[PATCH 2/2] GPIO driver for BBB
Ketul Shah ketulshah1993 at gmail.com
Tue Aug 11 10:02:04 UTC 2015
diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
new file mode 100644
index 0000000..6426d21
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
@@ -0,0 +1,468 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief Support for the BeagleBone Black.
+ * Copyright (c) 2015 Ketul Shah <ketulshah1993 at gmail.com>
+/* BSP specific function definitions for BeagleBone Black.
+ * It is totally beased on Generic GPIO API definition.
+ * For more details related to GPIO API please have a
+ * look at libbbsp/shared/include/gpio.h
+#include <bsp/beagleboneblack.h>
+#include <bsp/irq-generic.h>
+#include <bsp/gpio.h>
+#include <bsp/bbb-gpio.h>
+#include <libcpu/am335x.h>
+#include <assert.h>
+#include <stdlib.h>
+static const uint32_t gpio_bank_addrs[] =
+  { AM335X_GPIO0_BASE,
+  	AM335X_GPIO1_BASE,
+  	AM335X_GPIO2_BASE,
+  	AM335X_GPIO3_BASE };
+static const rtems_vector_number gpio_bank_vector[] =
+  { AM335X_INT_GPIOINT0A,
+  	AM335X_INT_GPIOINT1A,
+  	AM335X_INT_GPIOINT2A,
+  	AM335X_INT_GPIOINT3A };
+/* Macro for the gpio pin not having control module offset mapping */
+#define CONF_NOT_DEFINED 0x00
+/* Mapping of gpio pin nuber to the  Control module mapped register offset */
+static const uint32_t gpio_pad_conf [GPIO_BANK_COUNT][BSP_GPIO_PINS_PER_BANK] =
+  /* GPIO Module 0 */
+  { CONF_NOT_DEFINED,             /* GPIO0[0] */
+    CONF_NOT_DEFINED,             /* GPIO0[1] */
+    AM335X_CONF_SPI0_SCLK,        /* GPIO0[2] */
+    AM335X_CONF_SPI0_D0,          /* GPIO0[3] */
+    AM335X_CONF_SPI0_D1,          /* GPIO0[4] */
+    AM335X_CONF_SPI0_CS0,         /* GPIO0[5] */
+    CONF_NOT_DEFINED,             /* GPIO0[6] */
+    CONF_NOT_DEFINED,             /* GPIO0[7] */
+    AM335X_CONF_LCD_DATA12,       /* GPIO0[8] */
+    AM335X_CONF_LCD_DATA13,       /* GPIO0[9] */
+    AM335X_CONF_LCD_DATA14,       /* GPIO0[10] */
+    AM335X_CONF_LCD_DATA15,       /* GPIO0[11] */
+    AM335X_CONF_UART1_CTSN,       /* GPIO0[12] */
+    AM335X_CONF_UART1_RTSN,       /* GPIO0[13] */
+    AM335X_CONF_UART1_RXD,        /* GPIO0[14] */
+    AM335X_CONF_UART1_TXD,        /* GPIO0[15] */
+    CONF_NOT_DEFINED,             /* GPIO0[16] */
+    CONF_NOT_DEFINED,             /* GPIO0[17] */
+    CONF_NOT_DEFINED,             /* GPIO0[18] */
+    CONF_NOT_DEFINED,             /* GPIO0[19] */
+    CONF_NOT_DEFINED,             /* GPIO0[20] */
+    CONF_NOT_DEFINED,             /* GPIO0[21] */
+    AM335X_CONF_GPMC_AD8,         /* GPIO0[22] */
+    AM335X_CONF_GPMC_AD9,         /* GPIO0[23] */
+    CONF_NOT_DEFINED,             /* GPIO0[24] */
+    CONF_NOT_DEFINED,             /* GPIO0[25] */
+    AM335X_CONF_GPMC_AD10,        /* GPIO0[26] */
+    AM335X_CONF_GPMC_AD11,        /* GPIO0[27] */
+    CONF_NOT_DEFINED,             /* GPIO0[28] */
+    CONF_NOT_DEFINED,             /* GPIO0[29] */
+    AM335X_CONF_GPMC_WAIT0,       /* GPIO0[30] */
+    AM335X_CONF_GPMC_WPN          /* GPIO0[31] */ },
+  /* GPIO Module 1 */
+  { AM335X_CONF_GPMC_AD0,         /* GPIO1[0] */
+    AM335X_CONF_GPMC_AD1,         /* GPIO1[1] */
+    AM335X_CONF_GPMC_AD2,         /* GPIO1[2] */
+    AM335X_CONF_GPMC_AD3,         /* GPIO1[3] */
+    AM335X_CONF_GPMC_AD4,         /* GPIO1[4] */
+    AM335X_CONF_GPMC_AD5,         /* GPIO1[5] */
+    AM335X_CONF_GPMC_AD6,         /* GPIO1[6] */
+    AM335X_CONF_GPMC_AD7,         /* GPIO1[7] */
+    CONF_NOT_DEFINED,             /* GPIO1[8] */
+    CONF_NOT_DEFINED,             /* GPIO1[9] */
+    CONF_NOT_DEFINED,             /* GPIO1[10] */
+    CONF_NOT_DEFINED,             /* GPIO1[11] */
+    AM335X_CONF_GPMC_AD12,        /* GPIO1[12] */
+    AM335X_CONF_GPMC_AD13,        /* GPIO1[13] */
+    AM335X_CONF_GPMC_AD14,        /* GPIO1[14] */
+    AM335X_CONF_GPMC_AD15,        /* GPIO1[15] */
+    AM335X_CONF_GPMC_A0,          /* GPIO1[16] */
+    AM335X_CONF_GPMC_A1,          /* GPIO1[17] */
+    AM335X_CONF_GPMC_A2,          /* GPIO1[18] */
+    AM335X_CONF_GPMC_A3,          /* GPIO1[19] */
+    CONF_NOT_DEFINED,             /* GPIO1[20] */
+    CONF_NOT_DEFINED,             /* GPIO1[21] */
+    CONF_NOT_DEFINED,             /* GPIO1[22] */
+    CONF_NOT_DEFINED,             /* GPIO1[23] */
+    CONF_NOT_DEFINED,             /* GPIO1[24] */
+    CONF_NOT_DEFINED,             /* GPIO1[25] */
+    CONF_NOT_DEFINED,             /* GPIO1[26] */
+    CONF_NOT_DEFINED,             /* GPIO1[27] */
+    AM335X_CONF_GPMC_BEN1,        /* GPIO1[28] */
+    AM335X_CONF_GPMC_CSN0,        /* GPIO1[29] */
+    AM335X_CONF_GPMC_CSN1,        /* GPIO1[30] */
+    AM335X_CONF_GPMC_CSN2         /* GPIO1[31] */ },
+  /* GPIO Module 2 */
+  { CONF_NOT_DEFINED,             /* GPIO2[0] */
+    AM335X_CONF_GPMC_CLK,         /* GPIO2[1] */
+    AM335X_CONF_GPMC_ADVN_ALE,    /* GPIO2[2] */
+    AM335X_CONF_GPMC_OEN_REN,     /* GPIO2[3] */
+    AM335X_CONF_GPMC_WEN,         /* GPIO2[4] */
+    AM335X_CONF_GPMC_BEN0_CLE,    /* GPIO2[5] */
+    AM335X_CONF_LCD_DATA0,        /* GPIO2[6] */
+    AM335X_CONF_LCD_DATA1,        /* GPIO2[7] */
+    AM335X_CONF_LCD_DATA2,        /* GPIO2[8] */
+    AM335X_CONF_LCD_DATA3,        /* GPIO2[9] */
+    AM335X_CONF_LCD_DATA4,        /* GPIO2[10] */
+    AM335X_CONF_LCD_DATA5,        /* GPIO2[11] */
+    AM335X_CONF_LCD_DATA6,        /* GPIO2[12] */
+    AM335X_CONF_LCD_DATA7,        /* GPIO2[13] */
+    AM335X_CONF_LCD_DATA8,        /* GPIO2[14] */
+    AM335X_CONF_LCD_DATA9,        /* GPIO2[15] */
+    AM335X_CONF_LCD_DATA10,       /* GPIO2[16] */
+    AM335X_CONF_LCD_DATA11,       /* GPIO2[17] */
+    CONF_NOT_DEFINED,             /* GPIO2[18] */
+    CONF_NOT_DEFINED,             /* GPIO2[19] */
+    CONF_NOT_DEFINED,             /* GPIO2[20] */
+    CONF_NOT_DEFINED,             /* GPIO2[21] */
+    AM335X_CONF_LCD_VSYNC,        /* GPIO2[22] */
+    AM335X_CONF_LCD_HSYNC,        /* GPIO2[23] */
+    AM335X_CONF_LCD_PCLK,         /* GPIO2[24] */
+    AM335X_CONF_LCD_AC_BIAS_EN    /* GPIO2[25] */ },
+  /* GPIO Module 3 */
+  { CONF_NOT_DEFINED,             /* GPIO3[0] */
+    CONF_NOT_DEFINED,             /* GPIO3[1] */
+    CONF_NOT_DEFINED,             /* GPIO3[2] */
+    CONF_NOT_DEFINED,             /* GPIO3[3] */
+    CONF_NOT_DEFINED,             /* GPIO3[4] */
+    CONF_NOT_DEFINED,             /* GPIO3[5] */
+    CONF_NOT_DEFINED,             /* GPIO3[6] */
+    CONF_NOT_DEFINED,             /* GPIO3[7] */
+    CONF_NOT_DEFINED,             /* GPIO3[8] */
+    CONF_NOT_DEFINED,             /* GPIO3[9] */
+    CONF_NOT_DEFINED,             /* GPIO3[10] */
+    CONF_NOT_DEFINED,             /* GPIO3[11] */
+    CONF_NOT_DEFINED,             /* GPIO3[12] */
+    CONF_NOT_DEFINED,             /* GPIO3[13] */
+    AM335X_CONF_MCASP0_ACLKX,     /* GPIO3[14] */
+    AM335X_CONF_MCASP0_FSX,       /* GPIO3[15] */
+    AM335X_CONF_MCASP0_AXR0,      /* GPIO3[16] */
+    AM335X_CONF_MCASP0_AHCLKR,    /* GPIO3[17] */
+    CONF_NOT_DEFINED,             /* GPIO3[18] */
+    AM335X_CONF_MCASP0_FSR,       /* GPIO3[19] */
+    CONF_NOT_DEFINED,             /* GPIO3[20] */
+    AM335X_CONF_MCASP0_AHCLKX     /* GPIO3[21] */ }
+/* Get the address of Base Register + Offset for pad config */
+uint32_t static inline bbb_conf_reg(uint32_t bank, uint32_t pin)
+  /* Asserts if invalid pin is supplied */
+  assert(gpio_pad_conf[bank][pin] != CONF_NOT_DEFINED);
+  return (AM335X_PADCONF_BASE + gpio_pad_conf[bank][pin]);
+/* Get the value of Base Register + Offset */
+uint32_t static inline bbb_reg(uint32_t bank, uint32_t reg)
+  return REG(gpio_bank_addrs[bank] + reg);
+/* Waits a number of CPU cycles. */
+static void arm_delay(uint8_t cycles)
+  uint8_t i;
+  for ( i = 0; i < cycles; ++i ) {
+    asm volatile("nop");
+static rtems_status_code bbb_select_pin_function(
+  uint32_t bank,
+  uint32_t pin,
+  uint32_t type
+  if ( type == BBB_DIGITAL_IN ) {
+    mmio_set((gpio_bank_addrs[bank] + AM335X_GPIO_OE), BIT(pin));
+  else {
+    mmio_clear((gpio_bank_addrs[bank] + AM335X_GPIO_OE), BIT(pin));
+  return RTEMS_SUCCESSFUL;
+rtems_status_code rtems_gpio_bsp_multi_set(uint32_t bank, uint32_t bitmask)
+  mmio_set(bbb_reg(bank, AM335X_GPIO_SETDATAOUT), bitmask);
+rtems_status_code rtems_gpio_bsp_multi_clear(uint32_t bank, uint32_t bitmask)
+  mmio_set(bbb_reg(bank, AM335X_GPIO_CLEARDATAOUT), bitmask);
+uint32_t rtems_gpio_bsp_multi_read(uint32_t bank, uint32_t bitmask)
+  return (bbb_reg(bank, AM335X_GPIO_DATAIN) & bitmask);
+rtems_status_code rtems_gpio_bsp_set(uint32_t bank, uint32_t pin)
+  mmio_set((gpio_bank_addrs[bank] + AM335X_GPIO_SETDATAOUT), BIT(pin));
+rtems_status_code rtems_gpio_bsp_clear(uint32_t bank, uint32_t pin)
+  mmio_set((gpio_bank_addrs[bank] + AM335X_GPIO_CLEARDATAOUT), BIT(pin));
+uint8_t rtems_gpio_bsp_get_value(uint32_t bank, uint32_t pin)
+  return (bbb_reg(bank, AM335X_GPIO_DATAIN) & BIT(pin));
+rtems_status_code rtems_gpio_bsp_select_input(
+  uint32_t bank,
+  uint32_t pin,
+  void *bsp_specific
+  return bbb_select_pin_function(bank, pin, BBB_DIGITAL_IN);
+rtems_status_code rtems_gpio_bsp_select_output(
+  uint32_t bank,
+  uint32_t pin,
+  return bbb_select_pin_function(bank, pin, BBB_DIGITAL_OUT);
+rtems_status_code rtems_bsp_select_specific_io(
+  uint32_t bank,
+  uint32_t pin,
+  uint32_t function,
+  void *pin_data
+  return RTEMS_NOT_DEFINED;
+rtems_status_code rtems_gpio_bsp_set_resistor_mode(
+  uint32_t bank,
+  uint32_t pin,
+  rtems_gpio_pull_mode mode
+  /* Enable Pull Up/Down bit and setting Mux Mode 7 */
+  mmio_set(bbb_conf_reg(bank, pin), (BBB_PUDEN | BBB_MUXMODE(7)));
+  /* Set control signal. */
+  switch ( mode ) {
+    case PULL_UP:
+      mmio_set(bbb_conf_reg(bank, pin), BBB_PU_EN);
+      break;
+    case PULL_DOWN:
+      mmio_clear(bbb_conf_reg(bank, pin), ~BBB_PD_EN);
+      break;
+    case NO_PULL_RESISTOR:
+      mmio_clear(bbb_conf_reg(bank, pin), ~BBB_PUDDIS);
+      break;
+    default:
+      return RTEMS_UNSATISFIED;
+rtems_vector_number rtems_gpio_bsp_get_vector(uint32_t bank)
+  return gpio_bank_vector[bank];
+uint32_t rtems_gpio_bsp_interrupt_line(rtems_vector_number vector)
+  uint32_t event_status;
+  uint8_t bank_nr = 0;
+  /* Following loop will get the bank number from vector number */
+  while (bank_nr < GPIO_BANK_COUNT && vector != gpio_bank_vector[bank_nr])
+  	bank_nr++;
+  /* Retrieve the interrupt event status. */
+  event_status = bbb_reg(bank_nr, AM335X_GPIO_IRQSTATUS_0);
+  /* Clear the interrupt line. */
+  mmio_write(
+    (gpio_bank_addrs[bank_nr] + AM335X_GPIO_IRQSTATUS_0), event_status);
+  return event_status;
+rtems_status_code rtems_bsp_enable_interrupt(
+  uint32_t bank,
+  uint32_t pin,
+  rtems_gpio_interrupt interrupt
+  switch ( interrupt ) {
+    case FALLING_EDGE:
+      /* Enables asynchronous falling edge detection. */
+      mmio_set((gpio_bank_addrs[bank] + AM335X_GPIO_FALLINGDETECT), BIT(pin));
+      break;
+    case RISING_EDGE:
+      /* Enables asynchronous rising edge detection. */
+      mmio_set((gpio_bank_addrs[bank] + AM335X_GPIO_RISINGDETECT), BIT(pin));
+      break;
+    case BOTH_EDGES:
+      break;
+    case LOW_LEVEL:
+      /* Enables pin low level detection. */
+      mmio_set((gpio_bank_addrs[bank] + AM335X_GPIO_LEVELDETECT0), BIT(pin));
+      break;
+    case HIGH_LEVEL:
+      /* Enables pin high level detection. */
+      mmio_set((gpio_bank_addrs[bank] + AM335X_GPIO_LEVELDETECT1), BIT(pin));
+      break;
+    case BOTH_LEVELS:
+      break;
+    case NONE:
+    default:
+  /* The detection starts after 5 clock cycles as per AM335X TRM
+   * This period is required to clean the synchronization edge/
+   * level detection pipeline
+  arm_delay(5);
+rtems_status_code rtems_bsp_disable_interrupt(
+  uint32_t bank,
+  uint32_t pin,
+      /* Disables asynchronous falling edge detection. */
+      mmio_clear(
+      	(gpio_bank_addrs[bank] + AM335X_GPIO_FALLINGDETECT), BIT(pin));
+      break;
+    case RISING_EDGE:
+      /* Disables asynchronous rising edge detection. */
+      mmio_clear(
+      	(gpio_bank_addrs[bank] + AM335X_GPIO_RISINGDETECT), BIT(pin));
+      break;
+    case BOTH_EDGES:
+      mmio_clear(
+      mmio_clear(
+      break;
+    case LOW_LEVEL:
+      /* Disables pin low level detection. */
+      mmio_clear(
+      	(gpio_bank_addrs[bank] + AM335X_GPIO_LEVELDETECT0), BIT(pin));
+      break;
+    case HIGH_LEVEL:
+      /* Disables pin high level detection. */
+       mmio_clear(
+       	(gpio_bank_addrs[bank] + AM335X_GPIO_LEVELDETECT1), BIT(pin));
+      break;
+    case BOTH_LEVELS:
+      mmio_clear(
+      mmio_clear(
+      break;
+    case NONE:
+    default:
+rtems_status_code rtems_gpio_bsp_multi_select(
+  rtems_gpio_multiple_pin_select *pins,
+  uint32_t pin_count,
+  uint32_t select_bank
+  uint32_t register_address;
+  uint32_t select_register;
+  uint8_t i;
+  register_address = gpio_bank_addrs[select_bank] + AM335X_GPIO_OE;
+  select_register = REG(register_address);
+  for ( i = 0; i < pin_count; ++i ) {
+    if ( pins[i].function == DIGITAL_INPUT ) {
+      select_register |= BIT(pins[i].pin_number);
+    else if ( pins[i].function == DIGITAL_OUTPUT ) {
+      select_register &= ~BIT(pins[i].pin_number);
+    else { /* BSP_SPECIFIC function. */
+  REG(register_address) = select_register;
+rtems_status_code rtems_gpio_bsp_specific_group_operation(
+  uint32_t bank,
+  uint32_t *pins,
+  void *arg
\ No newline at end of file
