[PATCH] [RSB] doc: zlib1g-dev package needs to be installed on Linux Mint
Hesham Almatary
heshamelmatary at gmail.com
Tue Aug 18 13:37:04 UTC 2015
doc/source-builder.txt | 10 ++++++++++
1 file changed, 10 insertions(+)
diff --git a/doc/source-builder.txt b/doc/source-builder.txt
index b5c7e3c..fa75fe1 100644
--- a/doc/source-builder.txt
+++ b/doc/source-builder.txt
@@ -3150,6 +3150,16 @@ The RTEMS Source Builder has been tested on Mountain Lion. You will need to
install the Xcode app using the _App Store_ tool, run Xcode and install the
Developers Tools package within Xcode.
+Linux Mint
+zlib package is required on Linux Mint. It has a different name (other
+than the usual zlib-dev):
+# sudo apt-get install zlib1g-dev
Mavericks
1.9.1
