RTEMS graphic testing on RPi
Pavel Pisa pisa at cmp.felk.cvut.cz
Mon Aug 24 16:19:37 UTC 2015
Hello Qiao and Joel,
I have rerun testing of actual RSB mainline testing
on RPi B device. Generally works well.
Used instructions included for archival there
  git clone git://git.rtems.org/rtems-source-builder.git
  cd rtems
  ../source-builder/sb-set-builder \
    --prefix=/opt/rtems4.11 \
    --rtems-bsp=arm/raspberrypi \
    --log=graphic-build-log.txt \
    --with-rtems-bsp=raspberrypi \
    --pkg-tar-files \
    4.11/graphics/freetype2.bset \
    4.11/graphics/libjpeg.bset \
    4.11/graphics/libpng.bset \
    4.11/graphics/libtiff.bset \
    4.11/graphics/t1lib.bset \
    4.11/graphics/microwindows.bset
There are minor problems with t1lib patch and libpng version changes
diff --git a/rtems/config/4.11/graphics/libpng.bset b/rtems/config/4.11/graphics/libpng.bset
index 4df0e03..b858081 100644
--- a/rtems/config/4.11/graphics/libpng.bset
+++ b/rtems/config/4.11/graphics/libpng.bset
@@ -17,4 +17,4 @@
 # Build libpng.
-graphics/libpng-1.5.22-1.cfg
+graphics/libpng-1.5.23-1.cfg
diff --git a/source-builder/config/t1lib-1.cfg b/source-builder/config/t1lib-1.cfg
index 38c3530..b11e1eb 100644
--- a/source-builder/config/t1lib-1.cfg
+++ b/source-builder/config/t1lib-1.cfg
@@ -20,7 +20,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
 %source set t1lib ftp://ftp.netbsd.org/pub/pkgsrc/distfiles/t1lib-%{t1lib_version}.tar.gz
 %patch add t1lib https://raw.githubusercontent.com/yangqiao/rtems-tools/graphics/tools/4.11/t1lib/t1lib-5.1.2.diff
-%hash md5 t1lib-5.1.2.diff 196b0e39e36cab5afc6c5c280dcbe9bc
+%hash md5 t1lib-5.1.2.diff 98eeed85780227adf8525deab3679877
 # Prepare the source code.
We should get rid of microwindows patches or at least limit them
to the configuration file only
  microwindows-0.93-dev.diff
  microwindows-0.93-dev-without-keyboard.diff
I have some changes already included in my repo branch for RTEMS.
I.e. keyboard patch
  https://github.com/ppisa/microwindows/commit/57b3eb772dc4175bf356736fe239331c8e125721
I have there configuration file based override of graphic driver
even for RTEMS
  https://github.com/ppisa/microwindows/commit/a85ee935e4ff0f569455004d9a71cc3d218a7ca6
and even null KBD handling should land there.
I hope to find some spare time for that in reasonable time.
As of the 4.11/graphics/nxlib.bset, it does not build for RPi because
keyboard mapping is missing for that platform.
arm-rtems4.11-gcc --pipe -B/opt/rtems4.11/arm-rtems4.11/raspberrypi/lib/ -specs
bsp_specs -qrtems   -DDEBUG=1 -g -Wall -I/opt/rtems4.11/arm-rtems4.11/raspberrypi/lib/
include/ -I. -DX11_FONT_DIR1=\"\" -DX11_FONT_DIR2=\"\" -DX11_FONT_DIR3=\"\" -DX11_RGBTXT=\"fonts/rgb.txt\" -O3 -I. -o StrKeysym.o -c
StrKeysym.c
StrKeysym.c:20:30: fatal error: rtems/keyboard.h: No such file or directory
   #include <rtems/keyboard.h>
I do not see that as big problem because NXlib is mainly for remote
graphic (i.e. X like protocol) and if I see well the NXlib is absorbed
now in Microwindows directly
See Gregory Haerr actual repo
  https://github.com/ghaerr/microwindows/tree/master/src
Generally, it is great that the RTEMS graphic support build
is included in official RSB repo now and runs on target.
Best wishes,
             Pavel
