[PATCH] Fix exception handler for supporting FPU
sudarshan.rajagopalan sudarshan.rajagopalan at vecna.com
Fri Aug 28 17:31:59 UTC 2015
On 2015-08-28 12:18, sudarshan.rajagopalan wrote:
> On 2015-08-28 11:30, Daniel Gutson wrote:
>> On Fri, Aug 28, 2015 at 12:20 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>>> Could you please open a ticket on our trac to describe the problem
>>> this fixes, and add "closes #xxxx." to your patch commit message?
> Hi Gedare, Sure will do!
>> Additionally, please clarify which architecture this applies to. I
>> suspect this is for cortex-m4.
>> In any case, please clarify which architectures you tested on. We can
>> analyze and test cortex-m3 if you don't have one.
> Daniel, I've tested it on Cortex-M4 but this patch should also apply
> to Cortex-M3 or all ARMv7M based processor (including M7). But please
> feel free to test it on Cortex-M3 since I don't have it with me now.
> Am also attaching the links to ARM Cortex-M3, M4 and M7 Exception
> entry and return referenece documents for a quick reference, where the
> table gives all the possible exception error codes returned and which
> SP to pick depending on the error code. The only tricky part would be
> error code: 0xFFFFFFE1. But the asm "tst.w lr, #4" with lr=0xFFFFFFE1
> will result into zero and will set the Zero flag, which will make the
> ITT EQ block execute, which will choose MSP, which it should for the
> return code 0xFFFFFFE1 (or even 0xFFFFFFF1) in all M3, M4 and M7. But
> please feel free to test it on real M3 an M7 processor. I have tested
> it by manually giving all the return error codes for M3 and M7 to LR
> and and it chooses the right SP value.
> ARM Reference Docs - Exception Entry and Return:
> C-3:
> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0552a/Babefdjc.html
> C-4:
> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0553a/Babefdjc.html
> C-7:
> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0646a/Babefdjc.html
> Thanks and Regards,
> Sudarshan
Ok, so we tested the fix on Cortex-M7 processor. The error codes for C-4
and C-7 are all pretty much the same. This leaves with C-3, which I
believe should work too, becasue non-FPU error codes are same for C-3,
C-4 and C-7.
Thanks,
Sudarshan
>>> Thanks,
>>> Gedare
>>> On Thu, Aug 27, 2015 at 4:33 PM, sudarshan.rajagopalan
>>> <sudarshan.rajagopalan at vecna.com> wrote:
>>>> Patch attached here for ARMv7M Exception Handler. Looks like git
>>>> send-email
>>>> didn't deliver the mail. Something is not quite right with our mail
>>>> server
>>>> here. Avoid this email if patch delivered through git.
>>>> Thanks and Regards,
>>>> Sudarshan
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
> devel mailing list
> devel at rtems.org
