[PATCH 0/6] RSB Recipes for Add-On Packages
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Aug 25 23:02:03 UTC 2015
Hi
I recently committed changes to update some of the contents
of the rtems-addon-packages and get it all building again.
This was the first step of migrating these into the RSB. Once
I had them building as a baseline, I could write RSB recipes.
In this patch series, they run the gamut from typo to needs
review to doesn't work and needs help to get fixed.
+ libjpeg - Fix comments
+ libavl and GSL - build now
+ ncurses, readline, and libtecl - do not build but the recipe
appears close. My assumption is that the Makefile environment
for the rtems-addon-packages covers something that the RSB
recipe isn't accounting for. Help requested
Joel Sherrill (6):
libjpeg: Fix comments
Add libavl-1.4.0: Eliminates need to be in rtems-addon-packages
Add GSL 1.16: Removes need to be in rtems-addon-packages
Add ncurses 5.9: Not building yet
Add readline: Not building yet
Add libtecla: Not building yet
rtems/config/4.11/devel/gsl.bset | 20 +++++++
rtems/config/4.11/devel/libavl.bset | 20 +++++++
rtems/config/4.11/devel/libtecla.bset | 20 +++++++
rtems/config/4.11/devel/ncurses.bset | 20 +++++++
rtems/config/4.11/devel/readline.bset | 20 +++++++
rtems/config/devel/gsl-1.16-1.cfg | 21 +++++++
rtems/config/devel/libavl-1.4.0-1.cfg | 21 +++++++
rtems/config/devel/libtecla-1.6.3-1.cfg | 21 +++++++
rtems/config/devel/ncurses-5.9-1.cfg | 21 +++++++
rtems/config/devel/readline-6.3-1.cfg | 21 +++++++
rtems/config/graphics/libjpeg-9a-1.cfg | 2 +-
source-builder/config/gsl-1.cfg | 70 ++++++++++++++++++++++++
source-builder/config/libavl-1.cfg | 71 ++++++++++++++++++++++++
source-builder/config/libjpeg-1.cfg | 2 +-
source-builder/config/libtecla-1.cfg | 78 +++++++++++++++++++++++++++
source-builder/config/ncurses-1.cfg | 89 +++++++++++++++++++++++++++++++
source-builder/config/readline-1.cfg | 78 +++++++++++++++++++++++++++
17 files changed, 593 insertions(+), 2 deletions(-)
create mode 100644 rtems/config/4.11/devel/gsl.bset
create mode 100644 rtems/config/4.11/devel/libavl.bset
create mode 100644 rtems/config/4.11/devel/libtecla.bset
create mode 100644 rtems/config/4.11/devel/ncurses.bset
create mode 100644 rtems/config/4.11/devel/readline.bset
create mode 100644 rtems/config/devel/gsl-1.16-1.cfg
create mode 100644 rtems/config/devel/libavl-1.4.0-1.cfg
create mode 100644 rtems/config/devel/libtecla-1.6.3-1.cfg
create mode 100644 rtems/config/devel/ncurses-5.9-1.cfg
create mode 100644 rtems/config/devel/readline-6.3-1.cfg
create mode 100644 source-builder/config/gsl-1.cfg
create mode 100644 source-builder/config/libavl-1.cfg
create mode 100644 source-builder/config/libtecla-1.cfg
create mode 100644 source-builder/config/ncurses-1.cfg
create mode 100644 source-builder/config/readline-1.cfg
