GSoC 2015 RPi USB Support
Gedare Bloom gedare at gwu.edu
Mon Aug 10 01:45:15 UTC 2015
The one other thing I will say, to repeat myself, is that I'd like you
to clean-up your code on github so that you have clean commit history
without any merge commits.
Gedare
On Sun, Aug 9, 2015 at 7:09 PM, Gedare Bloom <gedare at gwu.edu> wrote:
> There isn't much action here on Fridays or Weekends normally. Have you
> gotten around to writing up your blog post describing the various
> steps you have tried? It's a little hard to help you to debug without
> understanding the full scope of what you have been trying to do.
> Gedare
> On Sun, Aug 9, 2015 at 12:36 PM, Yurii Shevtsov <ungetch at gmail.com> wrote:
>> Ping! Any news?
>> 2015-08-07 0:41 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>> These macroses are placed here
>>> https://github.com/gtament/rtems-libbsd/blob/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace/rtemsbsd/include/machine/rtems-bsd-sysinit.h
>>> And of course I added proper lines to specific testsuites, like
>>> init01. And IRC, without this macro driver just won't be linked
>>> 2015-08-07 0:34 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>> On 8/6/2015 4:29 PM, Yurii Shevtsov wrote:
>>>>> Isn't this line enough?
>>>>> SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus)
>>>> I was looking in nexus-devices.h since that is BSP specific.
>>>> I wasn't expecting a generic macro.
>>>> But where is that referenced? That is a macro that somewhere
>>>> should be referencing so it is expanded.
>>>> I would expect to see
>>>> below the nexus definition in nexus-devices.h.
>>>> Anyway, it is never being expanded so that definition has no impact.
>>>> Whether it will work and find the right bus, is another issue
>>>> but it isn't putting code in for sure. :)
>>>> I have the pc386 to the point where it the RTEMS nexus device
>>>> is trying to find em on the legacy bus but it is configured
>>>> as being on pci. Need to run down that or trick it to work.
>>>> But the probe is working.
>>>> --joel
>>>>> 2015-08-07 0:23 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>> On 8/6/2015 4:16 PM, Yurii Shevtsov wrote:
>>>>>>> 2015-08-07 0:08 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>>>> On August 6, 2015 3:57:40 PM CDT, Yurii Shevtsov <ungetch at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> What do you mean by "getting pulled"?
>>>>>>>> As I understood things, you had a linked executable but an empty
>>>>>>>> section.
>>>>>>>> Just curious if your devices were showing up at all.
>>>>>>> Yes, exactly. If you mean is probe function being executed, the answer
>>>>>>> is
>>>>>>> ''no"
>>>>>> You have to associate the drivers with a nexus bus.  Something like this
>>>>>> SYSINIT_DRIVER_REFERENCE(mmc, dw_mmc);
>>>>>> SYSINIT_DRIVER_REFERENCE(mmcsd, mmc);
>>>>>> That's from the Altera Cyclone.
>>>>>> You only configured a nexus device and didn't hang anything off it.
>>>>>>>>> 2015-08-06 23:48 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>>>>>> On 8/6/2015 3:42 PM, Yurii Shevtsov wrote:
>>>>>>>>>>> 2015-08-06 23:36 GMT+03:00 Joel Sherrill
>>>>>>>>>>>> On 8/6/2015 3:22 PM, Yurii Shevtsov wrote:
>>>>>>>>>>>>> Ping! Any news?
>>>>>>>>>>>> The people with experience with the libbsd code is quite small. :(
>>>>>>>>>>>>> 2015-08-05 18:29 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>>>>>>>>>>>> The problem is that rtemsroset.bsd.nexus.content doesn't exist in
>>>>>>>>>>>>>> final elf. If I change driver's name in
>>>>>>>>> RTEMS_BSD_DEFINE_NEXUS_DEVICE
>>>>>>>>>>>>>> macro, linker will throw an error
>>>>>>>>>>>>>> (.rtemsroset.bsd.nexus.content+0x10): undefined reference to
>>>>>>>>> '%wrong
>>>>>>>>>>>>>> driver's name%'. Otherwise with correct name - no
>>>>>>>>> errors(warnings) and
>>>>>>>>>>>>>> no nexus.content section. How can you explain this??
>>>>>>>>>>>> The RTEMS_BSD_DEFINE_NEXUS_DEVICE() macro must reference a
>>>>>>>>> bus/mexus,
>>>>>>>>>>>> not a regular device driver. I would expect a nexus device for the
>>>>>>>>> Pi
>>>>>>>>>>>> to be in
>>>>>>>>> https://github.com/freebsd/freebsd/tree/master/sys/arm/broadcom/bcm2835
>>>>>>>>>>>> or pointed to by a file in there.
>>>>>>>>>>>> Look at the configuration for the various bsps in nexus-devices.h
>>>>>>>>> and
>>>>>>>>>>>> then at the source the macros refer to.
>>>>>>>>>>>> Raspberry Pi source will have to be imported from the FreeBSD tree.
>>>>>>>>>>> Of course, I did it!)
>>>>>>>>> https://github.com/gtament/rtems-libbsd/commit/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace
>>>>>>>>>> Is bcm283x_dwcotg* getting pulled into your build?
>>>>>>>>>>>>>> 2015-08-02 18:02 GMT+03:00 Joel Sherrill
>>>>>>>>>>>>>>> On 08/01/2015 04:00 PM, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>> During debugging of compiled Nexus module(driver) I found out
>>>>>>>>> that
>>>>>>>>>>>>>>>> content which suppose to be created in
>>>>>>>>> RTEMS_BSD_DEFINE_SET(nexus,
>>>>>>>>>>>>>>>> rtems_bsd_device) is empty, That should mean that either it is
>>>>>>>>> not
>>>>>>>>>>>>>>>> found or cannot be read. Please, let me know why empty content
>>>>>>>>> is not
>>>>>>>>>>>>>>>> create any error message and in what situation it can be empty.
>>>>>>>>>>>>>>> Sebastian just added the pc386 to the nexus-devices file. Make
>>>>>>>>> sure
>>>>>>>>>>>>>>> the bsp.h is tripping the conditional logic in that file to get
>>>>>>>>> the Pi
>>>>>>>>>>>>>>> path as a minimum.
>>>>>>>>>>>>>>> Then you are going to need to add the appropriate devices for Pi
>>>>>>>>>>>>>>> USB.  If the Pi  doesn't have one of the standard USB
>>>>>>>>> controllers,
>>>>>>>>>>>>>>> then
>>>>>>>>>>>>>>> you will have to import the source for it from FreeBSD.
>>>>>>>>>>>>>>> The pc386 is stuck at the point where it detects the NIC
>>>>>>>>> configured
>>>>>>>>>>>>>>> but needs resources. I am going to try to debug that.
>>>>>>>>>>>>>>>> 2015-06-29 19:50 GMT+03:00 Yurii Shevtsov<ungetch at gmail.com>:
>>>>>>>>>>>>>>>>> So, it is empty.
>>>>>>>>>>>>>>>>>       .rtemsroset.bsd.nexus.begin
>>>>>>>>>>>>>>>>>                      0x001104bc        0x0
>>>>>>>>>>>>>>>>> ./libbsd.a(rtems-bsd-nexus.c.16.o)
>>>>>>>>>>>>>>>>>                      0x001104bc
>>>>>>>>> _bsd__start_set_nexus
>>>>>>>>>>>>>>>>>       .rtemsroset.bsd.nexus.end
>>>>>>>>>>>>>>>>>                      0x001104bc        0x0
>>>>>>>>>>>>>>>>>                      0x001104bc
>>>>>>>>> _bsd__stop_set_nexus
>>>>>>>>>>>>>>>>> What will be next step? My repo:
>>>>>>>>>>>>>>>>> 2015-06-29 9:43 GMT+03:00 Sebastian
>>>>>>>>>>>>>>>>> Huber<sebastian.huber at embedded-brains.de>:
>>>>>>>>>>>>>>>>>> You can debug this issue on Qemu. The Nexus childes are
>>>>>>>>> registered
>>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>>> a
>>>>>>>>>>>>>>>>>> linker set, so I would consult the linker map file.  It
>>>>>>>>> should look
>>>>>>>>>>>>>>>>>> like
>>>>>>>>>>>>>>>>>> this:
>>>>>>>>>>>>>>>>>>                      0x000000000052ef7c        0x0
>>>>>>>>>>>>>>>>>> libbsd.a(rtems-bsd-nexus.o)
>>>>>>>>>>>>>>>>>>                      0x000000000052ef7c _bsd__start_set_nexus
>>>>>>>>>>>>>>>>>>                      0x000000000052ef7c       0x28
>>>>>>>>>>>>>>>>>> testsuite/telnetd01/test_main.o
>>>>>>>>>>>>>>>>>>                      0x000000000052efa4        0x0
>>>>>>>>>>>>>>>>>>                      0x000000000052efa4 _bsd__stop_set_nexus
>>>>>>>>>>>>>>>>>> The  .rtemsroset.bsd.nexus.content section must be non-empty.
>>>>>>>>>>>>>>>>>> On 27/06/15 16:39, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>>>>> Any ideas? Maybe I did some typo? Maybe you can compile and
>>>>>>>>> try it
>>>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>>>> qemu?
>>>>>>>>>>>>>>>>>>> 2015-06-26 17:05 GMT+03:00 Yurii
>>>>>>>>>>>>>>>>>>>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber
>>>>>>>>>>>>>>>>>>>>> I would set a break point to nexus_probe(). In this loop
>>>>>>>>>>>>>>>>>>>>>           SET_FOREACH(nd, nexus) {
>>>>>>>>>>>>>>>>>>>>>               device_add_child(dev, nd->name, nd->unit);
>>>>>>>>>>>>>>>>>>>>> your device must get added. I would also set break points
>>>>>>>>> to the
>>>>>>>>>>>>>>>>>>>>> probe
>>>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>>> attach functions of your device.
>>>>>>>>>>>>>>>>>>>> Added printfs()
>>>>>>>>>>>>>>>>>>>>           printf("before setforeach\n");
>>>>>>>>>>>>>>>>>>>>               printf("setforeach: %s\n", nd->name);
>>>>>>>>>>>>>>>>>>>> Got only 'before setforeach' in console. So it doesn't step
>>>>>>>>> into
>>>>>>>>>>>>>>>>>>>> loop.
>>>>>>>>>>>>>>>>>>>> Any ideas? Also I already had printfs in my driver's probe
>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>> attach,
>>>>>>>>>>>>>>>>>>>> also got no output.
>>>>>>>>>>>>>>>>>>>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>>>>>>>> This is ping message, with small update: the problem is
>>>>>>>>> not on
>>>>>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>>>>>> linking stage, driver is linked to testsuite (checked
>>>>>>>>> with
>>>>>>>>>>>>>>>>>>>>>> objdump)
>>>>>>>>>>>>>>>>>>>>>> 2015-06-21 17:57 GMT+03:00 Yurii
>>>>>>>>>>>>>>>>>>>>>>> Hello)
>>>>>>>>>>>>>>>>>>>>>>> Now I have apps from libbsd testsuite running. But DWC
>>>>>>>>> OTG
>>>>>>>>>>>>>>>>>>>>>>> driver
>>>>>>>>>>>>>>>>>>>>>>> doesn't
>>>>>>>>>>>>>>>>>>>>>>> loads.
>>>>>>>>>>>>>>>>>>>>>>> I added this lines to init01/test_main.c:
>>>>>>>>>>>>>>>>>>>>>>> +SYSINIT_NEED_USB_CORE;
>>>>>>>>>>>>>>>>>>>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
>>>>>>>>>>>>>>>>>>>>>>> (I know it's bad hardcode)
>>>>>>>>>>>>>>>>>>>>>>> If I run it. I get only this:
>>>>>>>>>>>>>>>>>>>>>>>          nexus0:<RTEMS Nexus device>
>>>>>>>>>>>>>>>>>>>>>>>          devctl: +nexus0 at   on root0
>>>>>>>>>>>>>>>>>>>>>>>          devctl: !system=IFNET subsystem=lo0 type=ATTACH
>>>>>>>>>>>>>>>>>>>>>>> Of course, I modified
>>>>>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from
>>>>>>>>> working
>>>>>>>>>>>>>>>>>>>>>>> DTS)
>>>>>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>>>>> did other nexus-related changes to drivers. You can find
>>>>>>>>>>>>>>>>>>>>>>> changes
>>>>>>>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>>>>>>>>> repo https://github.com/gtament/rtems-libbsd/
>>>>>>>>>>>>>>>>>>>>>>> So I need some kind of code review, please.
>>>>>>>>>>>>>>>>>>>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs
>>>>>>>>>>>>>>>>>>>>>>> without
>>>>>>>>>>>>>>>>>>>>>>> any
>>>>>>>>>>>>>>>>>>>>>>> output.
>>>>>>>>>>>>>>>>>>>>>>> Thanks in advance!
>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>>>>>>>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>>>>>>>>>>>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>>>>>>>>>>>>>>>>> Phone   : +49 89 189 47 41-16
>>>>>>>>>>>>>>>>>>>>> Fax     : +49 89 189 47 41-09
>>>>>>>>>>>>>>>>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>>>>>>>>>>>>>>> PGP     : Public key available on request.
>>>>>>>>>>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im
>>>>>>>>> Sinne des
>>>>>>>>>>>>>>>>>>>>> EHUG.
>>>>>>>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>>>>>>>> des
>>>>>>>>>>>>>>>>>> EHUG.
>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>> -- Joel Sherrill
>>>>>>>>>>>>>>> Ask me about RTEMS: a free RTOS
>>>>>>>>>>>>>>> Support and Training Available
>>>>>>>>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>>>>>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>>>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>>>>>>> Support Available                (256) 722-9985
>>>>>>>> --joel
>> devel mailing list
>> devel at rtems.org
