[PATCH] RTEMS CAN Rough Draft Implementation
Isaac Gutekunst
isaac.gutekunst at vecna.com
Thu Aug 27 18:45:45 UTC 2015
Hi All,
Here is the RTEMS CAN driver framework I've been talking about. Please
give me feedback, and don't worry about being harsh. I want to commit
something of value.
Concerns
* Usage of return codes.
* General higher level error handling.
* Changing can bit rate.
* In general, changing CAN parameters at runtime.
* Task model: Should there really be an RX and TX task required by the
RTEMS driver? Is the method of starting and stopping tasks acceptable?
The motivation for this is that the CAN controller we are using, (STM32
BxCAN) requires you to re-initialize the device to change parameters.
This is a bit awkward with first calling open, and then IOCTL to
configure the bus. Any thoughts?
Thanks,
Isaac
P.S. I'm having trouble with git send-email. Something is not quite
right with our mail server here. I've attached the patch instead.
Isaac Gutekunst
Embedded Systems Software Engineer
www.vecna.com
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150827/99e67a98/attachment-0001.bin>
