+ aligned*/
+#endif
+#define MEMP_NUM_SYS_TIMEOUT (LWIP_TCP + IP_REASSEMBLY + LWIP_ARP + (2*LWIP_DHCP) + LWIP_AUTOIP + LWIP_IGMP + LWIP_DNS + PPP_SUPPORT)
+** IP Options
+#define IP_REASSEMBLY 0
+#define IP_FRAG 0
+** DHCP Options
+#define LWIP_DHCP 1
+#define DHCP_DOES_ARP_CHECK 0
+** Auto IP Options
+#define LWIP_AUTOIP 1
+#define LWIP_DHCP_AUTOIP_COOP ((LWIP_DHCP) && (LWIP_AUTOIP))
+** TCP Options
+#define TCP_MSS 1500
+#define TCP_WND (8 * TCP_MSS)
+#define TCP_SND_BUF (8 * TCP_MSS)
+#define TCP_OVERSIZE TCP_MSS
+** PBUF Options
+#define PBUF_LINK_HLEN 14
+#define PBUF_POOL_BUFSIZE 1520 /* + size of struct pbuf
+ shall be cache line
+ aligned be enabled */
+#define ETH_PAD_SIZE 0
+#define LWIP_NETCONN 1
+** Socket Options
+#define LWIP_SOCKET 1
+** Debugging options
+#define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_OFF
+#define LWIP_DBG_TYPES_ON (LWIP_DBG_ON | LWIP_DBG_TRACE \
+ |LWIP_DBG_STATE | LWIP_DBG_FRESH)
+#define DHCP_DEBUG LWIP_DBG_OFF
+#define NETIF_DEBUG LWIP_DBG_OFF
+#define IP_DEBUG LWIP_DBG_OFF
+#define UDP_DEBUG LWIP_DBG_OFF
+#define ETHARP_DEBUG LWIP_DBG_OFF
+#define SYS_DEBUG LWIP_DBG_OFF
+#define RAW_DEBUG LWIP_DBG_OFF
+#define MEM_DEBUG LWIP_DBG_OFF
+#define MEMP_DEBUG LWIP_DBG_OFF
+#define PBUF_DEBUG LWIP_DBG_OFF
+#define TCPIP_DEBUG LWIP_DBG_OFF
+#define APP_DEBUG LWIP_DBG_OFF
+#define SOCKETS_DEBUG LWIP_DBG_OFF
+#define LWIP_STATS 0
+#define LWIP_STATS_DISPLAY 0
+#define LWIP_STATS_POSIX 0
+ * LWIP_COMPAT_SOCKETS==1: Enable BSD-style sockets functions names.
+ * (only used if you use sockets.c)
+#define LWIP_COMPAT_SOCKETS 0
+#define LWIP_TIMEVAL_PRIVATE 0
+ #define LWIP_RAW 0
+#endif /* __LWIPOPTS_H__ */
diff --git a/ports/sys_arch.c b/ports/sys_arch.c
index 0000000..360a4e2
--- /dev/null
+++ b/ports/sys_arch.c
@@ -0,0 +1,663 @@
+ * OF SUCH DAMAGE.
+ * Wed Apr 17 16:05:29 EDT 2002 (James Roth)
+ * - Fixed an unlikely sys_thread_new() race condition.
+ * - Made current_thread() work with threads which where
+ * not created with sys_thread_new(). This includes
+ * the main thread and threads made with pthread_create().
+ * - Catch overflows where more than SYS_MBOX_SIZE messages
+ * are waiting to be read. The sys_mbox_post() routine
+ * will block until there is more room instead of just
+ * leaking messages.
+#include <string.h>
+#include <sys/time.h>
+#include <sys/types.h>
+#include <unistd.h>
+#include <pthread.h>
+#include "lwip/opt.h"
+#include "lwip/sys.h"
+#include "lwip/stats.h"
+#include "lwip/debug.h"
+#define UMAX(a, b) ((a) > (b) ? (a) : (b))
+static struct timeval starttime;
+#if !NO_SYS
+static struct sys_thread *threads = NULL;
+static pthread_mutex_t threads_mutex = PTHREAD_MUTEX_INITIALIZER;
+struct sys_mbox_msg {
+ struct sys_mbox_msg *next;
+ void *msg;
+#define SYS_MBOX_SIZE 128
+struct sys_mbox {
+ int first, last;
+ void *msgs[SYS_MBOX_SIZE];
+ struct sys_sem *not_empty;
+ struct sys_sem *not_full;
+ struct sys_sem *mutex;
+ int wait_send;
+struct sys_sem {
+ unsigned int c;
+ pthread_cond_t cond;
+ pthread_mutex_t mutex;
+struct sys_thread {
+ struct sys_thread *next;
+ pthread_t pthread;
+#if SYS_LIGHTWEIGHT_PROT
+static pthread_mutex_t lwprot_mutex = PTHREAD_MUTEX_INITIALIZER;
+static pthread_t lwprot_thread = (pthread_t)0xDEAD;
+static int lwprot_count = 0;
+#endif /* SYS_LIGHTWEIGHT_PROT */
+static struct sys_sem *sys_sem_new_internal(u8_t count);
+static void sys_sem_free_internal(struct sys_sem *sem);
+static u32_t cond_wait(pthread_cond_t * cond, pthread_mutex_t * mutex,
+ u32_t timeout);
+introduce_thread(pthread_t id)
+ struct sys_thread *thread = NULL;
+ thread = (struct sys_thread *)malloc(sizeof(struct sys_thread));
+ if (thread != NULL) {
+ pthread_mutex_lock(&threads_mutex);
+ thread->next = threads;
+ thread->pthread = id;
+ threads = thread;
+ pthread_mutex_unlock(&threads_mutex);
+ return thread;
+sys_thread_t
+sys_thread_new(const char *name, lwip_thread_fn function, void *arg, int stacksize, int prio)
+ int code;
+ int rc;
+ pthread_t tmp;
+ pthread_attr_t attr;
+ struct sys_thread *st = NULL;
+ LWIP_UNUSED_ARG(name);
+ LWIP_UNUSED_ARG(stacksize);
+ LWIP_UNUSED_ARG(prio);
+ /* Alloc a new pthread with the specified stack size. */
+ if(stacksize > 0) {
+ rc = pthread_attr_init(&attr);
+ if (rc != 0) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_thread_new: pthread_attr_init error = %d\n", rc));
+ return NULL;
+ rc = pthread_attr_setstacksize(&attr, stacksize);
+ if (rc != 0) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_thread_new: pthread_attr_setstacksize error = %d\n", rc));
+ pthread_attr_destroy(&attr);
+ return NULL;
+ pthread_attr_setinheritsched(&attr, PTHREAD_EXPLICIT_SCHED);
+ pthread_attr_setschedpolicy(&attr, SCHED_RR);
+ code = pthread_create(&tmp, &attr, (void *(*)(void *)) function, arg);
+ } else {
+ code = pthread_create(&tmp, NULL, (void *(*)(void *)) function, arg);
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_thread_new: thread created [name:%s|stacksize:%d|prio:%d|addr:0x%x]\n",
+ name, stacksize, prio, (uint)tmp));
+ if (0 == code) {
+ st = introduce_thread(tmp);
+ if (NULL == st) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_thread_new: failed to introduce %d, st = %p\n",
+ code, (void*)st));
+ abort();
+ } else {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_thread_new: introduced %d, st = %p\n",
+ return st;
+void sys_thread_signal(sys_thread_t thread, int signal)
+ /* Check received parameters. */
+ if(thread == NULL) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_thread_signal: could not send signal to thread. thread = NULL\n"));
+ return;
+ /* Send signal. */
+ pthread_kill(thread->pthread, signal);
+err_t
+sys_mbox_new(struct sys_mbox **mb, int size)
+ struct sys_mbox *mbox = NULL;
+ LWIP_UNUSED_ARG(size);
+ mbox = (struct sys_mbox *)malloc(sizeof(struct sys_mbox));
+ if (mbox == NULL) {
+ SYS_STATS_INC(mbox.err);
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_new: could not create mbox\n"));
+ return ERR_MEM;
+ mbox->first = mbox->last = 0;
+ mbox->not_empty = sys_sem_new_internal(0);
+ mbox->not_full = sys_sem_new_internal(0);
+ mbox->mutex = sys_sem_new_internal(1);
+ mbox->wait_send = 0;
+ SYS_STATS_INC_USED(mbox);
+ if((mbox->not_empty == NULL) || (mbox->not_full == NULL) || (mbox->mutex == NULL)) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_new: could not create mbox internals\n"));
+ sys_mbox_free(&mbox);
+ return ERR_MEM;
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_new: mbox created [not_empty:%X|not_full:%X|mutex:%X] \n",
+ mbox->not_empty, mbox->not_full, mbox->mutex));
+ *mb = mbox;
+ return ERR_OK;
+void
+sys_mbox_free(struct sys_mbox **mb)
+ if ((mb != NULL) && (*mb != SYS_MBOX_NULL)) {
+ struct sys_mbox *mbox = *mb;
+ sys_arch_sem_wait(&mbox->mutex, 0);
+ sys_sem_free_internal(mbox->not_empty);
+ sys_sem_free_internal(mbox->not_full);
+ sys_sem_free_internal(mbox->mutex);
+ mbox->not_empty = mbox->not_full = mbox->mutex = NULL;
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_free: mbox 0x%lx\n", mbox));
+ free(mbox);
+ SYS_STATS_DEC(mbox.used);
+err_t
+sys_mbox_trypost(struct sys_mbox **mb, void *msg)
+ u8_t first;
+ struct sys_mbox *mbox;
+ LWIP_ASSERT("invalid mbox", (mb != NULL) && (*mb != NULL));
+ mbox = *mb;
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_trypost: start"));
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_trypost: mbox %p msg %p\n",
+ (void *)mbox, (void *)msg));
+ if ((mbox->last + 1) >= (mbox->first + SYS_MBOX_SIZE)) {
+ sys_sem_signal(&mbox->mutex);
+ return ERR_MEM;
+ mbox->msgs[mbox->last % SYS_MBOX_SIZE] = msg;
+ if (mbox->last == mbox->first) {
+ first = 1;
+ } else {
+ first = 0;
+ mbox->last++;
+ if (first) {
+ sys_sem_signal(&mbox->not_empty);
+ return ERR_OK;
+void
+sys_mbox_post(struct sys_mbox **mb, void *msg)
+ u8_t first;
+ mbox = *mb;
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_post: mbox %p msg %p\n", (void *)mbox, (void *)msg));
+ while ((mbox->last + 1) >= (mbox->first + SYS_MBOX_SIZE)) {
+ mbox->wait_send++;
+ sys_arch_sem_wait(&mbox->not_full, 0);
+ mbox->wait_send--;
+ first = 1;
+ } else {
+ first = 0;
+ mbox->last++;
+ if (first) {
+u32_t
+sys_arch_mbox_tryfetch(struct sys_mbox **mb, void **msg)
+ mbox = *mb;
+ if (mbox->first == mbox->last) {
+ return SYS_MBOX_EMPTY;
+ if (msg != NULL) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_tryfetch: mbox %p msg %p\n", (void *)mbox, *msg));
+ *msg = mbox->msgs[mbox->first % SYS_MBOX_SIZE];
+ else{
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_tryfetch: mbox %p, null msg\n", (void *)mbox));
+ mbox->first++;
+ if (mbox->wait_send) {
+ sys_sem_signal(&mbox->not_full);
+ return 0;
+u32_t
+sys_arch_mbox_fetch(struct sys_mbox **mb, void **msg, u32_t timeout)
+ u32_t time_needed = 0;
+ mbox = *mb;
+ /* The mutex lock is quick so we don't bother with the timeout
+ stuff here. */
+ while (mbox->first == mbox->last) {
+ /* We block while waiting for a mail to arrive in the mailbox. We
+ must be prepared to timeout. */
+ if (timeout != 0) {
+ time_needed = sys_arch_sem_wait(&mbox->not_empty, timeout);
+ if (time_needed == SYS_ARCH_TIMEOUT) {
+ return SYS_ARCH_TIMEOUT;
+ } else {
+ sys_arch_sem_wait(&mbox->not_empty, 0);
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_fetch: mbox %p msg %p\n", (void *)mbox, *msg));
+ else{
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_mbox_fetch: mbox %p, null msg\n", (void *)mbox));
+ mbox->first++;
+ return time_needed;
+sys_sem_new_internal(u8_t count)
+ struct sys_sem *sem = NULL;
+ int rc;
+ sem = (struct sys_sem *)malloc(sizeof(struct sys_sem));
+ if (sem != NULL) {
+ sem->c = count;
+ rc = pthread_cond_init(&(sem->cond), NULL);
+ if(rc != 0) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_sem_new_internal: pthread_cond_init error = %d\n", rc));
+ return NULL;
+ rc = pthread_mutex_init(&(sem->mutex), NULL);
+ if(rc != 0) {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_sem_new_internal: pthread_mutex_init error = %d\n", rc));
+ SYS_STATS_INC(mutex.err);
+ pthread_cond_destroy(&(sem->cond));
+ return NULL;
+ SYS_STATS_INC_USED(mutex);
+ SYS_STATS_INC_USED(sem);
+ } else {
+ LWIP_DEBUGF(SYS_DEBUG, ("sys_sem_new_internal: could not create semaphore\n"));
+ SYS_STATS_INC(sem.err);
+ return sem;
+err_t
+sys_sem_new(struct sys_sem **sem, u8_t count)
+ *sem = sys_sem_new_internal(count);
+ if (*sem == NULL) {
+ return ERR_MEM;
+ return ERR_OK;
+static u32_t
+cond_wait(pthread_cond_t *cond, pthread_mutex_t *mutex, u32_t timeout)
+ time_t tdiff;
+ time_t sec, usec;
+ struct timeval rtime1, rtime2;
+ struct timespec ts;
+ int retval;
+ if (timeout > 0) {
+ /* Get a timestamp and add the timeout value. */
+ gettimeofday(&rtime1, NULL);
+ sec = rtime1.tv_sec;
+ usec = rtime1.tv_usec;
+ usec += timeout % 1000 * 1000;
+ sec += (int)(timeout / 1000) + (int)(usec / 1000000);
+ usec = usec % 1000000;
+ ts.tv_nsec = usec * 1000;
+ ts.tv_sec = sec;
+ retval = pthread_cond_timedwait(cond, mutex, &ts);
+ if (retval == ETIMEDOUT) {
+ } else {
+ /* Calculate for how long we waited for the cond. */
+ gettimeofday(&rtime2, NULL);
+ tdiff = (rtime2.tv_sec - rtime1.tv_sec) * 1000 +
+ (rtime2.tv_usec - rtime1.tv_usec) / 1000;
+ if (tdiff <= 0) {
+ return 0;
+ return (u32_t)tdiff;
+ } else {
+ pthread_cond_wait(cond, mutex);
+ return 0;
+u32_t
+sys_arch_sem_wait(struct sys_sem **s, u32_t timeout)
+ struct sys_sem *sem;
+ LWIP_ASSERT("invalid sem", (s != NULL) && (*s != NULL));
+ sem = *s;
+ pthread_mutex_lock(&(sem->mutex));
+ while (sem->c <= 0) {
+ time_needed = cond_wait(&(sem->cond), &(sem->mutex), timeout);
+ pthread_mutex_unlock(&(sem->mutex));
+ } else {
+ cond_wait(&(sem->cond), &(sem->mutex), 0);
+ sem->c--;
+ return (u32_t)time_needed;
+void
+sys_sem_signal(struct sys_sem **s)
+ sem = *s;
+ sem->c++;
+ if (sem->c > 1) {
+ sem->c = 1;
+ pthread_cond_broadcast(&(sem->cond));
+static void
+sys_sem_free_internal(struct sys_sem *sem)
+ if(sem != NULL) {
+ pthread_mutex_destroy(&(sem->mutex));
+ SYS_STATS_DEC(mutex.used);
+ SYS_STATS_DEC(sem.used);
+ free(sem);
+void
+sys_sem_free(struct sys_sem **sem)
+ if ((sem != NULL) && (*sem != SYS_SEM_NULL)) {
+ sys_sem_free_internal(*sem);
+#endif /* !NO_SYS */
+u32_t
+sys_now(void)
+ struct timeval tv;
+ u32_t sec, usec, msec;
+ gettimeofday(&tv, NULL);
+ sec = (u32_t)(tv.tv_sec - starttime.tv_sec);
+ usec = (u32_t)(tv.tv_usec - starttime.tv_usec);
+ msec = sec * 1000 + usec / 1000;
+ return msec;
+void
+sys_init(void)
+ gettimeofday(&starttime, NULL);
+/** sys_prot_t sys_arch_protect(void)
+This optional function does a "fast" critical region protection and returns
+the previous protection level. This function is only called during very short
+critical regions. An embedded system which supports ISR-based drivers might
+want to implement this function by disabling interrupts. Task-based systems
+might want to implement this by using a mutex or disabling tasking. This
+function should support recursive calls from the same task or interrupt. In
+other words, sys_arch_protect() could be called while already protected. In
+that case the return value indicates that it is already protected.
+sys_arch_protect() is only required if your port is supporting an operating
+system.
+sys_prot_t
+sys_arch_protect(void)
+ /* Note that for the UNIX port, we are using a lightweight mutex, and our
+ * own counter (which is locked by the mutex). The return code is not actually
+ * used. */
+ if (lwprot_thread != pthread_self())
+ /* We are locking the mutex where it has not been locked before *
+ * or is being locked by another thread */
+ pthread_mutex_lock(&lwprot_mutex);
+ lwprot_thread = pthread_self();
+ lwprot_count = 1;
+ else
+ /* It is already locked by THIS thread */
+ lwprot_count++;
+ return 0;
+/** void sys_arch_unprotect(sys_prot_t pval)
+This optional function does a "fast" set of critical region protection to the
+value specified by pval. See the documentation for sys_arch_protect() for
+more information. This function is only required if your port is supporting
+an operating system.
+void
+sys_arch_unprotect(sys_prot_t pval)
+ LWIP_UNUSED_ARG(pval);
+ if (lwprot_thread == pthread_self())
+ if (--lwprot_count == 0)
+ lwprot_thread = (pthread_t) 0xDEAD;
+ pthread_mutex_unlock(&lwprot_mutex);
+#ifndef MAX_JIFFY_OFFSET
+#define MAX_JIFFY_OFFSET ((~0U >> 1)-1)
+#endif
+#ifndef HZ
+#define HZ 100
+#endif
+u32_t
+sys_jiffies(void)
+ unsigned long sec;
+ long usec;
+ gettimeofday(&tv,NULL);
+ sec = tv.tv_sec - starttime.tv_sec;
+ usec = tv.tv_usec;
+ if (sec >= (MAX_JIFFY_OFFSET / HZ))
+ return MAX_JIFFY_OFFSET;
+ usec += 1000000L / HZ - 1;
+ usec /= 1000000L / HZ;
+ return HZ * sec + usec;
+#if PPP_DEBUG
+#include <stdarg.h>
+void ppp_trace(int level, const char *format, ...)
+ va_list args;
+ (void)level;
+ va_start(args, format);
+ vprintf(format, args);
+ va_end(args);
+#endif
diff --git a/src/include/lwip/opt.h b/src/include/lwip/opt.h
index 481bf76..89d509d 100644
--- a/src/include/lwip/opt.h
+++ b/src/include/lwip/opt.h
@@ -1324,7 +1324,7 @@
* sys_thread_new() when the thread is created.
#ifndef TCPIP_THREAD_STACKSIZE
-#define TCPIP_THREAD_STACKSIZE 0
+#define TCPIP_THREAD_STACKSIZE 2048
#endif
1.9.1
