[PATCH] add t1lib patches
YANG QIAO
yangqiao0505 at me.com
Fri Aug 14 09:04:17 UTC 2015
tools/4.11/t1lib/t1lib-5.1.2.diff | 75 +++++++++++++++++++++++++++++++++++++++
1 file changed, 75 insertions(+)
create mode 100644 tools/4.11/t1lib/t1lib-5.1.2.diff
diff --git a/tools/4.11/t1lib/t1lib-5.1.2.diff b/tools/4.11/t1lib/t1lib-5.1.2.diff
new file mode 100644
index 0000000..532cd54
--- /dev/null
+++ b/tools/4.11/t1lib/t1lib-5.1.2.diff
@@ -0,0 +1,75 @@
+diff -ruN t1lib-5.1.2/configure t1lib-5.1.2-new/configure
+--- t1lib-5.1.2/configure 2007-12-23 16:49:43.000000000 +0100
++++ t1lib-5.1.2-new/configure 2015-08-14 10:32:37.985381959 +0200
+@@ -24758,11 +24758,7 @@
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+ else
+ if test "$cross_compiling" = yes; then
+- { { echo "$as_me:$LINENO: error: cannot run test program while cross compiling
+-See \`config.log' for more details." >&5
+-echo "$as_me: error: cannot run test program while cross compiling
+-See \`config.log' for more details." >&2;}
+- { (exit 1); exit 1; }; }
++ ac_64bit_type="<none>"
+ else
+ cat >conftest.$ac_ext <<_ACEOF
+ /* confdefs.h. */
+diff -ruN t1lib-5.1.2/configure.in t1lib-5.1.2-new/configure.in
+--- t1lib-5.1.2/configure.in 2007-12-23 16:49:43.000000000 +0100
++++ t1lib-5.1.2-new/configure.in 2015-08-14 10:33:39.805379339 +0200
+@@ -225,14 +225,52 @@
+ dnl **** Check which ANSI integer type is 64 bit
+-AC_CACHE_CHECK( "which ANSI integer type is 64 bit", ac_64bit_type,
+- AC_TRY_RUN([
++echo $ECHO_N "checking \"which ANSI integer type is 64 bit\"... $ECHO_C" >&6
++if test "${ac_64bit_type+set}" = set; then
++ echo $ECHO_N "(cached) $ECHO_C" >&6
++else
++ if test "$cross_compiling" = yes; then
++else
++ cat >conftest.$ac_ext <<_ACEOF
++/* confdefs.h. */
++_ACEOF
++cat confdefs.h >>conftest.$ac_ext
++cat >>conftest.$ac_ext <<_ACEOF
++/* end confdefs.h. */
+ int main(void) {
+ if (sizeof(long)==8)
+ return(0);
+ else
+ return(1);
+-}], ac_64bit_type="long", ac_64bit_type="<none>"))
++_ACEOF
++rm -f conftest$ac_exeext
++if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
++ (eval $ac_link) 2>&5
++ ac_status=$?
++ echo "$as_me:$LINENO: \$? = $ac_status" >&5
++ (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
++ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
++ (eval $ac_try) 2>&5
++ ac_status=$?
++ (exit $ac_status); }; }; then
++ ac_64bit_type="long"
++else
++ echo "$as_me: program exited with status $ac_status" >&5
++echo "$as_me: failed program was:" >&5
++sed 's/^/| /' conftest.$ac_ext >&5
++( exit $ac_status )
++ac_64bit_type="<none>"
++fi
++rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
++fi
++fi
++echo "$as_me:$LINENO: result: $ac_64bit_type" >&5
++echo "${ECHO_T}$ac_64bit_type" >&6
+ if test "$ac_64bit_type" = "long"
+ then
+ T1_AA_TYPE64="-DT1_AA_TYPE64=long"
2.1.0
