[PATCH 1/6] mailbox support for rpi bsp
桥 杨 yangqiao0505 at me.com
Tue Aug 11 15:14:25 UTC 2015
Ok
> 在 2015年8月11日,17:02,Joel Sherrill <joel.sherrill at oarcorp.com> 写道:
> Can you rebase these and send again?
> Previous patches have changed at least bsp.h, Makefile.am
> and preinstall.am.
> --joel
>> On 8/10/2015 7:47 AM, YANG QIAO wrote:
>> From: YANG Qiao <yangqiao0505 at me.com>
>>  c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  4 ++
>>  c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h | 32 +++++++++++++
>>  .../libbsp/arm/raspberrypi/include/raspberrypi.h   | 49 +++++++++++++++++++
>>  c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c    | 56 ++++++++++++++++++++++
>>  c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |  4 ++
>>  5 files changed, 145 insertions(+)
>>  create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
>>  create mode 100644 c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> index c6133df..70bc01d 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> @@ -43,6 +43,7 @@ include_bsp_HEADERS += ../shared/include/arm-release-id.h
>>  include_bsp_HEADERS += include/irq.h
>>  include_bsp_HEADERS += include/mmu.h
>>  include_bsp_HEADERS += include/usart.h
>> +include_bsp_HEADERS += include/mailbox.h
>>  include_bsp_HEADERS += include/raspberrypi.h
>>  include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
>> @@ -123,6 +124,9 @@ libbsp_a_SOURCES += misc/timer.c
>>  # I2C
>> +# Mailbox
>> +libbsp_a_SOURCES += misc/mailbox.c
>>  # Cache
>>  libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>>  libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
>> new file mode 100644
>> index 0000000..e6cb0f8
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
>> @@ -0,0 +1,32 @@
>> + * @file
>> + * @ingroup raspberrypi
>> + * @brief mailbox support.
>> + * Copyright (c) 2015 Yang Qiao
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.org/license/LICENSE
>> +#ifndef LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
>> +#define LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif /* __cplusplus */
>> +extern unsigned int  raspberrypi_mailbox_read(unsigned int channel);
>> +extern void raspberrypi_mailbox_write(unsigned int channel, unsigned int data);
>> +#ifdef __cplusplus
>> +#endif  /* LIBBSP_ARM_RASPBERRYPI_MAILBOX_H */
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
>> index c33e22a..dc1be07 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
>> @@ -8,6 +8,8 @@
>> + * based on work by:
>>   * Copyright (c) 2013 Alan Cudmore.
>> @@ -208,6 +210,53 @@
>> + * @name Mailbox Registers
>> +#define BCM2835_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
>> +#define BCM2835_MBOX_PEEK (BCM2835_MBOX_BASE+0x10)
>> +#define BCM2835_MBOX_READ (BCM2835_MBOX_BASE+0x00)
>> +#define BCM2835_MBOX_WRITE (BCM2835_MBOX_BASE+0x20)
>> +#define BCM2835_MBOX_STATUS (BCM2835_MBOX_BASE+0x18)
>> +#define BCM2835_MBOX_SENDER (BCM2835_MBOX_BASE+0x14)
>> +#define BCM2835_MBOX_CONFIG (BCM2835_MBOX_BASE+0x1C)
>> +#define BCM2835_MBOX_FULL (BCM2835_MBOX_BASE+0x80000000)
>> +#define BCM2835_MBOX_EMPTY (BCM2835_MBOX_BASE+0x40000000)
>> +* @name Mailbox Channels
>> +/* Power Manager channel */
>> +#define BCM2835_MBOX_CHANNEL_PM         0
>> +/* Framebuffer channel */
>> +#define BCM2835_MBOX_CHANNEL_FB         1
>> + /* Virtual UART channel */
>> +#define BCM2835_MBOX_CHANNEL_VUART      2
>> + /* VCHIQ channel */
>> +#define BCM2835_MBOX_CHANNEL_VCHIQ      3
>> + /* LEDs channel */
>> +#define BCM2835_MBOX_CHANNEL_LED 4
>> + /* Button channel */
>> +#define BCM2835_MBOX_CHANNEL_BUTTON     5
>> + /* Touch screen channel */
>> +#define BCM2835_MBOX_CHANNEL_TOUCHS     6
>> +/* Property tags (ARM <-> VC) channel */
>> +#define BCM2835_MBOX_CHANNEL_PROP_AVC   8
>> + /* Property tags (VC <-> ARM) channel */
>> +#define BCM2835_MBOX_CHANNEL_PROP_VCA   9
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
>> index 0000000..8ec730a
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
>> @@ -0,0 +1,56 @@
>> + * @file
>> +#include <stdint.h>
>> +#include <stdbool.h>
>> +#include <bsp/raspberrypi.h>
>> +#include <bsp/mailbox.h>
>> +#define BCM2835_MBOX_DATA_MASK(data) (data & 0xFFFFFFF0U)
>> +#define BCM2835_MBOX_CHANNEL_MASK(data) (data & 0xFU)
>> +static inline bool bcm2835_mailbox_is_empty()
>> +  return (BCM2835_REG(BCM2835_MBOX_STATUS) & BCM2835_MBOX_EMPTY);
>> +static inline bool bcm2835_mailbox_is_full()
>> +  return (BCM2835_REG(BCM2835_MBOX_STATUS) & BCM2835_MBOX_FULL);
>> +unsigned int raspberrypi_mailbox_read(unsigned int channel)
>> +  unsigned int raw;
>> +  unsigned int read_channel;
>> +  while (1){
>> +    while (bcm2835_mailbox_is_empty());
>> +    raw = BCM2835_REG (BCM2835_MBOX_READ );
>> +    read_channel = BCM2835_MBOX_CHANNEL_MASK(raw) ;
>> +    if (read_channel == channel)
>> +      return BCM2835_MBOX_DATA_MASK(raw);
>> +void raspberrypi_mailbox_write(unsigned int channel, unsigned int data)
>> +  while (bcm2835_mailbox_is_full());
>> +  BCM2835_REG(BCM2835_MBOX_WRITE) =
>> +    BCM2835_MBOX_DATA_MASK(data) |
>> +    BCM2835_MBOX_CHANNEL_MASK(channel);
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>> index 70259e2..4cb7ed6 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>> @@ -126,6 +126,10 @@ $(PROJECT_INCLUDE)/bsp/usart.h: include/usart.h $(PROJECT_INCLUDE)/bsp/$(dirstam
>>      $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/usart.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/usart.h
>> +$(PROJECT_INCLUDE)/bsp/mailbox.h: include/mailbox.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mailbox.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mailbox.h
>>  $(PROJECT_INCLUDE)/bsp/raspberrypi.h: include/raspberrypi.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>      $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/raspberrypi.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/raspberrypi.h
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
