Fwd: SMP support for Raspberry Pi 2
Tue Aug 11 19:59:53 UTC 2015
On 8/11/2015 2:06 PM, Rohini Kulkarni wrote:
> Hi,
> I would have to register the related mailbox interrupt and associate it with a handler that should be same as _SMP_Inter_processor_interrupt_handler(). Am I right?
That sounds correct.
>  From where can I get a reference of how to do this?
I would look at the Xilinx code that registers interrupts. The API
should be the same. Also the clock driver, etc. The actual handler
and IRQ number will vary.
> On 11 Aug 2015 00:41, "Joel Sherrill" <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     The source for the CPU supplement is in doc/cpu_supplement in
>     the RTEMS tree.
>     I do not know when the latest online was built so reading it
>     there is probably safest.
>     To build it, you will likely have to install some texinfo and
>     texlive tools.
>     cd $r/doc
>     ../bootstrap
>     cd ../..
>     mkdir b-doc
>     cd b-doc
>     $r/doc/configure --enable-maintainer-mode \
>        --prefix=DIRECTORY
>     make
>     make install
>     That should be similar to how it is built.
>     --joel
>     On 8/10/2015 1:35 PM, Rohini Kulkarni wrote:
>         The documentation that Sebastian was referring to.
>         On Tue, Jul 28, 2015 at 12:24 PM, Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de> <mailto:sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>              Hello Rohini,
>              please use the devel list.
>              On 28/07/15 07:41, Rohini Kulkarni wrote:
>                  Hi,
>                  I wish to understand where the interprocessor interrupts are used during the boot process. During final initialization of SMP I can see
>                  rtems_interrupt_handler_install(
>                         ARM_GIC_IRQ_SGI_0,
>                         "IPI",
>                         RTEMS_INTERRUPT_UNIQUE,
>                         bsp_inter_processor_interrupt,
>                         NULL
>                  Raspberry Pi 2 does not have the generic interrupt controller. Interrupt routing will have to be handled differently. So I wish to understand how/ where it is used. I suppose this might be the problem.
>              Sorry, that the documentation is so scattered.  I think we should move everything into the CPU Architecture Supplement. It would be nice if you can help to improve the documentation since you have a different view point.
>         What is the CPU Architecture Supplement?
>              You must install the IPI during the system initialization. It is raised via the _CPU_SMP_Send_interrupt() function, for an example see arm-a9mpcore-smp.c.
>                  Thanks.
>                  On Wed, Jul 22, 2015 at 7:08 PM, Rohini Kulkarni <krohini1593 at gmail.com <mailto:krohini1593 at gmail.com> <mailto:krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>> <mailto:krohini1593 at gmail.com <mailto:krohini1593 at gmail.com> <mailto:krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>>>> wrote:
>                       Ok. Qemu suggestion seems helpful for the cache configuration
>                       issue though. I am trying with Pi 1.
>                       Thanks.
>                       On 22 Jul 2015 18:59, "Sebastian Huber"
>                       <mailto:sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de> <mailto:sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>>> wrote:
>                           Sorry, I cannot help you here since I never worked with a
>                           Raspberry Pi.
>                           --         Sebastian Huber, embedded brains GmbH
>                           Address : Dornierstr. 4, D-82178 Puchheim, Germany
>                           Phone   : +49 89 189 47 41-16
>                           Fax     : +49 89 189 47 41-09
>                           E-Mail  : sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de> <mailto:sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
>                           PGP     : Public key available on request.
>                           Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>                           des EHUG.
>                  Rohini Kulkarni
>              Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>         Rohini Kulkarni
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     Support Available                (256) 722-9985
