Porting CANFestival to RTEMS
Isaac Gutekunst
isaac.gutekunst at vecna.com
Wed Aug 19 16:51:42 UTC 2015
Hi
I'm thinking about porting CANFestival to RTEMS. I think it should be
relatively doable do to the posix support, and because the core files
don't have any platform specific code as far as I can tell.
Has anyone had any experience porting CANFestival so far, are could
offer some advice?
So far I've made a copy of the UNIX time and lincan drivers and renamed
them to can_rtems and timers_rtems as well as a couple of other directories.
I've gotten to the point where I need to link against an RTEMS BSP, and
don't really know what to do. I want to include <rtems.h> and generate a
static library that I can link with my application, or if I'm really
lucky, run the existing examples on RTEMS.
Regarding CAN drivers, I have written a simplistic CAN driver framework
based on lincan and the current cpukit/dev/i2c style IMFS driver. This
should be easy to support in CANFestival, and could pave the way for
supporting lincan directly at some point.
Thanks,
Isaac
