GSoC 2015 RPi USB Support
Yurii Shevtsov ungetch at gmail.com
Mon Aug 10 22:17:53 UTC 2015
I finally found the solution. All I need is to add
#include <bsp/nexus-devices.h> to a testsuite source
Now I have a rtemsroset.bsd.nexus.content section
2015-08-07 0:41 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
> These macroses are placed here
> https://github.com/gtament/rtems-libbsd/blob/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace/rtemsbsd/include/machine/rtems-bsd-sysinit.h
> And of course I added proper lines to specific testsuites, like
> init01. And IRC, without this macro driver just won't be linked
> 2015-08-07 0:34 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>> On 8/6/2015 4:29 PM, Yurii Shevtsov wrote:
>>> Isn't this line enough?
>>> SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus)
>> I was looking in nexus-devices.h since that is BSP specific.
>> I wasn't expecting a generic macro.
>> But where is that referenced? That is a macro that somewhere
>> should be referencing so it is expanded.
>> I would expect to see
>> below the nexus definition in nexus-devices.h.
>> Anyway, it is never being expanded so that definition has no impact.
>> Whether it will work and find the right bus, is another issue
>> but it isn't putting code in for sure. :)
>> I have the pc386 to the point where it the RTEMS nexus device
>> is trying to find em on the legacy bus but it is configured
>> as being on pci. Need to run down that or trick it to work.
>> But the probe is working.
>> --joel
>>> 2015-08-07 0:23 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>> On 8/6/2015 4:16 PM, Yurii Shevtsov wrote:
>>>>> 2015-08-07 0:08 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>> On August 6, 2015 3:57:40 PM CDT, Yurii Shevtsov <ungetch at gmail.com>
>>>>>> wrote:
>>>>>>> What do you mean by "getting pulled"?
>>>>>> As I understood things, you had a linked executable but an empty
>>>>>> section.
>>>>>> Just curious if your devices were showing up at all.
>>>>> Yes, exactly. If you mean is probe function being executed, the answer
>>>>> is
>>>>> ''no"
>>>> You have to associate the drivers with a nexus bus.  Something like this
>>>> SYSINIT_DRIVER_REFERENCE(mmc, dw_mmc);
>>>> SYSINIT_DRIVER_REFERENCE(mmcsd, mmc);
>>>> That's from the Altera Cyclone.
>>>> You only configured a nexus device and didn't hang anything off it.
>>>>>>> 2015-08-06 23:48 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>>>> On 8/6/2015 3:42 PM, Yurii Shevtsov wrote:
>>>>>>>>> 2015-08-06 23:36 GMT+03:00 Joel Sherrill
>>>>>>>>>> On 8/6/2015 3:22 PM, Yurii Shevtsov wrote:
>>>>>>>>>>> Ping! Any news?
>>>>>>>>>> The people with experience with the libbsd code is quite small. :(
>>>>>>>>>>> 2015-08-05 18:29 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>>>>>>>>>> The problem is that rtemsroset.bsd.nexus.content doesn't exist in
>>>>>>>>>>>> final elf. If I change driver's name in
>>>>>>> RTEMS_BSD_DEFINE_NEXUS_DEVICE
>>>>>>>>>>>> macro, linker will throw an error
>>>>>>>>>>>> (.rtemsroset.bsd.nexus.content+0x10): undefined reference to
>>>>>>> '%wrong
>>>>>>>>>>>> driver's name%'. Otherwise with correct name - no
>>>>>>> errors(warnings) and
>>>>>>>>>>>> no nexus.content section. How can you explain this??
>>>>>>>>>> The RTEMS_BSD_DEFINE_NEXUS_DEVICE() macro must reference a
>>>>>>> bus/mexus,
>>>>>>>>>> not a regular device driver. I would expect a nexus device for the
>>>>>>> Pi
>>>>>>>>>> to be in
>>>>>>> https://github.com/freebsd/freebsd/tree/master/sys/arm/broadcom/bcm2835
>>>>>>>>>> or pointed to by a file in there.
>>>>>>>>>> Look at the configuration for the various bsps in nexus-devices.h
>>>>>>> and
>>>>>>>>>> then at the source the macros refer to.
>>>>>>>>>> Raspberry Pi source will have to be imported from the FreeBSD tree.
>>>>>>>>> Of course, I did it!)
>>>>>>> https://github.com/gtament/rtems-libbsd/commit/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace
>>>>>>>> Is bcm283x_dwcotg* getting pulled into your build?
>>>>>>>>>>>> 2015-08-02 18:02 GMT+03:00 Joel Sherrill
>>>>>>>>>>>>> On 08/01/2015 04:00 PM, Yurii Shevtsov wrote:
>>>>>>>>>>>>>> During debugging of compiled Nexus module(driver) I found out
>>>>>>> that
>>>>>>>>>>>>>> content which suppose to be created in
>>>>>>> RTEMS_BSD_DEFINE_SET(nexus,
>>>>>>>>>>>>>> rtems_bsd_device) is empty, That should mean that either it is
>>>>>>> not
>>>>>>>>>>>>>> found or cannot be read. Please, let me know why empty content
>>>>>>> is not
>>>>>>>>>>>>>> create any error message and in what situation it can be empty.
>>>>>>>>>>>>> Sebastian just added the pc386 to the nexus-devices file. Make
>>>>>>> sure
>>>>>>>>>>>>> the bsp.h is tripping the conditional logic in that file to get
>>>>>>> the Pi
>>>>>>>>>>>>> path as a minimum.
>>>>>>>>>>>>> Then you are going to need to add the appropriate devices for Pi
>>>>>>>>>>>>> USB.  If the Pi  doesn't have one of the standard USB
>>>>>>> controllers,
>>>>>>>>>>>>> then
>>>>>>>>>>>>> you will have to import the source for it from FreeBSD.
>>>>>>>>>>>>> The pc386 is stuck at the point where it detects the NIC
>>>>>>> configured
>>>>>>>>>>>>> but needs resources. I am going to try to debug that.
>>>>>>>>>>>>>> 2015-06-29 19:50 GMT+03:00 Yurii Shevtsov<ungetch at gmail.com>:
>>>>>>>>>>>>>>> So, it is empty.
>>>>>>>>>>>>>>>       .rtemsroset.bsd.nexus.begin
>>>>>>>>>>>>>>>                      0x001104bc        0x0
>>>>>>>>>>>>>>> ./libbsd.a(rtems-bsd-nexus.c.16.o)
>>>>>>>>>>>>>>>                      0x001104bc
>>>>>>> _bsd__start_set_nexus
>>>>>>>>>>>>>>>       .rtemsroset.bsd.nexus.end
>>>>>>>>>>>>>>>                      0x001104bc        0x0
>>>>>>>>>>>>>>>                      0x001104bc
>>>>>>> _bsd__stop_set_nexus
>>>>>>>>>>>>>>> What will be next step? My repo:
>>>>>>>>>>>>>>> 2015-06-29 9:43 GMT+03:00 Sebastian
>>>>>>>>>>>>>>> Huber<sebastian.huber at embedded-brains.de>:
>>>>>>>>>>>>>>>> You can debug this issue on Qemu. The Nexus childes are
>>>>>>> registered
>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>> a
>>>>>>>>>>>>>>>> linker set, so I would consult the linker map file.  It
>>>>>>> should look
>>>>>>>>>>>>>>>> like
>>>>>>>>>>>>>>>> this:
>>>>>>>>>>>>>>>>                      0x000000000052ef7c        0x0
>>>>>>>>>>>>>>>> libbsd.a(rtems-bsd-nexus.o)
>>>>>>>>>>>>>>>>                      0x000000000052ef7c _bsd__start_set_nexus
>>>>>>>>>>>>>>>>                      0x000000000052ef7c       0x28
>>>>>>>>>>>>>>>> testsuite/telnetd01/test_main.o
>>>>>>>>>>>>>>>>                      0x000000000052efa4        0x0
>>>>>>>>>>>>>>>>                      0x000000000052efa4 _bsd__stop_set_nexus
>>>>>>>>>>>>>>>> The  .rtemsroset.bsd.nexus.content section must be non-empty.
>>>>>>>>>>>>>>>> On 27/06/15 16:39, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>>> Any ideas? Maybe I did some typo? Maybe you can compile and
>>>>>>> try it
>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>> qemu?
>>>>>>>>>>>>>>>>> 2015-06-26 17:05 GMT+03:00 Yurii
>>>>>>>>>>>>>>>>>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber
>>>>>>>>>>>>>>>>>>> I would set a break point to nexus_probe(). In this loop
>>>>>>>>>>>>>>>>>>>           SET_FOREACH(nd, nexus) {
>>>>>>>>>>>>>>>>>>>               device_add_child(dev, nd->name, nd->unit);
>>>>>>>>>>>>>>>>>>> your device must get added. I would also set break points
>>>>>>> to the
>>>>>>>>>>>>>>>>>>> probe
>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>> attach functions of your device.
>>>>>>>>>>>>>>>>>> Added printfs()
>>>>>>>>>>>>>>>>>>           printf("before setforeach\n");
>>>>>>>>>>>>>>>>>>               printf("setforeach: %s\n", nd->name);
>>>>>>>>>>>>>>>>>> Got only 'before setforeach' in console. So it doesn't step
>>>>>>> into
>>>>>>>>>>>>>>>>>> loop.
>>>>>>>>>>>>>>>>>> Any ideas? Also I already had printfs in my driver's probe
>>>>>>> and
>>>>>>>>>>>>>>>>>> attach,
>>>>>>>>>>>>>>>>>> also got no output.
>>>>>>>>>>>>>>>>>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>>>>>> This is ping message, with small update: the problem is
>>>>>>> not on
>>>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>>>> linking stage, driver is linked to testsuite (checked
>>>>>>> with
>>>>>>>>>>>>>>>>>>>> objdump)
>>>>>>>>>>>>>>>>>>>> 2015-06-21 17:57 GMT+03:00 Yurii
>>>>>>>>>>>>>>>>>>>>> Hello)
>>>>>>>>>>>>>>>>>>>>> Now I have apps from libbsd testsuite running. But DWC
>>>>>>> OTG
>>>>>>>>>>>>>>>>>>>>> driver
>>>>>>>>>>>>>>>>>>>>> doesn't
>>>>>>>>>>>>>>>>>>>>> loads.
>>>>>>>>>>>>>>>>>>>>> I added this lines to init01/test_main.c:
>>>>>>>>>>>>>>>>>>>>> +SYSINIT_NEED_USB_CORE;
>>>>>>>>>>>>>>>>>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
>>>>>>>>>>>>>>>>>>>>> (I know it's bad hardcode)
>>>>>>>>>>>>>>>>>>>>> If I run it. I get only this:
>>>>>>>>>>>>>>>>>>>>>          nexus0:<RTEMS Nexus device>
>>>>>>>>>>>>>>>>>>>>>          devctl: +nexus0 at   on root0
>>>>>>>>>>>>>>>>>>>>>          devctl: !system=IFNET subsystem=lo0 type=ATTACH
>>>>>>>>>>>>>>>>>>>>> Of course, I modified
>>>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from
>>>>>>> working
>>>>>>>>>>>>>>>>>>>>> DTS)
>>>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>>> did other nexus-related changes to drivers. You can find
>>>>>>>>>>>>>>>>>>>>> changes
>>>>>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>>>>>>> repo https://github.com/gtament/rtems-libbsd/
>>>>>>>>>>>>>>>>>>>>> So I need some kind of code review, please.
>>>>>>>>>>>>>>>>>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs
>>>>>>>>>>>>>>>>>>>>> without
>>>>>>>>>>>>>>>>>>>>> any
>>>>>>>>>>>>>>>>>>>>> output.
>>>>>>>>>>>>>>>>>>>>> Thanks in advance!
>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>>>>>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>>>>>>>>>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>>>>>>>>>>>>>>> Phone   : +49 89 189 47 41-16
>>>>>>>>>>>>>>>>>>> Fax     : +49 89 189 47 41-09
>>>>>>>>>>>>>>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>>>>>>>>>>>>> PGP     : Public key available on request.
>>>>>>>>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im
>>>>>>> Sinne des
>>>>>>>>>>>>>>>>>>> EHUG.
>>>>>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>>>>>> des
>>>>>>>>>>>>>>>> EHUG.
>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>> -- Joel Sherrill
>>>>>>>>>>>>> Ask me about RTEMS: a free RTOS
>>>>>>>>>>>>> Support and Training Available
>>>>>>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>>>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>>>>> Support Available                (256) 722-9985
>>>>>> --joel
