[PATCH] CPSW lwIP library build changes
ragunath
ragunath3252 at gmail.com
Sat Aug 15 06:48:00 UTC 2015
This change builds the cpsw driver as a library for lwIP. The application can link to the
lwIP & driver libraries. The driver is based on TI Starterware & is taken from lwIP port done by Marcos/Daniel.
The driver files are available at https://github.com/ragunath3252/cpsw-lwip.git
rtems/config/4.11/net/cpsw.bset | 20 ++++++++++++++++
rtems/config/net/cpsw-1-1.cfg | 19 +++++++++++++++
source-builder/config/cpsw-1.cfg | 52 ++++++++++++++++++++++++++++++++++++++++
3 files changed, 91 insertions(+)
create mode 100644 rtems/config/4.11/net/cpsw.bset
create mode 100644 rtems/config/net/cpsw-1-1.cfg
create mode 100644 source-builder/config/cpsw-1.cfg
diff --git a/rtems/config/4.11/net/cpsw.bset b/rtems/config/4.11/net/cpsw.bset
new file mode 100644
index 0000000..768256e
--- /dev/null
+++ b/rtems/config/4.11/net/cpsw.bset
@@ -0,0 +1,20 @@
+# Build set for lwIP cpsw driver
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build lwIP CPSW driver.
+net/cpsw-1-1.cfg
diff --git a/rtems/config/net/cpsw-1-1.cfg b/rtems/config/net/cpsw-1-1.cfg
index 0000000..10ffc8d
--- /dev/null
+++ b/rtems/config/net/cpsw-1-1.cfg
@@ -0,0 +1,19 @@
+# LWIP CPSW
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# CPSW Version
+%define cpsw_version cpsw-1-1
+# lwIP cpsw Build configuration
+%include %{_configdir}/cpsw-1.cfg
diff --git a/source-builder/config/cpsw-1.cfg b/source-builder/config/cpsw-1.cfg
index 0000000..dbfda51
--- /dev/null
+++ b/source-builder/config/cpsw-1.cfg
@@ -0,0 +1,52 @@
+# cpsw lwIP Version 1.
+# This configuration file configure's, make's and install's lwIP cpsw driver.
+%define release 1
+%endif
+Name: cpsw-%{cpsw_version}-%{_host}-%{release}
+Summary: Light weight TCP/IP stack -- CPSW driver
+Version: %{cpsw_version}
+Release: %{release}
+URL: https://github.com/ragunath3252/cpsw-lwip.git
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# CPSW driver Source
+%source set cpsw git://github.com/ragunath3252/cpsw-lwip.git
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ source_dir_cpsw="cpsw-lwip"
+ %source setup cpsw -q -n ${source_dir_cpsw}
+ %patch setup cpsw -p1
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ %{build_directory}
+ mkdir -p ${build_dir}
+ cd ${build_dir}
+ %{host_build_flags}
+ cd ${build_top}/${source_dir_cpsw}
+ export RTEMS_MAKEFILE_PATH=%{_exec_prefix}
+ %{__make} all
+#%install
+ build_top=$(pwd)/%{cpsw_version}
+ %{__make} install
1.9.1
