[PATCH V2 1/2] RTEMS GPIO API definition and implementation.
Ketul Shah ketulshah1993 at gmail.com
Thu Aug 13 14:25:25 UTC 2015
Hello Andre,
I created a ticket <https://devel.rtems.org/ticket/2390> . Please make the
necessary changes.
Thanks.
Cheers,
Ketul
On 13 August 2015 at 19:38, André Marques <andre.lousa.marques at gmail.com>
wrote:
> On 13-08-2015 14:51, Ketul Shah wrote:
> Hi Andre,
> Thanks for the reply.
> On 13 August 2015 at 19:13, André Marques <andre.lousa.marques at gmail.com>
> wrote:
>> Hello Ketul,
>> On 13-08-2015 13:04, Ketul Shah wrote:
>>> Hi Andre,
>>> Great API and happy to know that it is merged with main line.
>>> Eventually I implemented GPIO driver for BBB using this API. After
>>> debugging for rtems_gpio_get_value() on BBB I found the following bug.
>>> For BBB, GPIO pin nos. varies from 0 to 32. So function return type
>>> would be uint32_t instead of uint8_t.
>>> For BBB I wrote :-
>>> uint32_t rtems_gpio_bsp_get_value(uint32_t bank, uint32_t pin)
>>>   return (mmio_read(bbb_reg(bank, AM335X_GPIO_DATAIN)) & BIT(pin));
>> So it would be:-  return ((mmio_read(bbb_reg(bank, AM335X_GPIO_DATAIN)) &
> BIT(pin)) > 0);
> Am I correct ?
> Yes, but since this function is not used by applications maybe it would be
> best to return the bitmask here and avoid another operation, as
> rtems_gpio_get_value does the mapping to 1 anyway for any value above 0.
> So yes the bsp function shall return uint32_t instead of the uint8_t.
> Doxygen also has to be updated.
>> the rtems_gpio_bsp_get_value returns the value of a GPIO pin, which can
>> only be either 0 or 1. This is not platform dependent. Any value greater
>> than zero should map to 1.
>> I do notice that I forgot this detail in the Pi implementation too, so it
>> is also returning a 32 bit value.
>> The reasoning for the 8-bit return is that the return will always be
>> binary. 0 or non-zero, but by mapping a non-zero value to 1 may make more
>> sense than outputing a 32-bit bitmask, which was the initial approach.
>> Thanks.
>>> Best Regards,
>>> Ketul
>> --André Marques.
>> [snip]
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150813/e243b6a2/attachment-0002.html>
