Telnetd fails to compile due to -DDEBUG
Inderjit Singh
inderjit.singh at aacmicrotec.com
Fri Aug 21 11:29:07 UTC 2015
Hi,
I put some debug macos in my driver and when building the rtems, i get failure in telned. Any idea why?
RTEMS version 4.10.99 from git some time from May.
My configuration: ../rtems/configure --target=or1k-rtems4.11 --enable-rtemsbsp=or1k-bb --enable-test=samples --prefix=/home/indy/devel/rtems-dev/rtems.git/target/or1k-bb target_alias=or1k-rtems4.11
or1k-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../or1k-aac/lib/include -DDEBUG -MT libtelnetd_a-des.o -MD -MP -MF .deps/libtelnetd_a-des.Tpo -c -o libtelnetd_a-des.o `test -f 'des.c' || echo '../../../../../../rtems/c/src/../../cpukit/telnetd/'`des.c
../../../../../../rtems/c/src/../../cpukit/telnetd/des.c: In function 'des_snap':
../../../../../../rtems/c/src/../../cpukit/telnetd/des.c:850:3: error: unknown type name 'uint8'
uint8* pfc;
../../../../../../rtems/c/src/../../cpukit/telnetd/des.c: In function 'des_check':
../../../../../../rtems/c/src/../../cpukit/telnetd/des.c:867:3: error: unknown type name 'uint8'
uint8* pfc1, pfc2, pfc3, pfc4;
Thanks,
Indy
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150821/d6c9dc05/attachment.html>
