ARMv7M Exception Handler
Daniel Gutson daniel.gutson at tallertechnologies.com
Thu Aug 27 20:58:39 UTC 2015
On Thu, Aug 27, 2015 at 3:53 PM, sudarshan.rajagopalan
<sudarshan.rajagopalan at vecna.com> wrote:
> Hey guys,
> I was working on the exception handler for the CPU hard fault. Managed to
> register the fatal error user extension to RTEMS and call the user defined
> function when an exception occurs. But the pointer to the stacked frame
> didn't have the correct register values(esp. the PC register). So I looked
> into the assembly code in /cpukit/score/cpu/arm/armv7m-exception-default.c,
> where it decides which stack pointer was used (MSP or PSP) before the
> exception occurred depending on the error code returned in the Link
> Register. After carefully examining all the assembly instructions, I guess
> theres a little bug in the code.
> The instruction "cmn r2, #3\n" in line 31 basically compares the Link
> Register(lr) to value 0xFFFFFFFD (negative #3, because CMN negates the RHS
> and compares with LHS) and chooses MSP or PSP in the following IT block.
> This is pretty cool! But, it will not work if you have the floating-point
> unit (FPU) enabled in your processor, which is enabled in mine. With FPU
> enabled, the error code returned is either 0xFFFFFFE9 or 0xFFFFFFED, for
> which the above assembly instruction will not work out and MSP will be
> selected always.
> Better way to do is to check the 2nd bit of the error code to determine
> which stack pointer was used before the exception happened - "tst lr, #4\n"
> and change the IT block from "itt ne" to "itt eq" and the "mov" and "add"
> within this IT block.
> Have tested this with the above changes and it works. I have sent the patch
> "0001-Fix-exception-handler-for-supporting-FPU.patch" to the devel mailing
> list that fixes this problem. :)
Nice. Have you tested this without FPU support too?
> Thanks and Regards,
> Sudarshan
> devel mailing list
> devel at rtems.org
Daniel F. Gutson
Chief Engineering Officer, SPD
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone:   +54 351 4217888 / +54 351 4218211
Skype:    dgutson
LinkedIn: http://ar.linkedin.com/in/danielgutson
