Trouble creating RSB Package: error copying tree
Isaac Gutekunst
isaac.gutekunst at vecna.com
Thu Aug 27 17:01:14 UTC 2015
Hi Devel,
I've been working on porting CANFestival to RTEMS. I ended up creating
some changes to CANFestival to allow it to be built against an RTEMS BSP.
All was going well except a strange ldconfig error, when I tried to fix
it by removing the build directory (rtems_source_builder/rtems/build).
Now I get the following error:
error: copying tree:
/other/rtems/rtems-source-builder/rtems/build/tmp/canfestival-8bfe0ac00cdb-arm-rtems4.11-1-root-isaac.gutekunst
/other/rtems/rtems-source-builder/rtems/build/tmp/sb-isaac.gutekunst/4.11/net/canfestival:
[Errno 2] No such file or directory:
'/other/rtems/rtems-source-builder/rtems/build/tmp/canfestival-8bfe0ac00cdb-arm-rtems4.11-1-root-isaac.gutekunst'
I tried re-building ntp, the package I based my bset and cfg files off
of, and it doesn't build correctly, but gets much farther along.
Any idea what's going on ?
Thanks,
Isaac
Isaac Gutekunst
Embedded Systems Software Engineer
www.vecna.com
