[PATCH V2 1/2] RTEMS GPIO API definition and implementation.
André Marques
andre.lousa.marques at gmail.com
Thu Aug 13 14:08:04 UTC 2015
On 13-08-2015 14:51, Ketul Shah wrote:
> Hi Andre,
> Thanks for the reply.
> On 13 August 2015 at 19:13, André Marques
> <andre.lousa.marques at gmail.com <mailto:andre.lousa.marques at gmail.com>>
> wrote:
> Hello Ketul,
> On 13-08-2015 13:04, Ketul Shah wrote:
> Hi Andre,
> Great API and happy to know that it is merged with main line.
> Eventually I implemented GPIO driver for BBB using this API.
> After debugging for rtems_gpio_get_value() on BBB I found the
> following bug.
> For BBB, GPIO pin nos. varies from 0 to 32. So function return
> type would be uint32_t instead of uint8_t.
> For BBB I wrote :-
> uint32_t rtems_gpio_bsp_get_value(uint32_t bank, uint32_t pin)
> return (mmio_read(bbb_reg(bank, AM335X_GPIO_DATAIN)) &
> BIT(pin));
> So it would be:- return ((mmio_read(bbb_reg(bank,
> AM335X_GPIO_DATAIN)) & BIT(pin)) > 0);
> Am I correct ?
Yes, but since this function is not used by applications maybe it would
be best to return the bitmask here and avoid another operation, as
rtems_gpio_get_value does the mapping to 1 anyway for any value above 0.
So yes the bsp function shall return uint32_t instead of the uint8_t.
Doxygen also has to be updated.
> the rtems_gpio_bsp_get_value returns the value of a GPIO pin,
> which can only be either 0 or 1. This is not platform dependent.
> Any value greater than zero should map to 1.
> I do notice that I forgot this detail in the Pi implementation
> too, so it is also returning a 32 bit value.
> The reasoning for the 8-bit return is that the return will always
> be binary. 0 or non-zero, but by mapping a non-zero value to 1 may
> make more sense than outputing a 32-bit bitmask, which was the
> initial approach.
> Thanks.
> Best Regards,
> Ketul
> --André Marques.
> [snip]
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150813/136d69c8/attachment-0002.html>
