Pi2 Mailbox IRQs was Re: Fwd: SMP support for Raspberry Pi 2
Cudmore, Alan P. (GSFC-5820) alan.p.cudmore at nasa.gov
Mon Aug 17 15:23:31 UTC 2015
Joel and Rohini,
I will have to take some time to catch up.. I apologize that I have not
been able to keep up with the Raspberry Pi work lately, I have just been
too busy with my work projects. ( which is usually a good thing :)
Alan
On 8/15/15, 5:37 PM, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>Alan .. can you confirm what I am interpreting?
>On 08/15/2015 02:56 PM, Rohini Kulkarni wrote:
>> On Sun, Aug 16, 2015 at 1:13 AM, Joel Sherrill
>> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>     On 08/15/2015 02:35 PM, Rohini Kulkarni wrote:
>>         Hi
>>         I need some help with this. I am unable to figure out yet how
>>         to add an interrupt for the mailbox and determine interrupt
>>         number to be associated with it.
>>     If you can enable it and cause it, the fault handler will be one
>>     way to do it :)
>>     Can you tell from the documentation which pin(s) on the interrupt
>>     controller
>>     is associated with the mailbox?
>>     FWIW I don't even know what documentation to look at for the SoC to
>>     find this. If you point me to it, I will see what I can find.
>> This
>><https://www.raspberrypi.org/documentation/hardware/raspberrypi/bcm2836/Q
>>A7_rev3.4.pdf>
>> is the only official document which seems to be available. The Cortex
>> A7 mpcore document didn't help here.
>Putitng this back on the devel list.
>Page 16 of that PDF (4.10) follows up on a previous section. There
>are sixteen mailboxes. Each core has four associated with it. In
>4.10, there is a list of per-core interrupt sources. There are four
>addresses for core specific interrupt source registers.
>It looks like the interrupts are numerically next to the GPU interrupt.
>This much looks fairly straight-forward.  Pick a mailbox to dedicate
>to interprocessor-interrupts. If you pick Bit 7 (mailbox 3), I would
>expect
>it to be one logical interrupt lower than the GPU interrupt source.
>Check the irq list for the BSP. This should be in a .h file.
>You will install one SMP IRQ handler. But based on the core number it
>is running on, you will have to do slightly different things to clear it
>(I think) since the interrupt registers are duplicated per core.
>>         Thanks.
>>         On Sat, Aug 15, 2015 at 10:52 PM, Rohini Kulkarni
>>         <krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>
>>         <mailto:krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>>>
>>         wrote:
>>             On Wed, Aug 12, 2015 at 1:29 AM, Joel Sherrill
>>         <mailto:joel.sherrill at oarcorp.com>>> wrote:
>>                 On 8/11/2015 2:06 PM, Rohini Kulkarni wrote:
>>                     Hi,
>>                     I would have to register the related mailbox
>>         interrupt and
>>                     associate it with a handler that should be same as
>>                     _SMP_Inter_processor_interrupt_handler(). Am I
>>right?
>>                 That sounds correct.
>>                      From where can I get a reference of how to do this?
>>                 I would look at the Xilinx code that registers
>>         interrupts. The API
>>                 should be the same. Also the clock driver, etc. The
>>         actual handler
>>                 and IRQ number will vary.
>>             How do I determine the interrupt number?
>>             I could fine the IPi handler being installed here in
>>             arm-a9mpcore-smp.c
>>             rtems_interrupt_handler_install(
>>                   ARM_GIC_IRQ_SGI_0,
>>                   "IPI",
>>                   RTEMS_INTERRUPT_UNIQUE,
>>                   bsp_inter_processor_interrupt,
>>                   NULL
>>                     On 11 Aug 2015 00:41, "Joel Sherrill"
>>         <mailto:joel.sherrill at oarcorp.com>>>> wrote:
>>                         The source for the CPU supplement is in
>>                     doc/cpu_supplement in
>>                         the RTEMS tree.
>>                         I do not know when the latest online was built
>>so
>>                     reading it
>>                         there is probably safest.
>>                         To build it, you will likely have to install
>>some
>>                     texinfo and
>>                         texlive tools.
>>                         cd $r/doc
>>                         ../bootstrap
>>                         cd ../..
>>                         mkdir b-doc
>>                         cd b-doc
>>                         $r/doc/configure --enable-maintainer-mode \
>>                            --prefix=DIRECTORY
>>                         make
>>                         make install
>>                         That should be similar to how it is built.
>>                         --joel
>>                         On 8/10/2015 1:35 PM, Rohini Kulkarni wrote:
>>                             The documentation that Sebastian was
>>         referring to.
>>                             On Tue, Jul 28, 2015 at 12:24 PM,
>>         Sebastian Huber
>>         <sebastian.huber at embedded-brains.de
>>         <mailto:sebastian.huber at embedded-brains.de>
>>         <mailto:sebastian.huber at embedded-brains.de>>
>>         <mailto:sebastian.huber at embedded-brains.de>>>
>>         <mailto:sebastian.huber at embedded-brains.de>>>>> wrote:
>>                                  Hello Rohini,
>>                                  please use the devel list.
>>                                  On 28/07/15 07:41, Rohini Kulkarni
>>wrote:
>>                                      Hi,
>>                                      I wish to understand where the
>>                     interprocessor interrupts are used during the boot
>>                     process. During final initialization of SMP I can
>>see
>>                                             ARM_GIC_IRQ_SGI_0,
>>                                             "IPI",
>>                                             NULL
>>                                      Raspberry Pi 2 does not have the
>>         generic
>>                     interrupt controller. Interrupt routing will have
>>         to be
>>                     handled differently. So I wish to understand how/
>>         where it
>>                     is used. I suppose this might be the problem.
>>                                  Sorry, that the documentation is so
>>                     scattered.  I think we should move everything into
>>         the CPU
>>                     Architecture Supplement. It would be nice if you
>>         can help
>>                     to improve the documentation since you have a
>>         different
>>                     view point.
>>                             What is the CPU Architecture Supplement?
>>                                  You must install the IPI during the
>>         system
>>                     initialization. It is raised via the
>>                     _CPU_SMP_Send_interrupt() function, for an example
>>see
>>                     arm-a9mpcore-smp.c.
>>                                      Thanks.
>>                                      On Wed, Jul 22, 2015 at 7:08 PM,
>>         Rohini
>>                     Kulkarni <krohini1593 at gmail.com
>>         <mailto:krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>>>>
>>         <mailto:krohini1593 at gmail.com>>>>>> wrote:
>>                                           Ok. Qemu suggestion seems
>>         helpful
>>                     for the cache configuration
>>                                           issue though. I am trying
>>         with Pi 1.
>>                                           Thanks.
>>                                           On 22 Jul 2015 18:59,
>>         "Sebastian Huber"
>>         <mailto:sebastian.huber at embedded-brains.de>>>>>> wrote:
>>                                               Sorry, I cannot help you
>>         here
>>                     since I never worked with a
>>                                               Raspberry Pi.
>>                                               --         Sebastian
>>Huber,
>>                     embedded brains GmbH
>>                                               Address : Dornierstr. 4,
>>         D-82178
>>                     Puchheim, Germany
>>                                               Phone   : +49 89 189 47
>>         41-16
>>                                               Fax     : +49 89 189 47
>>         41-09
>>                                               E-Mail  :
>>                                               PGP     : Public key
>>         available
>>                     on request.
>>                                               Diese Nachricht ist keine
>>                     geschäftliche Mitteilung im Sinne
>>                                               des EHUG.
>>                                      Rohini Kulkarni
>>                                  Sebastian Huber, embedded brains GmbH
>>                                  Address : Dornierstr. 4, D-82178
>>         Puchheim,
>>                     Germany
>>                                  Phone   : +49 89 189 47 41-16
>>                                  Fax     : +49 89 189 47 41-09
>>                                  E-Mail  :
>>                                  PGP     : Public key available on
>>         request.
>>                                  Diese Nachricht ist keine geschäftliche
>>                     Mitteilung im Sinne des EHUG.
>>                             Rohini Kulkarni
>>                         Joel Sherrill, Ph.D.             Director of
>>         Research
>>         & Development
>>                         joel.sherrill at OARcorp.com        On-Line
>>         Applications
>>                     Research
>>                         Ask me about RTEMS: a free RTOS  Huntsville AL
>>         35805
>>                         Support Available                (256) 722-9985
>>                 --         Joel Sherrill, Ph.D.             Director
>>         of Research &
>>                 Development
>>                 joel.sherrill at OARcorp.com        On-Line Applications
>>         Research
>>                 Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>             --     Rohini Kulkarni
>>         Rohini Kulkarni
>>     -- Joel Sherrill
>>     Support and Training Available
>> Rohini Kulkarni
>-- Joel Sherrill
