Fwd: SMP support for Raspberry Pi 2
Rohini Kulkarni
krohini1593 at gmail.com
Wed Aug 12 21:15:17 UTC 2015
Hi,
It would be great if somebody can help here.
[1] How are the mailbox registers available for each core of Pi2 to be
used.
[2] Another thing is that I don't know which registers of Pi 1 are
available for Pi2 as well. The ones in this link
<https://www.raspberrypi.org/documentation/hardware/raspberrypi/bcm2836/QA7_rev3.4.pdf>
, are quite different from the ones for Pi 1.
[3] Can the same mailbox interface as Pi1 be used?
Thanks.
On Wed, Aug 12, 2015 at 1:29 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 8/11/2015 2:06 PM, Rohini Kulkarni wrote:
>> Hi,
>> I would have to register the related mailbox interrupt and associate it
>> with a handler that should be same as
>> _SMP_Inter_processor_interrupt_handler(). Am I right?
> That sounds correct.
> From where can I get a reference of how to do this?
> I would look at the Xilinx code that registers interrupts. The API
> should be the same. Also the clock driver, etc. The actual handler
> and IRQ number will vary.
>> On 11 Aug 2015 00:41, "Joel Sherrill" <joel.sherrill at oarcorp.com <mailto:
>> joel.sherrill at oarcorp.com>> wrote:
>> The source for the CPU supplement is in doc/cpu_supplement in
>> the RTEMS tree.
>> I do not know when the latest online was built so reading it
>> there is probably safest.
>> To build it, you will likely have to install some texinfo and
>> texlive tools.
>> cd $r/doc
>> ../bootstrap
>> cd ../..
>> mkdir b-doc
>> cd b-doc
>> $r/doc/configure --enable-maintainer-mode \
>> --prefix=DIRECTORY
>> make
>> make install
>> That should be similar to how it is built.
>> --joel
>> On 8/10/2015 1:35 PM, Rohini Kulkarni wrote:
>> The documentation that Sebastian was referring to.
>> On Tue, Jul 28, 2015 at 12:24 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de <mailto:
>> sebastian.huber at embedded-brains.de> <mailto:
>> sebastian.huber at embedded-brains.de>>> wrote:
>> Hello Rohini,
>> please use the devel list.
>> On 28/07/15 07:41, Rohini Kulkarni wrote:
>> Hi,
>> I wish to understand where the interprocessor interrupts
>> are used during the boot process. During final initialization of SMP I can
>> see
>> rtems_interrupt_handler_install(
>> ARM_GIC_IRQ_SGI_0,
>> "IPI",
>> RTEMS_INTERRUPT_UNIQUE,
>> bsp_inter_processor_interrupt,
>> NULL
>> Raspberry Pi 2 does not have the generic interrupt
>> controller. Interrupt routing will have to be handled differently. So I
>> wish to understand how/ where it is used. I suppose this might be the
>> problem.
>> Sorry, that the documentation is so scattered. I think we
>> should move everything into the CPU Architecture Supplement. It would be
>> nice if you can help to improve the documentation since you have a
>> different view point.
>> What is the CPU Architecture Supplement?
>> You must install the IPI during the system initialization.
>> It is raised via the _CPU_SMP_Send_interrupt() function, for an example see
>> arm-a9mpcore-smp.c.
>> Thanks.
>> On Wed, Jul 22, 2015 at 7:08 PM, Rohini Kulkarni <
>> krohini1593 at gmail.com <mailto:krohini1593 at gmail.com> <mailto:
>> krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>> <mailto:
>> krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>>>> wrote:
>> Ok. Qemu suggestion seems helpful for the cache
>> configuration
>> issue though. I am trying with Pi 1.
>> Thanks.
>> On 22 Jul 2015 18:59, "Sebastian Huber"
>> <sebastian.huber at embedded-brains.de <mailto:
>> <mailto:sebastian.huber at embedded-brains.de <mailto:
>> sebastian.huber at embedded-brains.de>>>> wrote:
>> Sorry, I cannot help you here since I never
>> worked with a
>> Raspberry Pi.
>> -- Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim,
>> Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de> <mailto:
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche
>> Mitteilung im Sinne
>> des EHUG.
>> Rohini Kulkarni
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> E-Mail : sebastian.huber at embedded-brains.de <mailto:
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>> des EHUG.
>> Rohini Kulkarni
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150813/854aa9fd/attachment-0002.html>
