[PATCH 1/4] Code refactor altera-cyclone-V MMU initialization
Rohini Kulkarni
krohini1593 at gmail.com
Thu Aug 13 21:44:21 UTC 2015
c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am | 4 ++++
.../arm/altera-cyclone-v/startup/bspstarthooks.c | 22 ++++++++------------
2 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index 6afe681..887a63a 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -31,6 +31,7 @@ include_bsp_HEADERS =
include_bsp_socal_HEADERS =
include_bsp_HEADERS += ../../shared/include/utility.h
+include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
include_bsp_HEADERS += ../../shared/include/irq-generic.h
include_bsp_HEADERS += ../../shared/include/irq-info.h
include_bsp_HEADERS += ../../shared/include/stackalloc.h
@@ -176,6 +177,9 @@ libbsp_a_SOURCES += ../shared/arm-a9mpcore-smp.c
libbsp_a_SOURCES += startup/bspsmp.c
endif
+# LIBMM
+libbsp_a_SOURCES += ../shared/mminit.c
# IRQ
libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
libbsp_a_SOURCES += ../../shared/src/irq-generic.c
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
index bd1f1c8..9f3ec03 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
@@ -15,6 +15,7 @@
#define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
#include <bsp.h>
+#include <bsp/mm.h>
#include <bsp/start.h>
#include <bsp/arm-cp15-start.h>
#include <bsp/arm-a9mpcore-start.h>
@@ -35,18 +36,13 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
BSP_START_TEXT_SECTION static void setup_mmu_and_cache(void)
- uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
- ARM_CP15_CTRL_A | ARM_CP15_CTRL_M,
- ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
- arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
- ctrl,
- (uint32_t *) bsp_translation_table_base,
- ARM_MMU_DEFAULT_CLIENT_DOMAIN,
- &arm_cp15_start_mmu_config_table[0],
- arm_cp15_start_mmu_config_table_size
+ uint32_t bsp_initial_mmu_ctrl_clear = ARM_CP15_CTRL_M | ARM_CP15_CTRL_A;
+ uint32_t bsp_initial_mmu_ctrl_set = ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z;
+ bsp_memory_management_initialize(
+ bsp_initial_mmu_ctrl_set,
+ bsp_initial_mmu_ctrl_clear
@@ -91,4 +87,4 @@ BSP_START_TEXT_SECTION void bsp_start_hook_1( void )
rtems_cache_enable_data();
#endif
bsp_start_clear_bss();
\ No newline at end of file
1.7.9.5
