[PATCH] Fix exception handler for supporting FPU
Daniel Gutson daniel.gutson at tallertechnologies.com
Fri Aug 28 17:44:17 UTC 2015
On Fri, Aug 28, 2015 at 2:31 PM, sudarshan.rajagopalan
<sudarshan.rajagopalan at vecna.com> wrote:
> On 2015-08-28 12:18, sudarshan.rajagopalan wrote:
>> On 2015-08-28 11:30, Daniel Gutson wrote:
>>> On Fri, Aug 28, 2015 at 12:20 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>>>> Could you please open a ticket on our trac to describe the problem
>>>> this fixes, and add "closes #xxxx." to your patch commit message?
>> Hi Gedare, Sure will do!
>>> Additionally, please clarify which architecture this applies to. I
>>> suspect this is for cortex-m4.
>>> In any case, please clarify which architectures you tested on. We can
>>> analyze and test cortex-m3 if you don't have one.
>> Daniel, I've tested it on Cortex-M4 but this patch should also apply
>> to Cortex-M3 or all ARMv7M based processor (including M7). But please
>> feel free to test it on Cortex-M3 since I don't have it with me now.
>> Am also attaching the links to ARM Cortex-M3, M4 and M7 Exception
>> entry and return referenece documents for a quick reference, where the
>> table gives all the possible exception error codes returned and which
>> SP to pick depending on the error code. The only tricky part would be
>> error code: 0xFFFFFFE1. But the asm "tst.w lr, #4" with lr=0xFFFFFFE1
>> will result into zero and will set the Zero flag, which will make the
>> ITT EQ block execute, which will choose MSP, which it should for the
>> return code 0xFFFFFFE1 (or even 0xFFFFFFF1) in all M3, M4 and M7. But
>> please feel free to test it on real M3 an M7 processor. I have tested
>> it by manually giving all the return error codes for M3 and M7 to LR
>> and and it chooses the right SP value.
>> ARM Reference Docs - Exception Entry and Return:
>> C-3:
>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0552a/Babefdjc.html
>> C-4:
>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0553a/Babefdjc.html
>> C-7:
>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0646a/Babefdjc.html
>> Thanks and Regards,
>> Sudarshan
> Ok, so we tested the fix on Cortex-M7 processor. The error codes for C-4 and
> C-7 are all pretty much the same. This leaves with C-3, which I believe
> should work too, becasue non-FPU error codes are same for C-3, C-4 and C-7.
Hi Sudarshan,
   ok thanks. We will comment on Monday since we have a release today.
Good job.
   Daniel.
> Thanks,
> Sudarshan
>>>> Thanks,
>>>> Gedare
>>>> On Thu, Aug 27, 2015 at 4:33 PM, sudarshan.rajagopalan
>>>>> Patch attached here for ARMv7M Exception Handler. Looks like git
>>>>> send-email
>>>>> didn't deliver the mail. Something is not quite right with our mail
>>>>> server
>>>>> here. Avoid this email if patch delivered through git.
>>>>> Thanks and Regards,
>>>>> Sudarshan
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>> devel mailing list
>>>> devel at rtems.org
>> devel mailing list
>> devel at rtems.org
Daniel F. Gutson
Chief Engineering Officer, SPD
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone:   +54 351 4217888 / +54 351 4218211
Skype:    dgutson
LinkedIn: http://ar.linkedin.com/in/danielgutson
